#26 |
Re: 71' K10 4x4 SWB project "North to Alaska"
Looking good!
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
#27 |
#28 |
I Am definitely jealous! Awesome Job and great progress . I was hoping to have my truck done for the spring to make a run to the Yukon . looks like i will have to read your progress
#29 |
Awsome build. Truck should end up cool too. My truck gun is the 1895 in 45-70. Added wildwest trigger, ejector, xs ghost rings, did a fill on the rear site dovetail and refinished whole thing in duracoat Teflon. If you are not aware of grizzly custom guns you should google them and check out his brush hawg packages. Are you going 50 alaskan to match calibers with a handgun? Love the "big medicine".
Also your truck looks good and great call loosing the 20's. Like your choices in test drivers. |
#30 |
Thanks Guys, Roxx just let me know when you can pick it up
![]() Bojak, I've been thinking about a big revolver as well, hehe we'll see on that. I finished the 50 Alaskan this weekend and started in on the truck again. The gun works well, and there isn'y much to show on the truck,but completely wired the MPFI, ECM, and Ignition. All modded into the factory harness to look semi-original. Then started plumbing heater cores, belts.. ect.
-2010 Silverado daily driver, 5.3, 24's, HP tuners ect -2006 Silverado 6.6 Duramax, 6" lift, 37's, efi live -1988 S10 10 point cage, 383, linked,1-tons 42's -1971 1/2 ton 4x4 SWB, Ramjet 350/SM465/NP205, 6" lift, 35" BFG's, 15x8 ralley's, and lots more to come.... -1957 GM 3800 (9433) Napco 4x4, She's rough and I love it! |
#31 | |
Cough cough ![]() |
#32 |
Well I finished fitting and tigging up the exhaust, as well as dynomatting the incab tank with the electric fuel pump.
#33 |
I then got the tank in and mounted/plumbed as well as the vinyl flooring and the rest of the interior. I then put in a nice hidden receiver hitch for a rear tow point and incase I want to tow a small trailer.
#34 |
Ohhhh jeees Truck is looking rougher then ever ...
#35 |
Now it was time for the drivetrain, I got all new spicer "life" series ujoints for everything, I run only these u-joints in everything I have and have yet to have a failure under 100K miles. I also started tearing down the rear diff for a full overhaul with new everything and a Detroit trutrac diff.
#36 |
This is how she sits today. I am waiting for a rear ring and pinion, and the front Detroit Truetrac and I should have her together in a couple of weeks sans any problems.
I have fired and set the timing on the ramjet and it seems to run great. As the the fuel pump in the cab, you can hear it prime barely before the engine fires but then I can't here any noise from it. Hopefully my parts show up and I can get the front end completely done with new ball joints, tie rod ends, bearings, seals, diff ect... over the course of the next few weekends, as well as button up the rear. Then I can drive her again, and its almost time for all the snow to melt up here so not a second too soon. I also included a pic of the stock axle shafts on the left compared to the 73+ 297x ones I'm using on the right so people can see the differences. I didn't know the older 72 and prior ones necked down so small the whole length. That's Dana 30 size!!
#37 |
Awesome build man, hope you make it to alaska. Feel free to stop by if you do! haha
78 chevy scottsdale 4x4 k10 ![]() Alaskan Members Check In http://67-72chevytrucks.com/vboard/s...22#post5094422 |
#38 |
![]() I got the rear ring and pinion and Detroit in and all set up with a great pattern, as well as the front Detroit and gears. I also did all new bearings, seals, ball joints, u-joints, brakes, tie rod ends, drag link ends ect...
#39 |
I also got a spare 35" swamper I had laying around mounted up on another rally rim for a spare tire. I then put the drive shafts in and took her for a spin...... and embarrassingly the tranny was howling.
#40 |
I suspected a bushing I got from trans warehouse since day one as it fit too tight in the granny gear.... I measured it as .010" OD over the old bushing, but it was new and the other was worn I figured? Nope, it was just a sh!t part. So she's back on the lift, I tore the tranny out, and found that bushing burnt up. It also scored up the main shaft and the granny gear. Luckily I have a lathe and a diamond wheel grinder set up to true the shaft and re-grind and I had a spare granny gear. I put it all back together with a new bushing I got locally that measured in correctly.
#41 |
Got her done again and put 25 miles on her last night, other then running cool (needs hotter thermostat with that huge rad) it ran great.
#42 |
looking great man.
#43 |
Just curious if this pick-up is ready for that Alaska trip?
Great build!
'72 Blazer, A/C, tach, tilt. Not on the road at this time '87 v30 Custom Deluxe, standard cab, SRW, Utility bed '86 c10 Silverado longbed (for now) '19 ecsb, 2500, 4x4 '15 Subaru Legacy - commuter |
#44 |
Mee too!!! I love the build, one of my favorites! I also love the marlin, glad to see even more gun lovers in here! It seems like a rarity nowadays! Keep it up
#45 |
![]() Join Date: Nov 2007
Nice build. Good luck moving forward on body and such.
Chris
Project Reno Build http://67-72chevytrucks.com/vboard/s...d.php?t=392636 Easier to beg forgiveness than ask permission! ![]() |
#46 |
Looking good
#47 |
Bump
Mine: 72 c20 Chevy suburban, 02 5.3 w/4l60e , factory ac and 50gal tank. 70 k10 Chevy burb, 04 5.3 w/4l60e np241, with dual 30gal saddle tanks and rear 30 gal tank Dads: 67 c10 step side(project) 72 c10 GMC burb 350/400, with 67 Chevy front clip(grocery getter) Ours: 67 c30 tow truck 70 c10 long bed 383stroker w/digital gauges(work truck) |
#48 |
Meh That Ugly Truck ...... I did offer to take it off His hands (Cheap) (Really Cheap )
