#726 | |
Re: Crusty Rusty Leaky Squeaky 67 Step
This unfortuantely doesn't apply to Vic because he went from a stepside to a fleetside and had to buy the bed to start with, but for those who start with a truck that was a longbed it is certainly true. |
#727 | ||
![]() Join Date: Mar 2012
Victor 57 Chevy Wagon - California Dreamin'"Mecum'd" 9/2022 Dallas, TX Crusty Rusty Leaky Squeaky 67 Consigned 4/2019 Dresden, Germany Maybelline - my '57 Ford 2dr Sedan "Mecum'd" 3/2016 Location unknown Silver Streaker "Mecum'd" 4/2013 Somewhere in Texas |
#728 |
Very good point Vic.
1970 SWB Got My PB Suspension It's On Now- 1970 SWB - Porterbuilt to the Extreme Mike |
#729 |
Brian G. came over yesterday and while he was here I enlisted his help to flip over the floor so I could weld the underside seam. Weld penetration was good for about 60% of the seam, but the remaining 40% needed the reinforcement. With all the welding done, I can lay the bed floor flat on the concrete and knock down the little dents.
Removed and filled in the stake pockets on the driver bedside, then sectioned it. Bunch of pieces on the floor now! Doubt it will go back together as quickly as it came apart. There's a fair amount of hammer and dolly work and holes to weld before I can fixture anything up. Now is the time to do it, though, because access to the backs of the panels won't get any easier once reassembly starts. I've also been cleaning the edges where the various pieces will bolt to the floor. The old seam sealer and caked on filth and rust might interfere with the fit when I start mocking it all up. Or then again, maybe I'm being too anal. Only takes a small amount of effort, so better safe than sorry, I guess.
#730 |
![]() Join Date: Mar 2010
Nice work as always Vic. Coming together!!
#731 |
Looking great! I know to save my bed i'm gonna have to take it apart too, for a first timer (that being me) would you rate it pretty easy? Just the one weld in the back per side and start unbolting everything (including any ground straps and unhook the lights of course) Thanks!
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
#732 | |
#733 |
The Zip wheel is your friend, at least in my case.
Boppa's Old Yeller Truck Build, Old Yeller's New Heart! Project Buzz Bomb Flyin' Low! |
#734 |
Not much exciting stuff going on. Been welding up holes and doing hammer and dolly work on the pieces of the bed. For some reason, I decided now would be a good time to patch the side marker light opening. Cut out the material I needed and welded it in. When I released the clamps, it went crazy. I had the same problem on my previous truck and blamed the TiG. Used a MiG this time and same result. Tried working out the low spot with the slapper, but it was having none of it. So I cut out the patch along with the frame. The panel immediately returned to the correct shape. I made a second patch and rolled an offset around all four edges then spot welded it in place. No distortion, so I'm leaving it like it is until I get the sections welded back together. It should be rigid enough at that point to finish it out.
#735 |
Today, I dollied out as many dents as I could get to on the bed floor then flipped it over to begin fixturing the sections. I'd bought a new front panel this past fall and when I pulled it out of the box, it was seriously twisted. So I made a panic trip to Classic Parts and exchanged it for one that was only bowed along the bottom lip. Brian G. is coming over tomorrow to help me use the shrinker to straighten it out. Hate working on brand new parts, but the counterman was real upfront and said it wouldn't be likely to find a perfect one.
The initial fit on the driver side looks pretty good, even without using any butt clamps. Need to trim a little in a few places to get a closer fit, but it should be no problem. You can see the offset between the body lines in the last photo. Not as bad as I'd envisioned, but it will still be an interesting exercise to make it 'flow" seamlessly.
#736 |
Looks great so far! That flat bar or angle you've got clamped under the bed rail is a great idea too. The mis-match at the roll is about the same as I had. Anxious to see how you tackle that.
'77 K30 3+3 - "The Crummy" http://67-72chevytrucks.com/vboard/s...d.php?t=640134 '67 C10 L/SWB - Soon to be daily driver! http://67-72chevytrucks.com/vboard/s...d.php?t=471776 ![]() |
#737 |
I'll give it to ya Vic, I couldn't imagine attempting what you're doing, and you make it look like a piece of cake.
Jason '70 C-10 short fleet 427BB TH400 (SOLD) '10 Ford F 350 '13 Ford RAPTOR 6.2 MY BUILD THREAD http://www.67-72chevytrucks.com/vboa...d.php?t=612623 |
#738 |
Nice work Vic. Good luck on the bedsides, looks pretty challenging.
Scott |
#739 |
I ran into the same issue ish on the s-box. If you have a smidgen of prior damage/deflection, it will go BUCK CRAZY when you weld/heat anywhere near it. It was a challenge to get it back halfway close! Can't wait for the next installment. Sure enjoy your work.
I'd also say, while we're talking about beds, I don't know where you're at on a tailgate, but get and redo/repair an OEM one. The repro's fit pretty good and look pretty good, but have the consistency and constitution of a beer can. We've dented Yeller's three times since it's been finished. We're looking to replace it long term.
#740 | |
Speaking of the front panel, Brian G. came over this morning and together we straightened out the bow in the bottom lip and attached it up to the floor. Fits perfectly now. We then mocked up the front section of the bed using the panel and holes in the floor as our guide. It's going to work out great. While he was here, we discussed the problems with the passenger side sheet metal and how it might be better to at least buy repro for that side. I got to thinking I'd already invested $140 in what appeared to be a thin, marginally usable patch panel. For another $335, I could have the whole dang thing and not have to fill the side marker hole and do all the other repairs. Looked at the clock and said, to heck with it ...I'm goin' for it. Made it to Classic with time to spare and exchanged the patch panel and the $$ for a complete bedside. However, the euphoria was short lived. After getting home with it, I bolted on the wheel well and noticed right away that the holes in the bottom ledge of the panel didn't match up to my OEM piece. Went ahead and positioned it on the floor and the depth of the problem was immediately evident. In order for the wheel well to fit, I'll have to do major surgery to relocate the captive nuts where the wheel well attaches. Two steps forward... ![]()
#741 |
Hrmrmrm... Mine on both sides popped right together with no problems. Both of mine came from Ron Manes in Odessa, Mo. You may wanna give him a call and see which brand you got. I don't have the box, or I'd look for you. Anyway, I think there's 2 or 3 brands, you might give it a check on. Sorry it didn't drop right on for ya.
#742 |
lol. thats awesome Vic
Scott |
#743 |
That new bedside looks like it has its own set of problems, which is scary because I have two repro bedsides. I wonder if the fitment is just on factory floors.
Scott |
#744 | |
Not sure if your version of Porterbuilt suspension will force you to raise the bed floor or not. If not, and you want to compare the fit of your bedside, when the weather clears and you have some free time, haul the right side over here and we'll test fit it. That would tell us both something. ![]()
#745 |
I will definitely do that Vic. I bought these last year and I think the guy I bought them from had them for several years prior to selling them. Hope these are from the good batch.
Scott |
#746 |
Still a lot of welding and grinding ahead good luck buddy.
#747 |
I'm wondering if the issue isn't the bedside but where the floor was cut in both the front and the back, perhaps the preportions are incorrect and it is throwing everything off, for example if it's an inch too long in the front and an inch to short in the back then the wheel wells wouldnt line up, I'm just spitballing here.
The only way you can know for sure is to measure someone elses shortbed or try a known good bedside on your floor. Last edited by Xeen; 03-02-2014 at 02:04 AM. |
#748 |
I think I'd return the bedside and consider trying another from a different supplier.
I thought i was the only guy that took 2 steps forward and 4 steps back..... ![]()
#749 | ||
#750 | |
![]() Ahh, man it's been a long time since I have been on here, and I am never disappointed with your build Vic. The amount of attention to detail in your builds is nothing short of spectacular. From what I can decipher, it looks as though you are going to a fleetside bed on this one? |
