03-01-2014, 12:48 PM | #1 |
Frame holes are elongated where shocks connect
Hey guys.
I am guessing my 68 was used for off roading in the past. The shock holes in the frame are now oval. I am planning on welding them back to round. I am guessing I should weld from the top down???? The off roading caused the shocks to jam upwards and push the holes upwards??? Any suggestions on how to fix this to make them round again would really held. I'm a total noob. Thanks Picture is sideways, so turn your heads left. |
03-01-2014, 12:52 PM | #2 |
Re: Frame holes are elongated where shocks connect
And also, there are hairline cracks going outward here, so this frame was definitely under some serious stress here.
03-01-2014, 08:17 PM | #3 | |
That is very common in all of these trucks, because the mounts are "single shear".
I have fixed dozens of them with various methods. This includes a simple weld to the oblong edge for minor wear and going as far as welding thick washers in place inside the frame. This gives some back-up for any cracks that may have developed too.
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. |
03-01-2014, 08:22 PM | #4 |
Do you have an idea as to which edge is the "oblong edge"? The top or bottome of the hole? Or does it even matter?
03-01-2014, 09:09 PM | #5 | |
As a bad as that is, I wouldn't worry about it. I would go for somewhat centered and call it good. It's not a precision thing anyway.
03-01-2014, 09:32 PM | #6 |
Moderator
I would find a thick washer, weld it in then get CPP's shock mount support tabs:
http://image.customclassictrucks.com...d-to-frame.jpg
'20 Silverado Trail Boss ~ '17 Tahoe ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '71 Cheyenne swb ~ '55 Pontiac Safari ~'50 3100 bagged ~ '80 Wife ~ Late model kids
03-01-2014, 09:38 PM | #7 |
I would stop drill the crack also,but that's just me.
84 step side 87 swb |
03-02-2014, 12:38 AM | #8 |
Try this link, maybe it would work for you.
http://67-72chevytrucks.com/vboard/s...d.php?t=516508 |
03-02-2014, 08:06 PM | #9 |
Thanks guys and great info! I like those cpp brackets....
03-03-2014, 12:03 AM | #10 |
Never Ending Projects
CPP brackets work great. Have installed them on two trucks.
. 1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
