Old 03-02-2014, 01:35 PM   #1
1rudestude
steering column wiring question.
Hi guys, I do apologize if this question has already been asked and addressed but I am at the end of a suspension swap on my 62 and have used a 69 column and have looked for info with no luck on wiring the 69 into a 62 . thanks
1rudestude is offline   Reply With Quote
Old 03-03-2014, 04:16 AM   #2
j_persinger66c10
Re: steering column wiring question.
The wiring colors changed I believe in 1965. So you will have to get a wiring diagram from a 1969 and one from a 1962 and match them up wire by wire. Here is a thread for the full body wiring of a 60-66.
http://67-72chevytrucks.com/vboard/s...d.php?t=378484
j_persinger66c10 is offline   Reply With Quote
Old 03-03-2014, 02:00 PM   #3
1rudestude
Yes you are correct I have been looking online for this info and so far have only found one for a 57 and a 71 and it dose not seem to jive but still looking thanks.
Old 03-03-2014, 03:44 PM   #4
Trump
I assume you are talking about colors or which colors to connect to what?
I am in the process of rewiring my 1964 and most of the wire colors match up with exception of the two shades of blue. My kit was universal but meant for use with a GM column, so I would assume that they should be close.
I can tell you what colors came in my harness that should match the later model column and what they matched to in my 1964 if that would help....I can get it tonight if you need, just let me know.
I am not sure if the harnesses are the same for 64 v. 62, but if you have any interest in the harnesses and some new female spade terminals to fit inside the harnesses, let me know. I ended up using a terminal block to make all my steering column connections. So, mine are available.
My wiring is still out for the most part if you need a picture to help or anything.
Trump is offline   Reply With Quote
Old 03-03-2014, 04:16 PM   #5
1rudestude
Trump, I believe J persigner66c10 is correct I read that the wiring changed in 65 so a 64 should be the same I found one for the late 50's and the colors seem to be the same but still scrounging through and trying to find one for the 69 and also would like to see you 64 diagram to confirm what I am working with is the same as I am not sure. Thanks.
Old 03-03-2014, 04:25 PM   #6
Trump
Ok, I will try to get back to you tonight after I get home from work to take some pics and do some checking if nobody else gets to it first.
Old 03-03-2014, 09:11 PM   #7
Trump
Ok I am going to try and give this a shot without getting it jumbled. Here's my theory. I am using a later model aftermarket harness that is supposed to match the later model wire colors with an early style (1964) chevy steering column and ignition switch. I am making a chart that references the "harness" which should have wire colors that match the later model column, unless something is missed.
Turn signals and horn:
Column (1964) / Harness (later style wire colors)
Green/White / Light Green
Black/White / White
Black/Yellow / Yellow
Purple / Purple
Black / Black
Black/Blue / Light Blue
Blue/White / Dark Blue
N/A / Brown (hazards)
IGN Switch (1964)
/ Wiring Harness (later style)
Brown / Brown (acc)
Purple / Purple (starter)
Red / Red x2 (Batt)
Pink / Pink (coil)
Pink / Orange (ignition) (Spliced w/ orange)
Dark Green (thermo sender) / N/A
Sorry about the font colors. I tried to set it up like a table, but the format wouldn't let me. So the font colors separate.
Hopefully this is what you are looking for. If you or anybody else finds any issues, please correct them. I used a terminal strip to replace the half-moon connectors. I have the half moon connects and new female spade terminals to use with them available if needed. The back of my ign switch is labeled so that should be pretty easy for hook-up. Pictures below.
Let me know if you need anything else.
half moon connectors (male and female)
Old 03-03-2014, 09:23 PM   #8
Trump
PS- I used the diagrams at the link below to do my matching.
http://67-72chevytrucks.com/vboard/s...d.php?t=312351
Old 03-03-2014, 10:49 PM   #9
1rudestude
Thanks, I will check it out and hopefully will be able to hit the road this week.
Old 03-14-2014, 12:58 PM   #10
Trump
I just came across this little do-dad (classicparts.com PN#77-504):
http://www.classicparts.com/1963-66-.../#.UyM0nU2Ircs
might make life easier
Old 03-14-2014, 01:16 PM   #11
1rudestude
Thank you Trump, That is cool. I figured it out thanks to you help already and have been driving the truck. Know I am on to the elusive G.M.C. in hood marker light assemblies.
