Old 03-02-2014, 06:05 PM   #26
bpmack16
Re: How many of you guys are running 700r4's
So I got a quote today from a local shop that has a good rep. All said and done $2,300 that is take out old trans, move cross member, build trans w/ upgraded parts, 2400 stall
, shorten drive shaft, all linkage and wiring ex.......... drop of on Monday and get it back road worthy Friday. It sounds high to me. What do you guys think.
bpmack16 is offline   Reply With Quote
Old 03-02-2014, 06:15 PM   #27
Eddie H.
Eddie H.'s Avatar
It actually sounds pretty reasonable for a complete turn key job.
"Negative people always seem to have a problem for every solution"
Eddie H. is offline   Reply With Quote
Old 03-02-2014, 06:39 PM   #28
calvin78612
calvin78612's Avatar
Sounds like a good deal,you'll be gald you did it.
84 step side
87 swb
calvin78612 is offline   Reply With Quote
Old 03-02-2014, 06:54 PM   #29
C10_ustacould
A day late and $1 short...
C10_ustacould's Avatar
Sounds like a good deal to me.
Buck
Instagram: C10_ustacould
1963 SWB Fleet Side 528 Desert Beige
Milly
1967 SWB Step Side 506 Medium Blue
The Old Girl
1968 SWB Fleet Side 503 Light Green
Ellie SOLD
1965 SWB Fleet Side 507 Light Blue
Prescription Strength SOLD
1971 SWB Fleet Side 521 White
Shiro SOLD
1968 SWB Step Side 503 Light Green
My Old Farm Truck SOLD
C10_ustacould is offline   Reply With Quote
Old 03-02-2014, 09:43 PM   #30
davischevy
davischevy's Avatar
One of my buddies got a quote to do the same job in his 70 442 last week, and that's what they priced his at. $2,300.
other Larry
Build thread, Arkansas K10
https://67-72chevytrucks.com/vboard/...=755797&page=5
The ability to speak several languages is an asset, but the ability to keep your mouth shut in any language is priceless.
davischevy is offline   Reply With Quote
Old 03-05-2014, 12:22 PM   #31
bpmack16
Just heard this today but do you have to use a caprice or impala ss tail shaft housing to make the 700r4 work?
Old 03-05-2014, 01:03 PM   #32
suspect
suspect's Avatar
I doubt that. Just use whatever housing is on it, shorten or lengthen driveshaft accordingly.
Daniel
68 C10 Build http://67-72chevytrucks.com/vboard/s...d.php?t=503594
Romans 10:13 Everyone who calls on the name of the Lord will be saved.
suspect is offline   Reply With Quote
Old 03-05-2014, 01:08 PM   #33
HIGHWAY BY THE SEA
HIGHWAY BY THE SEA's Avatar
I used to have one in my 81, but I accidentally burned up the 3 and 4 clutch packs by towing a trailer behind it on the interstate. Until that happened that was the best transmission that I ever owned. My 350C turbo does not even come close.
FRANKENTRUCK 1981 Chevrolet C10 Shortbed Stepside
GRANDTRUCK 1968 Chevrolet C10 Stepside Longbed
http://67-72chevytrucks.com/vboard/s...d.php?t=584617
PROJECT JIGSAW 1967 GMC C3500
GREAT WHITE 1986 Blazer M1009 454 engine w/700R4 transmission gas conversion
HIGHWAY BY THE SEA is offline   Reply With Quote
Old 03-08-2014, 12:45 PM   #34
bpmack16
What is the best TV cable and bracket kit for this job.
Old 03-11-2014, 11:39 AM   #35
bpmack16
So I got everything ordered yesterday. The trans is being built this week and I will drop of the shift parts and tv made ez when they come in. Then then the truck will be dropped of and the transplant will begin. What end of the drive shaft did you guys shorten? The front half or rear? Or should I go with a single driveshaft ? What are the pros and cons of single drive shaft?
Old 03-11-2014, 12:15 PM   #36
Stickman
Stickman's Avatar
In my opinion the BTO one is an awesome product. They have them for most carbs and look nice also. Ask for Jenn if you call them, the girl knows her tranny's and service is top notch , they are an easy install and adjustment.
Stickman is offline   Reply With Quote
Old 03-11-2014, 01:00 PM   #37
bpmack16
That the one I got. I figured you don't want to get crap when you spend all that money on a built 700r4. Thank you though for the info.
Old 06-24-2014, 06:16 PM   #38
ESKAPEE
where do I find a shift linkage for a 68 column shift for the 700R4?
1968 Stepper
ESKAPEE is offline   Reply With Quote
Old 06-24-2014, 07:54 PM   #39
Longhorn 70
Longhorn 70's Avatar
Lokar is your friend.
1970 Longhorn, Front Disc, 350/4 bolt, 882 heads, HEI, Edelbrock, 700R4, HO-52/4.11.
1996 Corvette, Collector Roadster, LT4, 396, 450RWHP, 6sp, 4.11/Dana44/posi 5 point roll bar
And let us not grow weary of doing good, for in due season we will reap, if we do not give up. Gal 6:9
Longhorn 70 is offline   Reply With Quote
Old 06-24-2014, 08:48 PM   #40
calvin78612
Great product ! You won't be disappointed, and made in the USA !!
84 step side
87 swb
Old 06-24-2014, 10:19 PM   #41
derotoreut
Roto Reuter thats the name...
derotoreut's Avatar
Not looking to start a debate, but when I bought my TH350 torque converter from Hughes Performance, they suggested a 200-4R over the 700R4 as a future upgrade. At the time I wasn't interested in spending the money to change to an overdrive transmission because my truck is mainly a weekend driver. If it was a daily driver (or driven more often) I might consider it. For my situation it just doesn't make sense to spend the extra money. Maybe some day though. If/when that day comes, I will seriously look into both transmissions.
~ Dan
My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232
My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394
1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt
1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project
"Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977
derotoreut is offline   Reply With Quote
Old 06-25-2014, 03:43 PM   #42
68is4me
68is4me's Avatar
i will be running one when I start my build.
I paid $300.00 for a tranny out of a 91 caprice with 100,000 miles and still works good. Paid about $700.00 for a good rebuild kit with trans-go shift kit, alto racing cluthes and extra clutch packs. All this will be going behind a 454 with 500hp/500+tq. The rebuild will be done by me as I have access to all the tools and books.
Will probably run a ECE cross member for looks and the ease of removing tranny pan.
68is4me is offline   Reply With Quote
Old 06-25-2014, 09:03 PM   #43
piecesparts
Parts and more parts
piecesparts's Avatar
With that engine consider upgrading the planetary, sonex valve, hardened valve body separator plate, oil pump (Pump definite weak spot)
Frank
Old 06-26-2014, 09:10 AM   #44
68is4me
68is4me's Avatar
Yah, I was considering up grading planetary but I don't think I should have to since I don't plan on towing, As for the pump it should have the good pump already in it, will just update it with new bushings and pressure springs, not sure about the sonex valve, and separator plate will have to check into that.
Thanks for the advice.
Old 06-26-2014, 01:18 PM   #45
70blackfish
with that lumpy cam your going to need more than 1800 factory stall, even the corvette 2200 stall isn't going to be enough, going to suk if you have to do it twice....
69 SWB 780hp Hellcat powered, manual 6 speed, currie 9
70blackfish is offline   Reply With Quote
Old 06-26-2014, 07:11 PM   #46
profe56
I had one for about three years or more, I bougt it at a Junk yard from a Chevy C20 1990, but the transmission was 87, I got another one from C20 1990 but now yes it is a 1990 trans. I found they are diferent cases.
Dirty one is 87 and clean one 90
profe56 is offline   Reply With Quote
Old 06-26-2014, 07:18 PM   #47
piecesparts
I am here to ell you that unless your plans are to baby the truck, the upgrade on the pump is a good idea, since you are going into the tranny. Two pumps down in mine and the time to take it apart for those repairs. Go heavy duty or baby it. I don't tow with mine, but I do get a little excited with it now and then. Not drag race excited, but enough to warrant heavy duty parts.
Frank
Old 06-26-2014, 07:33 PM   #48
profe56
Also, I got the transmission with the tv cable and I notice the adjustable cable is longest than this one that was on an FI engine and mine is carburated. I'll see later if the cable is long enough
