Old 03-01-2014, 09:28 AM   #1
dman1982
dman1982's Avatar
where to start???
yesterday i went and picked up a 5.3 engine and trans 4le60 with a 130k, has full harness minus the ecu and mass air, this really has every wire that goes to the motor and trans still on it....holy crap thats a lot of wire!!! but where the heck do i start??? oh and i got the whole thing for 1200 bucks
Sgt Dennis Heineman
USMC Aviation Ordnance
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
2009 Troy Built with a 42 Inch Deck
My LS Swap http://67-72chevytrucks.com/vboard/s...=1#post6559371
dman1982 is offline   Reply With Quote
Old 03-01-2014, 12:50 PM   #2
LONGHAIR
Re: where to start???
I would think that figuring out how you are going to control it. With no ECU, you are looking at some kind of aftermarket unit.
I'm sue that there are guys who have done this who will have specific ones to recommend.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 03-01-2014, 12:52 PM   #3
dman1982
dman1982's Avatar
I'm going to order one, once it comes in I'm going to send it off to get the wiring harness cut up and get it tuned for my truck
Sgt Dennis Heineman
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
Old 03-01-2014, 03:05 PM   #4
dman1982
dman1982's Avatar
well i got the harness of the new motor, started getting my old engine tranny out, then there was rain!!! dang it
Sgt Dennis Heineman
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
Old 03-01-2014, 05:43 PM   #5
dman1982
dman1982's Avatar
well got a lot done today....
Sgt Dennis Heineman
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
Old 03-01-2014, 05:44 PM   #6
dman1982
dman1982's Avatar
git r done
Sgt Dennis Heineman
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
Old 03-01-2014, 09:24 PM   #7
dman1982
dman1982's Avatar
i bought a 2004 5.3 and 4le60 trans yesterday, has the whole harness, no ecu, or pedal or mass air, I've already ordered the pedal, been looking into getting a ecu, and mass air sensor and air box. I'm looking for advice....looking for companies to send my harness and ecu (once i get it) to get chopped up and tuned, and any other advice as to stuff i might need, and was wondering if i can use my transfer case...i have a np208 or if i could buy a adapter and use a stock one from a 2004 chevy? this is my first swap and trying to make it as painless as possible
Sgt Dennis Heineman
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
Old 03-01-2014, 10:40 PM   #8
LONGHAIR
The transfer case from an '04 is not going to work in your '84. It would have what is known as "driver's side drop". Meaning that the out-put for the front driveshaft is on the driver's side, plus it would have an odd out-put because it is intended to fit a "fixed" differential of an independent suspension.
Yours needs passenger's side drop, but mating it to a regular rear wheel drive transmission may be tricky or at least costly.
Old 03-01-2014, 10:44 PM   #9
dman1982
dman1982's Avatar
id heard of adapters to hook my 208 to the newer trans, and id also seen something somewhere where someone was able to use the newer transfer case...the second statement may have been from reading sooooo much on these swaps...trying to do this sooner than later haha...hate seeing my truck on blocks
Sgt Dennis Heineman
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
Old 03-02-2014, 10:32 AM   #10
nekkidhillbilly
you can use the adapter fromt he 04 on the 208 yes. it should be between the 04 trans and transfercase. bolt that to the 208. also to op theres a list of things on the net of what all you can cut out of the harness. just need to get the wiring diragram.
the thing on the back bolts to a 208/241 along with the newer tcs which are lsd 241s.
nekkidhillbilly is offline   Reply With Quote
Old 03-02-2014, 10:34 AM   #11
nekkidhillbilly
now on to using a new transfercase it can be done too but you need a left side drop axle. a ford axle and its pretty much a bolt in. me though id keep the 208.
Old 03-02-2014, 12:07 PM   #12
LONGHAIR
I would keep the 208 too, for several reasons.
First and foremost, you already have it
You can keep your original driveshafts and shifter.
You can skip the "adapting" for the front driveshaft and all of the wiring that would be required to make the later model unit shift.
Old 03-02-2014, 12:39 PM   #13
dman1982
dman1982's Avatar
i like your way of thinking....would now be a good time to have it rebuilt? it works fine but has a lot of miles on it (i think) at least a 40k, thats about how many miles I've put on it
Sgt Dennis Heineman
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
Old 03-02-2014, 12:51 PM   #14
nekkidhillbilly
if its doing ok i cant see the point. just change the fluid.
Old 03-02-2014, 12:52 PM   #15
LONGHAIR
40K is not bad, if they are not abusive miles. Don't fix what isn't broken......you already have enough to do.
Old 03-03-2014, 05:01 PM   #16
dman1982
dman1982's Avatar
got to remember i said ATLEAST 40k lol, could be a 140, 240, who knows...but i aint messing with it til i have to...now i gotta think about fuel delivery
Sgt Dennis Heineman
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
Old 03-03-2014, 06:32 PM   #17
TheBlueBomber
TheBlueBomber's Avatar
Hey Sgt, Check out my build thread I'm doing a 5.3 swap right now. My set up is going to be 5.3/4l80e/np241.
Most companies are going to charge you about $700 bucks to do the harness but my buddy does them for less than $300 and he's doing mine. Shoot me a PM if you want his contact info.
Austin
1996 Chevrolet K1500 Silverado
1979 Chevrolet K10 Scottsdale - Carolina K10 -
My 4.8L Twin turbo build - Project Short Stroke -
Instagram - TheBlueBomber1996
TheBlueBomber is offline   Reply With Quote
Old 03-03-2014, 06:34 PM   #18
TheBlueBomber
If it aint raining, we aint training!
Austin
Old 03-03-2014, 06:58 PM   #19
dman1982
dman1982's Avatar
very well....electrical and rain...no good combo haha
i just checked out your build...looks really good man...im going with the traditional swap, bone stock look...for the most part....never done this before so I'm sure it'll looked a little jacked up
Sgt Dennis Heineman
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
Old 03-03-2014, 07:22 PM   #20
nekkidhillbilly
as long as it works right
Old 03-03-2014, 07:25 PM   #21
dman1982
dman1982's Avatar
true story hillbilly
Sgt Dennis Heineman
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
