Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > S10 S15 Luv Blazer
Old 09-21-2013, 07:33 PM   #1
Spline64
Spline64's Avatar
Strange Tire Wear / Wandering
Hey Guys,
Have one tire that has wear on both the inside and outside. Was parked on a slight hill and the top of the tire was leaning so far out I thought it was going to fall off when I backed up. Doesn't always do it cause I tried to repeat this at home with no success. Also has about 8 inches (I am not kidding) of play in the wheel before it will start to turn. Wanders like crazy, acts like it is following the road but wanders both directions.
I'm thinking this is all connected (same cause) but know nothing about suspension and don't feel like getting ripped off at a mechanic. Attached a couple of pictures hopefully someone out there can shed some light?
Thanks,
Pat
Spline64 is offline   Reply With Quote
Old 09-22-2013, 10:35 AM   #2
Zane M
Re: Strange Tire Wear / Wandering
There are multiple possibilities(tie rods, idler arm, ball joints), or a combination of all.
Jack the truck up and grab the tire. Grab it at the top and bottom, and pull in/out. That will give you an idea if it is the ball joint. Look for play in the ball joints. Grab it on the sides and pull back and forth. Look at the other components like the ball joint, idler arm, etc. and see if/where the play is. This will give you an idea of what needs to be replaced, so you can go to a mechanic with some knowledge.
I almost forgot, you will also want to inspect the A Arm bushings.
Zane M is offline   Reply With Quote
Old 09-22-2013, 04:05 PM   #3
Spline64
Spline64's Avatar
Just gets weirder....
jacked the front end up and tried to move the tire. Wouldn't budge. Decided to replace the tire with the spare cause it was so rounded and the second time I jacked it up after driving it around a bit, the tire can be moved from side to side, not top to bottom. Explains the wandering to me.... so that means??
Thanks,
Spline
Old 02-21-2014, 11:01 AM   #4
BlackedOut67shorty
BlackedOut67shorty's Avatar
A good alignment shop can tell you what's going on, the one I take mine to didn't charge me for it rather, just let me fix the issue and bring it back for an alignment
1995 s10 blazer 4.3
1967 c10 350/350 fleet short
1993 s10 blazer 4.3l 4l60 RIP 6/20/14
2011 subaru impreza sport
2001 s10 blazer 4.3
1992 chevy caprice wagon
BlackedOut67shorty is offline   Reply With Quote
Old 02-21-2014, 11:27 AM   #5
Gumby
Gumby's Avatar
to much toe can wear the outter edges fast [ been there ] maybe it works the other way to. I saved a bundly DIY with rockauto .
Gumby is offline   Reply With Quote
Old 02-22-2014, 08:54 AM   #6
68C15
blood type; Retumbo
68C15's Avatar
place jack under spring pocket in lower arm. Jack up tire 3 or 4" from ground. Place pry bar (long) under tire and have buddy lift bar while you watch for movement in ball joints and control arm bushings. Then have him wiggle side to side while watching inner and outer tie rods, idler arm, and pitman arm.
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card
68C15 is offline   Reply With Quote
Old 03-04-2014, 10:58 AM   #7
donthekawguy
donthekawguy's Avatar
Get a repair amnual and check out the steering section. It's pretty easy once you get a look at how it goes together. Sounds like you need to replace all the parts in the suspension and steering. Most are pretty cheap and easy to replace. If money is tight start collecting the parts and do it all at once. Once back together take it in and have it aligned. It will feel like a new truck when your done.
66 shorty
donthekawguy is offline   Reply With Quote
Old 03-04-2014, 11:42 AM   #8
Indian113
Indian113's Avatar
I had a wandering problem but it was a belt slipping on my front tires of my S10. I had to buy 2 new tires and now it rides and drives like a new truck
Last edited by Indian113; 03-04-2014 at 11:42 AM. Reason: left out important information
Indian113 is offline   Reply With Quote
