Old 03-03-2014, 11:04 AM   #26
68post
Re: Spent a lot of money today
Originally Posted by Jonboy View Post
My '87 had a weird trans mount. I took the remnants of it to one of the box stores and matched it up.
'87 is a transition year and you get some old and some new body style parts.
68post is offline   Reply With Quote
Old 03-05-2014, 02:36 AM   #27
y5mgisi
Second Chance Program
y5mgisi's Avatar
Should run real nice!
90 Chevy Suburban 2500 5.3 swap/th400/np241/14bltSF/10blt.
77 C20 crew cab Silverado. 396/th400. In work.
y5mgisi is offline   Reply With Quote
Old 03-05-2014, 08:25 AM   #28
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
I'm too late. I was going to advise you to remove the intake and oil pan. Add a good bead of RTV to the corners and intake rear/front walls. It would save you oil leaks in the future. Using aircraft sealer on the bolts will also keep oil from creeping up onto the intake.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
Old 03-12-2014, 09:19 PM   #29
csdineley
csdineley's Avatar
It's alive, It's alive. Only took me a month, but it fired up on the first try. I'm hoping to finish up some little things tomorrow and be driving it Friday, Hopefully.
csdineley is offline   Reply With Quote
Old 03-13-2014, 05:22 AM   #30
Congrats!
Old 03-13-2014, 08:43 PM   #31
csdineley
csdineley's Avatar
Drove it a little tonight, Wow that thing has a lot more power then the old motor. But in 3rd and 4th gears (sm465), while giving it some gas. It sounds like something is chattering, maybe clutch. Kind of like a diesel flapper. I do know there is a small exhaust leak on the passenger side manifold gasket. Going to fix that tomorrow. Think I should pull the trans back out and double check it. Any thought?
Old 03-13-2014, 10:11 PM   #32
y5mgisi
y5mgisi's Avatar
Is it rhythmic? Or does it sound super random? If super random I would think it's pinging.
Old 03-14-2014, 05:02 PM   #33
csdineley
csdineley's Avatar
Only does it while accelerating in 3rd or 4 gears. Once I get to speed and let off it's fine. Today I talked with a mechanic buddy of mine. He suggested the u-joint. Which I did have a hard time getting it back in. So he might be on to something there.
