Old 03-05-2014, 09:59 PM   #1
71 super
71 super's Avatar
Need some help on set of bell tech spindles
The 67 I just picked up came with a complete front end rebuild kit- new upper lower ball joints, tie rods etc. also came with a set of bell tech spindles. Now to the problem, I bought inner and outer bearings and set of 5 lug rotors- re drilling them to 6 lug at work- bought a5 and a3 inner and outer bearings, the a5 s work without issue, the a3 are too small on the id. Is there a special bearing for these spindles? Also where can I get nuts and washers for spindles to hold bearings on?
67 blue step side- bb
68 gold and white swb cst anniversary
68 custom swb hot rod Ls swap
69 swb cst 6 cylinder/ overdrive
69 black/black cst bb swb
70 orange and white cst Canada built truck swb bb
71 black and white super swb bb
71 red and white super swb
72 green and white super swb 4x4
62 nova wagon 400 series Ls swapped
68 Camaro 327/4 speed- 1 owner, original paint
66 Volkswagen bettle
69 auto stick Volkswagen Beetle
71 super is offline   Reply With Quote
Old 03-05-2014, 10:56 PM   #2
mgchevyparts
mgchevyparts's Avatar
Re: Need some help on set of bell tech spindles
Often times there may be a slight burr on the spindle tip, usually where the groove is flycut for the tanged washer. Hit this area with a flat file and generally inspect the entire spindle end for any type of burr. unless you're saying the i.d. is way off.
1957 CHEVY 1/2 TON SHORT BED
1940 FORD 1/2 TON SHORT BED
mgchevyparts is offline   Reply With Quote
Old 03-05-2014, 11:24 PM   #3
leddzepp
Moderator
leddzepp's Avatar
Iirc bell tech spindles are a 3" drop as opposed to 2.5" like most others. If you are going to run 15" wheels you may have clearance issues. I know this isn't your question but it is something that might come up.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 03-06-2014, 11:52 PM   #4
71 super
71 super's Avatar
Got the bearing issue fixed, going to run 20" wheels so should be good. Thank you for the replies.
