Old 03-05-2014, 10:59 PM   #1
Motorhead-47
Motorhead-47's Avatar
Upper Radiator Hose # 454 w/serpentine belt?
I have a crate GM 454 Gen VI with the serpentine belt system in my 67' and I am hoping someone has "been there done that" and can give me a part number for a molded upper radiator hose that gives adequate clearance around the alternator and serpentine belt. What I have in there now works but has just slightly more than a gnat's azz of clearance. I think it is just a matter of time until something rubs.
Anyone?
1967 Shortbed Stepside - GM Crate 454HO 425HP/500 lb-ft, long tube Hedman ceramic coated headers, serpentine belt drive, Built 700R4, 12 bolt 3.42 with Eaton posi, 4 wheel disc brakes, OldAir A/C. 69' Corvette Lemans Blue. Painless Wiring Harness. Everything from the ground up is either new or rebuilt!
Motorhead-47 is offline   Reply With Quote
Old 03-05-2014, 11:17 PM   #2
diggerbob
diggerbob's Avatar
Re: Upper Radiator Hose # 454 w/serpentine belt?
I had a similar issue. I couldn't find a good fitting hose because the angles were wrong. I got a aluminum thermostat housing that swiveled. It gave me a few more options on hoses. Here is an example http://www.jegs.com/i/Billet-Special...90220/10002/-1
diggerbob is offline   Reply With Quote
Old 03-06-2014, 10:08 AM   #3
Lee H
Lee H's Avatar
I used a 45 degree swivel thermostat housing and the stock hose. Just takes a slight twist to get the hose to clear the belt.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 03-06-2014, 11:37 AM   #4
Motorhead-47
"Stock hose" for what application?
Old 03-06-2014, 11:49 AM   #5
Motorhead-47
What hose # did you end up with? Do you have any photos of the routing maybe?
Old 03-06-2014, 12:01 PM   #6
Fitz
Anyone?
Been there done that with a 90 degree bend in 1-1/2 stainless, two silicon tube elbows and a swivel thermostat housing.
Fitz is offline   Reply With Quote
Old 03-06-2014, 12:09 PM   #7
Motorhead-47
Good idea but I am trying to keep the underhood look somewhat "stock-ish" if you will and wanted to stay with a molded rubber hose.
Old 03-06-2014, 12:24 PM   #8
Fitz
You'll have an easier time finding chicken lips.
Old 03-06-2014, 12:29 PM   #9
Motorhead-47
That is why I came to the forum with the question...I have found lots of "chicken lips" in the search!
Old 03-06-2014, 02:23 PM   #10
kwmech
Not sure, but what about a t-stat housing off of an LS engine say an '02 with the hose that wraps around behind. (originally the ac on an LS)
Old 03-06-2014, 08:50 PM   #11
jeh
jeh's Avatar
I'm not sure it's going to stay this way but this is what I put on mine.
Jason
'70 C-10 short fleet 427BB TH400 (SOLD)
'10 Ford F 350
'13 Ford RAPTOR 6.2
MY BUILD THREAD http://www.67-72chevytrucks.com/vboa...d.php?t=612623
jeh is offline   Reply With Quote
Old 03-06-2014, 10:24 PM   #12
Motorhead-47
Very nice
