Old 03-03-2014, 08:06 PM   #1
Metalaroundstone
Question about OEM AC Condenser
I have a chance to buy a used OEM AC condenser and I was wondering if this would be as good as an aftermarket original style all aluminum replacement condenser, such as this one sold on ebay? The OEM would be cheaper, but I am not even sure what to ask the seller to ensure it is in workable condition.
http://www.ebay.com/itm/1964-1965-19...-/230911144599
Metalaroundstone is offline   Reply With Quote
Old 03-03-2014, 08:29 PM   #2
LT1 Burb
LT1 Burb's Avatar
Re: Question about OEM AC Condenser
There is no way to tell if it is in working condition until you flush it and pull a vacuum on it to see if it leaks. If this aftermarket one is very close to original than I will use one, if not I will use the OEM one I have.
LT1 Burb is offline   Reply With Quote
Old 03-06-2014, 11:19 AM   #3
Metalaroundstone
Since I can't really check out the used one before buying it, it sounds like it could be risky. Thanks
Old 03-06-2014, 12:02 PM   #4
LT1 Burb
LT1 Burb's Avatar
If your not doing a factory correct resto than yoyu can use whatever fits. With 134A refrigerant the bigger the condenser the better, the one in my suburban I believe is a mid 90's cavalier from Carquest.
Old 03-06-2014, 12:05 PM   #5
Metalaroundstone
I have another question about an AC condenser. Would the parallel flow condenser shown here be more efficient than the OEM condenser on my 66? Has anybody used this product?
Old 03-06-2014, 12:50 PM   #6
61K10
61K10's Avatar
the e-bay one says new--re-pop like the org?
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 03-06-2014, 01:30 PM   #7
Metalaroundstone
You're right. Not a OEM. The ebay one is also all aluminum made to same size and shape of original. Would this be better than OEM?
Old 03-06-2014, 01:41 PM   #8
grs
Call Old Air Products, and ask them about there's.
grs is offline   Reply With Quote
Old 03-06-2014, 03:54 PM   #9
Metalaroundstone
Did you have to do much retrofitting, hole drilling, cutting etc. to make the cavalier condenser fit?
Old 03-06-2014, 04:01 PM   #10
LT1 Burb
LT1 Burb's Avatar
No, just made some brackets for it, the important thing with 134A is condenser surface area , the more the better. The new condenser design is better than the old 60's design.
