03-06-2014, 04:03 PM | #1 |
Tilt column problems
The tilt column I got with the truck I bought was not installed yet.It looks like it's rebuilt and very good shape.I notice it does not have a tang that sticks up to make the back up switch work? There is a slot there but no tang, the blow up diagram in my service manual doesn't show a back up switch on the column.any one have ideas? Thanks so much with your help with my problems,this web site is great!
03-06-2014, 06:35 PM | #2 |
member #16
Re: Tilt column problems
If you have a converted van column, they use a different switch than the truck they fit into a slot rather than over a tang.
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors http://www.flickr.com/photos/1745471...7602865984234/ |
03-06-2014, 08:03 PM | #3 |
How long is shaft coming out bottom of column. That's a give away also.
03-06-2014, 08:03 PM | #4 |
Thanks .. Any idea where I could get a back up switch for van column?
03-06-2014, 08:18 PM | #5 |
Most van columns have the switch in the wrong location. The switch needs to be in the truck switch location which is about 8" from the lower end of the
column. You may want to check the location of the switch on your tilt. Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
03-06-2014, 08:38 PM | #6 |
Post some pictures of your column on here, we can tell you exactly what you have.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
03-07-2014, 12:46 AM | #7 |
Scribed
1967custom |
