Old 03-08-2014, 06:48 PM   #1
Iceburgh
Iceburgh's Avatar
Fuel tank/pump
Guys need some help.
Here is the tank I have.
The motor is a LS3 465 hp.
Should I use a external pump? If so which one. I have something similar now on a 383 with aftermarket injection with no return line and no issues
Or internal....I don't know anything about internal is there a kit that I cut the tank and mount? Not sure how the pump stands up in the tank.
What about flow rate?
Thanks in advance
Iceburgh is offline   Reply With Quote
Old 03-08-2014, 07:31 PM   #2
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Fuel tank/pump
Yes you will have to cut the tank if you want a internal pump. Does this tank have the baffels? If not you may want to stick to the inline pump. You don't want to starve the internal pump for gas when low on fuel.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 03-08-2014, 10:08 PM   #3
Big Port Jimmy 6
Addicted to Rust
Big Port Jimmy 6's Avatar
Re: Fuel tank/pump
You need one of these, Call Doc and he will send one out. Tell him Jay said to call. Just a hole saw cut away from an in tank pump.
http://docskustom.com/shop/viewitem.php?productid=486
Current trucks:
(48 GMC100 320 inliner) Gone
(48 Suburban in pieces) Sold
87 GMC CCSB 5.3 4l60E Daily Driver
ECTA National record holder XO/PP
We never really grow up, we just learn how to act in public.
Big Port Jimmy 6 is offline   Reply With Quote
Old 03-09-2014, 02:00 AM   #4
Andy4639
Old member
Andy4639's Avatar
Wink Re: Fuel tank/pump
That would work just fine. I like the internal pump much better than the inline pumps. Just my opinion though!
Old 03-09-2014, 04:45 AM   #5
BigDan3131
BigDan3131's Avatar
Re: Fuel tank/pump
The other internal option is this one: http://www.summitracing.com/search/b...s?autoview=SKU .
Its more money but its a known name brand that can support almost anything you can throw at it.
Custom Painter/Restoration Specialist
1965 GMC 3/4 Ton LB SOLD?
1964 Chevy El Camino in full restoration
1991 Chevy S10 288K+ miles 2nd Owner SOLD
2020 RAM 1500 Warlock
BigDan3131 is offline   Reply With Quote
Old 03-09-2014, 03:21 PM   #6
Iceburgh
Iceburgh's Avatar
Re: Fuel tank/pump
thanks for the reply's. Some of this is nice but to rich for what I am doing
Old 03-10-2014, 02:43 AM   #7
woodwright
Enjoying left field
woodwright's Avatar
Re: Fuel tank/pump
There is an OEM option. When GM started using plastic tanks, they went with a fuel pump module so they wouldn't need baffles. Basically the pump sits in a cup that is held on the bottom by springs. They come in different heights depending on the depth of the tank. For example, I found one from an 02 Silverado. The module is 15" tall, but it compresses down to 12". And there are others that are shorter. You can find new modules on ebay for less than $100, or look in your local wrecking yards.
Clint
70 Chevy 4WD "Ultimate Work Truck" SOLD
woodwright is offline   Reply With Quote
