Old 03-08-2014, 07:41 PM   #1
Andy4639
Old member
Andy4639's Avatar
Talking Sound deadener
I finished up the passengerside floor today with the sound deadener. Started at the fire wall right up against the AC box and went all the way back to the cab wall and corner of the cab. I did the back wall of the cab and doors several months ago. I ran out of material so I have to get more Monday. I hope all this is worth it. I'm going to try and get the drivers side done next week while I'm off.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 03-08-2014, 09:10 PM   #2
vidman
vidman's Avatar
Re: Sound deadener
Going to be installing a vintage air system sometime soon, was wondering should I install my sound deadener now on the firewall. (Cab is bare right now) Didn,t know if it would make the VA install harder with the mat all ready on. didn,t want to start taking any of it off after its on..
62 Willys 4wd Pickup : 72 C-10 swb 504 stroker 09 Taco 3" lift 33" tires: 90 K-5 blazer (plow truck): RIP Ross Little brother
vidman is offline   Reply With Quote
Old 03-08-2014, 09:25 PM   #3
Andy4639
Old member
Andy4639's Avatar
Question Re: Sound deadener
I wouldn't install it under the box. Not much point I wouldn't think. Not sure how it would do inside there either. It would stay moist I would think all the time.
Old 03-08-2014, 09:33 PM   #4
Z10
Z10's Avatar
Re: Sound deadener
Originally Posted by vidman View Post
Going to be installing a vintage air system sometime soon, was wondering should I install my sound deadener now on the firewall. (Cab is bare right now) Didn,t know if it would make the VA install harder with the mat all ready on. didm,t want to start taking any of it off after its on..
I did mine before I installed the sound deadener and insulation. Much easier to do with it not installed. Click on my build thread below in my signature for pics and description.
I still need to do my doors but, along with new door seals, it's done a lot to lesson the noise.
1969 RS/SS Z10 Camaro Pace coupe
1972 GMC Short Step buildhttp://67-72chevytrucks.com/vboard/s...=1#post6356218
1979 Mazda RX7
1979 Pontiac Trans Am WS6 & 1979 Pontiac Trans Am 10th Anniversary
1999 Honda Valkyrie
2006 Corvette Z06
2010 BMW 650i
Z10 is offline   Reply With Quote
Old 03-08-2014, 10:07 PM   #5
Andy4639
Old member
Andy4639's Avatar
Can you really tell a differance in the sound inside the truck. I know installing the deadner in my doors made a differance as far as when I shut them now. Its a thud and not like a rattle.
What is this for? What is the purpose of it?
Old 03-08-2014, 11:08 PM   #6
Z10
Z10's Avatar
Re: Sound deadener
What you are looking at is MLV. Mass Load Vinyl. From what I've read, sounding should be looked at as a system. What I did first, was do use a dynamat type material with about 35% coverage, directly on the floor, toe board, and firewall, then the rear of the cab. This material does not have to completely cover, it their to primarily reduce/eliminate harmonic vibration which creates noise. This was followed by using a two sided aluminized closed cell foam material, which I used to completely cover everything I could reach. This is to cut down primarily heat/cold transfer. It's easy to work with. This is followed by MLV which is weighs about 1lb per sq.ft. It's very dense and very heavy. This material is used for sound proofing home theaters. It will reduce noise migration. It's stiff and doesn't like to bend in multiple directions, so I ended up using as few pieces as possible. This was place on top of the aluminized material. Of course I followed that with carpet padding and then carpet. So in my case it's a 5 layer system.
If you'll google search MLV, you'll find several articles on the subject.
Glad to hear that your doors sound much better. I still need to tackle my doors.
1979 Mazda RX7
1999 Honda Valkyrie
2006 Corvette Z06
2010 BMW 650i
Old 03-09-2014, 12:22 AM   #7
Andy4639
Old member
Andy4639's Avatar
Cool Re: Sound deadener
Thanks for the heads up. I remember reading on the Audio section about it now. I will have to check on it. I used fat mat and the bulbble wrap stuff and carpet so far I may do the MLV stuff as well.
I wear hearing aids so any unwanted noise I can cut out will be nice!
Old 03-09-2014, 06:41 AM   #8
Jb70c10
Re: Sound deadener
Please explain and or show pics of how you do your doors
Jb70c10 is offline   Reply With Quote
Old 03-09-2014, 01:22 PM   #9
Andy4639
Old member
Andy4639's Avatar
Wink Re: Sound deadener
I did as the local Stereo guy told me to do it.
I cut a 12"x12" peice to go in center of door then 4 peices 6"x6" and put in each corner of the door as close to the corner as I could reach them. I also put a strip along the bottom on the inside skin of the door.
Here is the link to how and what I used.
http://67-72chevytrucks.com/vboard/s...d.php?t=605236
Old 03-09-2014, 08:11 PM   #10
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Sound deadener
Here are a couple of pictures I snapped before work tonight. Deadner then bubble wrap then carpet.
Road Kill.
Bubble wrap.
Carpet.
Old 03-09-2014, 09:06 PM   #11
Jb70c10
Re: Sound deadener
Thanks for the info! BTW, nice truck Andy!
Old 03-09-2014, 09:13 PM   #12
71 super
71 super's Avatar
Re: Sound deadener
Also put some in the "b" pillars and in gap behind dome light. Also reach as high as possible into bedsides and put 12x12 sheet in area before and after wheel. Doors and floor make difference but these other make it even better.
67 blue step side- bb
68 gold and white swb cst anniversary
68 custom swb hot rod Ls swap
69 swb cst 6 cylinder/ overdrive
69 black/black cst bb swb
70 orange and white cst Canada built truck swb bb
71 black and white super swb bb
71 red and white super swb
72 green and white super swb 4x4
62 nova wagon 400 series Ls swapped
68 Camaro 327/4 speed- 1 owner, original paint
66 Volkswagen bettle
69 auto stick Volkswagen Beetle
71 super is offline   Reply With Quote
Old 03-09-2014, 10:38 PM   #13
Andy4639
Old member
Andy4639's Avatar
Thanks, I try!
71 super
I can't see why you would do this. Help me understand why you would install it on the inside bed walls when it's seprate from the cab.
Old 03-09-2014, 10:49 PM   #14
Andy4639
Old member
Andy4639's Avatar
Thanks, I try!
71 super
