#51 |
![]() Join Date: Oct 2012
Re: Thoughts on tuning engines
deleted
#52 |
deleted
#53 |
deleted
#54 |
deleted
#55 |
I actually have a 292 waiting to find its' way into my 1951 International panel truck. This one ain't gonna be j.a.f.s.b.
#56 |
![]() Join Date: Jan 2011
Hey you can ignore list me if you want but I trying to get you to think this deal out before you kill engine number 2. There are practical limits to timing and todays fuel and just because you can't here it pining does not mean it isn't. You have a couple of unknowns in your combination and the first one is the compression and the shape of the piston. You have a good tach and a timing light and can plot your timing curve and a vacuum gauge to show you when the engine is adding timing. You also know how you drive and what the rpm is where you run the most. Look at the timing at this rpm and vavuum level and that is the number you need. If you have to ad a lot of extra initial to get it to run well in that rpm range but have to much total that is beating on the engine at times then what is needed is a quicker curve to get the timing in sooner to give you what you need with out the high total and it's ill effects. Changing the springs and or weights in the distributor is what will fix that issue. High initial makes em hard to start and builds extra heat at idle that this time of year is not an issue but come August you may find it a problem. You now have a good feel for what your truck needs to run well as far as timing for the way you drive. Now please just take the time to learn how to fit a curve to this HEI you have to give you a a safe spot at both ends and the numbers you need in the middle. Here is a link to how this works.http://www.msdignition.com/instructi...pdf?terms=8428 Some good reading on working with the curve. http://www.pontiacstreetperformance....distcurve.html
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
#57 | |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
