Old 12-29-2003, 02:10 PM   #1
Low69CST
Will my guage handle it?
I started my truck up for the first time with the original guagues in it. My oil pressure guaged was pegged as far as it could go. I've got a built 400 sb. with a high volume and pressure oil pump in it. My concern is that my factory guage won't be able to handle the pressure since it was already close to being pegged just lettin the motor idle. A burst oil guage would definately hurt my feelins and my new interior. Anybody else had a problem?
'69 CST Short fleetside
Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress)
'87 V10 4x4 Short Fleetside
Quad Suspension and Dual Tanks
Low69CST is offline   Reply With Quote
Old 12-29-2003, 02:19 PM   #2
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
My toyota run's 65 hot and the guage is pegged when cold (10 w 30) auto guage BTW
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 12-29-2003, 02:29 PM   #3
JimKshortstep4x4
Talking
I would be concerned about the gauge since it is probably a 60 psi gauge.
Try hooking up a 100 psi gauge to see what the actual pressure is. I believe that 80 psi gauges are available and that might do it for you.
Jim
Old 12-29-2003, 06:43 PM   #4
cableguy0
that pump is probably putting out 80 psi most do and they have a pressure release at 80 but if it was me i would change the gauges to autometers with a 100psi oil guage
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 12-29-2003, 06:46 PM   #5
67Fleetsidedream
Wiseass secured himself a BAN
67Fleetsidedream's Avatar
I would change to an aftermarket gauge also.
67Fleetsidedream is offline   Reply With Quote
Old 12-29-2003, 07:52 PM   #6
500HP/SB
please don't break
500HP/SB's Avatar
haha i have the same problem. i have a built 350 and at idle it's pegged and as it comes up off idle it goes off the chart. probly ought to fix that
70 k10 35s 350/sm465/np205
titanspeed.com
500HP/SB is offline   Reply With Quote
Old 12-29-2003, 09:36 PM   #7
rage'nrat638
rage'nrat638's Avatar
same here.....
but were driving chevy's not fords......
most parts are good for double the working pressure......
mine come's off the the high side once it's warmed up
IT'S ONLY MONEY......
rage'nrat638 is offline   Reply With Quote
