Old 03-12-2014, 07:45 PM   #1
JacobSchni
JacobSchni's Avatar
Engine ID troubles
I recently bought a 1983 Chevy k10 with a supposed crate 350. He has no paperwork but it looks and sounds new. I am trying to get the identification codes but i cant see the rear driver side code(too far in back), and the head is covering the other id code on the passenger side front code. Where can i find codes to identify exactly what i have?
JacobSchni is offline   Reply With Quote
Old 03-12-2014, 09:42 PM   #2
russgt
russgt's Avatar
Re: Engine ID troubles
Loosen up the alternator and move it out of the way to see the suffix code, crawl up on top of the motor and use a flash light to see the casting numbers on the top of the bell housing on the drivers side.
70 stepside
76 blazer
86 Sierra Classic
20 Max Trailering 6.2 Crew
71 Nova SS
My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=363634
russgt is offline   Reply With Quote
Old 03-12-2014, 10:36 PM   #3
JacobSchni
JacobSchni's Avatar
i can try to climb up but its a real cluster f*** with wires, and isnt the suffix code right infront of the head, because im almost positive thier is nothing protruding past the head it sits flush with the block. Ill double check tommorrow or somthing
Old 03-13-2014, 08:57 AM   #4
MylilBowTie
Right turn Clyde
MylilBowTie's Avatar
If I'm not mistaken crate engines don't have suffix codes. They should have a casting number though on drivers side bellhousing flange.
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73
1992 Camaro RS 305 TBI
MylilBowTie is offline   Reply With Quote
