Old 03-13-2014, 09:22 AM   #1
Claytona08
Claytona08's Avatar
Speedo and Odo quit working
I need some help here. My speedometer and my odometer quit working. It was working good but when I got it back from the paint shop it's not working anymore. I climbed under the truck and checked to see if it was still hooked to the transmission and also check to make sure it was still hooked up to the dash. Everything was hooked up but it doesn't work. Any thoughts????
http://67-72chevytrucks.com/vboard/s...d.php?t=580955
http://youtu.be/JYoQJYTXKqI
1984 Chevrolet Scottsdale C10 "Project Platinum C10"
1971 Chevrolet Chevelle "Project Car"
Claytona08 is offline   Reply With Quote
Old 03-13-2014, 10:00 AM   #2
Bishops Trucks
KEEP ON TRUCKIN'
Bishops Trucks's Avatar
Re: Speedo and Odo quit working
Unhook it at the trans, pull the cable out of the sleeve and see if it is broke in half. That's a starting point.
JIM
'97 GMC Sierra K1500
'95 Chevy Silverado C1500
'71 Cheyenne Z71 / LT1 & 4-Speed SWB K/10 Father/Son Project
http://www.youtube.com/watch?v=4l689JKXPnA
http://67-72chevytrucks.com/vboard/payments.php
"LIVIN' FREE FOREVER"
Bishops Trucks is offline   Reply With Quote
Old 03-13-2014, 02:58 PM   #3
Claytona08
Claytona08's Avatar
Do I need to unhook it from the back of the cluster first?
Old 03-14-2014, 06:10 AM   #4
Bishops Trucks
KEEP ON TRUCKIN'
No, you should be able to unhook from the trans, grab the end of the cable and pull it out. If it's not broke, slide it back in, you may need to spin it a little bit to get it to slide back in the cluster.
JIM
Old 03-14-2014, 07:31 AM   #5
motornut
78K & 79C Jimmys
motornut's Avatar
I would,just to make sure it's in far enough,and before putting back in.
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
Old 03-14-2014, 09:26 AM   #6
Ski-me
Ski-me's Avatar
I thought you had it pull the cable out from the other end (at cluster). I didn't think you could pull it the other way.
You could unscrew the tranny connection and put the cable end on a drill. Slowly turn it and see if the speedo moves (need 2 people).
Make sure the cable connection is fully seated onto the cluster. Sometimes it doesn't get all the way pushed in.
- Jeff
89' K5 Blazer, 2.5" lift, 35" tires
04' GMC Yukon XL, 3/4 ton, 8.1L
Ski-me is offline   Reply With Quote
Old 03-14-2014, 02:05 PM   #7
Claytona08
Claytona08's Avatar
Do I need to have my dash out for this or can I remove the bezel and cluster with the dash installed?
Old 03-14-2014, 02:13 PM   #8
SeTx67
SeTx67's Avatar
If the cable is broke you can have mine if you don't mind waiting for me to get back home in a few weeks
SeTx67 is offline   Reply With Quote
Old 03-14-2014, 02:26 PM   #9
Claytona08
Claytona08's Avatar
That'll work Tim. I don't need the speedo to work to drive it around town.
Old 03-14-2014, 02:48 PM   #10
Ski-me
Ski-me's Avatar
Unfortunately, yes you'll have to remove the dash, instrment bezel and then cluster to get to the cable. I'd first try just disconnecting from tranny and spinning it. That's a 3 minute job. Going into the dash....probably an hour job (I've done it several times!!)
- Jeff
Old 03-14-2014, 03:31 PM   #11
Claytona08
Claytona08's Avatar
I'll unhook it and spin the cable. Luckily I already have the bezel and dash out of the truck but was planning on putting it in this evening. Looks like I better leave it out.
Old 03-15-2014, 01:02 AM   #12
Claytona08
Claytona08's Avatar
Well I found my problem. Easy fix!
Old 03-15-2014, 09:38 PM   #13
Claytona08
Claytona08's Avatar
Got the cable replaced today. Cost me $ 6.99 and took about 3 minutes to replace it. Thanks for your help guys.
