03-16-2014, 01:47 AM | #376 |
Re: What did you do to your truck today? Chapter II
Got my new coolant hoses installed, along with a new thermostat, and outlet. Pulled the old exhaust off the manifolds, and fired it up. Open rams horns are LOUD!!
Managed to get the old mufflers cut off the pipe I am reusing, and got the driver side ready to weld up to the muffler before the thunderstorms hit. Since I was using my buddies welder (and he took it home with him), I will be taking a different approach to finishing the exhaust. Instead of welding (too easy to burn through), I will fall back on my old technique, and braze it together with a torch and wire. Hoping to make more progress next time I have a day or so off work.
Grunt: 1971 C20 Custom Camper. Runs/Drives/Kinda stops. 350Ci, TH350. 4.10:1 D60. Eight Lug LWB is more better. Hell no its not fast! Donkey: 93 Nissan D21, the farm truck. My 1/2 ton SWB. The Indomitable Datsun. 1st BN 3rd MAR. '00-'04 |
03-16-2014, 04:42 PM | #377 |
I got the right rear cab corner and right outer rocker welded on today. I'm done welding, finally.
03-16-2014, 09:47 PM | #378 |
03-16-2014, 10:32 PM | #379 |
Pulled the grill trims off my truck to polish up and replace a few broken clips.
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop |
03-16-2014, 10:58 PM | #380 |
off to finish body work and get some paint on her
Doc & Kim build http://67-72chevytrucks.com/vboard/s...d.php?t=722288 I am from the desert http://67-72chevytrucks.com/vboard/s...d.php?t=650332 basket case build SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=648557 |
03-16-2014, 11:00 PM | #381 |
her ride
03-16-2014, 11:59 PM | #382 |
03-17-2014, 12:12 AM | #383 |
tcoop68
Replaced ,rotors bearings calipers pads coil springs upper and lower ball joints , upper and lower a arm pivot rods, basically rebuilt the front end on my 72 sw.
03-17-2014, 12:15 AM | #384 |
tcoop68
Do you have to use a different motor mounts when you put a late model in , just wondering, if so where can you get them.
03-17-2014, 12:20 AM | #385 |
RAT1968 '68 Cab/'71 Parts
Pulled (rolled up) the tonneau, stashed the "bows", and drove the 20 mile round trip to collect 18- 8 ft. 1-1/2" boards,
2- 10' 2 x 10's, 2- 8' 2 x10's, and three rolls of wire for the next round of squirrel fighting/gardening. The Boss () bought lunch, watched the garden supplies on the way home, and helped extract them from the bed without a scratch (on the bed) when we got to Casa de Magwa. On the trip, three people asked me the year of the truck. The guys at the lumber yard were respectful of my wanting to be careful loading.
M17 Coarsegold, CA RAT's shiny now. But always a rat. |
03-17-2014, 12:23 AM | #386 | |
http://www.earlyclassic.com/catalog....ry=New%20Items |
03-17-2014, 12:28 AM | #387 |
Finished cleaning up the cab and got it all sealed up in PPG DP-90LF.
Check out my build thread http://67-72chevytrucks.com/vboard/s...d.php?t=606231 |
03-17-2014, 12:29 AM | #388 |
tcoop68
03-17-2014, 12:42 AM | #389 |
03-17-2014, 05:52 AM | #390 |
Installed core support filler panel. I had to make an opening for the A/C and re-paint it with SEM hot rod black. It looks really good and cleans up the engine bay.
03-17-2014, 07:39 AM | #391 |
Put my Radio, Dash Speaker, Hidden Antenna, Glove box Door and Liner in. Beautiful day on Satuday - 73 degrees. Also got lots of wiring done, Been a long build, but slow and steady wins the race....
Thanks, Casey 71 Chevy C-10 SWB 350/400 PS, PB The Build http://67-72chevytrucks.com/vboard/s...d.php?t=584045 The Brake Upgrade http://67-72chevytrucks.com/vboard/s...d.php?t=695699 |
03-17-2014, 07:41 AM | #392 | |
03-17-2014, 07:43 AM | #393 |
I purchased the same kit and it has been wonderful to install, not complicated.
03-17-2014, 09:07 AM | #394 |
What did you do for a hidden antenna? I have to install one myself shortly.
03-17-2014, 09:44 AM | #395 |
They have a hidden antenna that sticks under dash and plugs in the back of the radio as always, then you hook up the pwr antenna lead to it for power. Not sure about reception yet, but we'll see.
03-17-2014, 11:18 AM | #396 |
Where did you get your radio from & is it the USA-230?
"Now all I need is a shop to go with my shop vac!" Last edited by texjake; 03-17-2014 at 11:25 AM. |
03-17-2014, 11:35 AM | #397 |
I've just keep taking parts off and painting. I'm really wanting a sand blaster as I'm awfully tired of sanding only to find its not perfect. I'm also just awfully tired of sanding.
Ryan 1967 Red Stepside..."Laymond" http://67-72chevytrucks.com/vboard/s...40#post6441840 1972 Medium Olive SWB-Chester http://67-72chevytrucks.com/vboard/s...d.php?t=759628 1967/71 Blue SWB C10..SOLD 1977 SWB K10..my grandpa's.....never should have sold |
03-17-2014, 12:35 PM | #398 |
Yes its the 230. I got it from Classic Car Stereos.com It's the am/fm radio with ipod port. The knobs came with it and it looks pretty stock.
03-18-2014, 01:33 PM | #399 |
Last night I came up with an idea of how to remove, store, and reattach my custom bed cover and fix it so that it's a one man job!
I just now paid for the grill guard....the latest of neat things my truck doesn't need to regain the road but will be cool to have when she does! |
03-18-2014, 02:17 PM | #400 |
Installed pinion angle shims...1.5 deg.
1970 C10 Short Stepper with 71/72 front clip. |
