Old 03-17-2014, 12:30 PM   #1
asianmario1
22" on 1969 c10
I have a 1969 c10. I just got 22x9.5 with a +12 mm offset. I have to add a 1" spacer on the back. My question is what would be the best tires to put on all the way around. I heard 265/35/22 but want to make sure before I buy them.
asianmario1 is offline   Reply With Quote
Old 03-17-2014, 01:37 PM   #2
Rusbuilt
Rusbuilt's Avatar
Re: 22" on 1969 c10
I have 265/35/22 on my 68
Rusbuilt is offline   Reply With Quote
Old 03-17-2014, 01:37 PM   #3
Rusbuilt
Rusbuilt's Avatar
Re: 22" on 1969 c10
Welcome to the board btw!!
Old 03-17-2014, 01:41 PM   #4
Famous Tater
Famous Tater's Avatar
Re: 22" on 1969 c10
Welcome!!
I have 265/35/22s on front 22x8.5" with 6.25 bs and 285/35/22s on back with 22x10" with 5.5 bs. Fit great!
Famous Tater is offline   Reply With Quote
Old 03-21-2014, 08:26 AM   #5
asianmario1
Re: 22" on 1969 c10
Originally Posted by Famous Tater View Post
Welcome!!
what kind on drop do you have on your truck.
Old 04-05-2014, 06:49 PM   #6
AZBIG1
Re: 22" on 1969 c10
305-40-22s on 22 by 10s. 6 inch back spacing. 2" rear spacers.
AZBIG1 is offline   Reply With Quote
Old 04-07-2014, 09:20 AM   #7
Famous Tater
Re: 22" on 1969 c10
Hey bud...
My truck was actually dropped "as-it-is" when I got it. As for the actual amount of drop, I am really not sure?? Right now, front is 30 3/4" from ground to fender lip with 2" of clearance above top of the tire. Rear is 32 1/2" from ground to fender lip with 3" of clearance above thew top of the tire.
The only reason I have not droped it more is because I have been on the fence for the last month as to whether I want to spend the money and do air or whether to just static drop (which would probably be just a 2.5" dropped spindle and using the spring that I already have on the truck and then doing a 4 or 5" spring in back with or without a block?? Little harder to decide what to install when you truly do not know the current amount of drop. Would suck to buy coils and find out the truck sits the same as it did to start with!
Everytime I look at this pic that a fellow member did of my truck, it sit real hard to NOT want to install air!!
