Old 03-18-2014, 09:25 PM   #1
1970 C10 MJW
1970 C10 MJW's Avatar
shifter
im wondering what you guys are doing as far as being able to shift the 4l60e or 4l80e with the factory steering column shifter, i have no room for the linkage system that was there for the th350 because of my long tube camaro 98-02 headers
70 C10 working on a LSx swap
4.8L MS3 edelbrock pro flo intake, pacesetter long tubes, 4l60e 2500 stall hoping the tranny holds up lol
1970 C10 MJW is offline   Reply With Quote
Old 03-18-2014, 11:32 PM   #2
kevmac
kevmac's Avatar
Re: shifter
gonna use the lokar 1804 cable this week, i'll try to report back on how it goes
kevmac is offline   Reply With Quote
Old 03-19-2014, 08:41 AM   #3
Jmiller022
Jmiller022's Avatar
Re: shifter
I am interested to hear this as well. because I am about to install some 98-02 headers.
68' c10 stepper 5.3/4L60e
Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=578917
Jmiller022 is offline   Reply With Quote
Old 03-19-2014, 09:48 AM   #4
JJH Jimmy
JJH Jimmy's Avatar
Re: shifter
I used the Lokar ACA-1800. I had to bend a new rod for it, but it works good.
1972 GMC Jimmy 4x4 LS Swap
1985 Chevy K20
1994 GMC Yukon
2021 GMC 2500HD Duramax AT4
My "It's a Jimmy Thing" Build
http://67-72chevytrucks.com/vboard/s...d.php?t=583528
Budget Build 1985 K20
http://67-72chevytrucks.com/vboard/s...d.php?t=801565
JJH Jimmy is offline   Reply With Quote
Old 03-23-2014, 08:06 PM   #5
1970 C10 MJW
Re: shifter
jimmy how well does that linkage make the gear indicator line up?
Old 03-23-2014, 08:36 PM   #6
JJH Jimmy
JJH Jimmy's Avatar
Re: shifter
I am using a stock tilt column and I originally bought one of the gear indicator lenses that have the extra overdrive spot, but I could not get it to line up right. The reverse is to close to the park. I know some guys say they got it to work but i got tired of trying. So I used the original lenses and got the pointer lined up perfectly on park, reverse, neutral and drive (overdrive). It is only slightly off on 1, 2 and 3. When you put it in 1st it is just under the 1.
Three rod that came with the Lokar kit was too short. I bought some 5/16" stainless steel rod and bent it to fit. I also threaded both ends because I did not like the set screws that Lokar uses on the transmission side.
1985 Chevy K20
1994 GMC Yukon
Old 03-25-2014, 07:21 PM   #7
mooseknuckles
mooseknuckles's Avatar
Re: shifter
I used the lokar 1800 as well and the indicator in the dash was messed up too...never did get it to line up right.
mooseknuckles is offline   Reply With Quote
Old 03-25-2014, 07:39 PM   #8
ls1nova71
ls1nova71's Avatar
Re: shifter
The shift detent that is inside the column is different from a 3 speed automatic to a 4 speed automatic, so you will likely never get it perfect, but you can usually get from park to overdrive to line up right, which is what most people use 90% of the time anyway.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 03-25-2014, 07:58 PM   #9
mooseknuckles
Re: shifter
mine was originally a 700r4. always seemed like it was off half a cog..
