Closed Thread
Old 03-18-2014, 10:29 PM   #1
runamukrancher
Re: 62 C-10 screwdriver start
.... and a few weeks later, here's what the problem was (and still is):
Neutral safety switch located at bottom on steering column! I had the local shop look at it, very busy little place. Had to get truck towed in, the screw driver start wasn't working. after a week he says it's good to go, no charge, just adjusted the NSS. OK! so I bring a large box of dog bones for his shop dog and truck is running; home I go. Headed out a few hours later, turn key and NOTHING. lights on, no crank, exact same problem. so i shift thru all gears eventually it will start in Neutral. (with hand brake on) the trick here is when I park the truck, while it is still running, I shift into N, handbrake on, cut motor. That's the best chance to have it "set" to start again. crazy!
so it wasn't the solenoid, or the starter or any electrical connection by the fire wall, all great suggestions. I'm not happy about it all but hey all it cost to find this out was dog bones. The NSS I had replaced 3+ yrs ago forgot all about it - is this just a touch and (maybe) go sort of thing, just knock it around and get it right that way? Would be nice to start my truck in *Park* someday! Thanks for any and all info.
runamukrancher is offline
Old 03-19-2014, 08:34 AM   #2
tincan1966
tincan1966's Avatar
Why not just replace the NSS? Or get it adjusted to work properly in park.
tincan1966 is offline
Old 03-19-2014, 10:52 AM   #3
chevy_mike
Never Ending Projects
chevy_mike's Avatar
You have another thread going, this one will be closed.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline
Closed Thread
