Old 03-19-2014, 02:19 PM   #1
muffintop
87 burb wiring demons
So i finally got the burb running that has been siting for about a year now. but she has some demons.
maybe some of you guys might know what is cross-wired or has been damaged. but here we go
i can turn the truck on, but it wont turn off. my dad actually installed a cut power switch to the distributor so we can turn it off.
next problem... when i want to use brake lights/ turn signals, i need to pull out the running lights or go full lights. the brake lights will not work if i push the light switch all the way in.
secondly, the motor seems to idling a little fast. but im going to check the timing.
all this has stemmed after some red neck mechanic installed a new distributor for us. initially they bent the distributor cap metal fins when installing the wire harness. which had to be redone.
thanks for the help guys.
muffintop is offline   Reply With Quote
