Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > Vendors Marketplace
Closed Thread
Old 03-19-2014, 07:41 PM   #1
Pacific Fabrication
Pacific Fabrication's Avatar
Lowest Price LS3 Ready To Run Package Available!!!
Tilden Motorsports is proud to announce the release of their new 6.2L LS3 engine package! Priced at $8636, this is as low as it gets for all brand new parts and a full 3 year 36k mile warranty. When combined with long tube headers and a free flowing intake, this engine stamps out 475 horsepower and 425 lbf-ft torque that will surely out perform the competition!
These engines come with everything you need to make swapping one in your ride of choice a breeze.
For $8636 you will receive the following:
  • 475 hp GM Performance crate engine
  • New standalone engine harness
    • Our harness contains any fuses and relays that will be needed. There is no main power feed required for this harness, just a single switched ignition power will switch a relay in the harness that in turn, supplies 12V power to all of the required engine sensors and the ECU. We use weather pack connectors on all engine connections as well as a weather tight fuse block to ensure that connections are protected from the elements. All of our harnesses come with an easily accessible DLC (Data Link Connector) that is usually long enough to be mounted in the passenger compartment. This allows for easy access to the ECU via a laptop or standard scan tool.
  • Pre-flashed GM PCM
    • We supply all of our engine packages with a genuine GM factory computer. The GM factory computer, unlike our competitors’ marine style computer, is fully supported by any GM repair facility. GM has invested thousands of hours of research and development time into perfecting their computer technology. Many aftermarket companies try and duplicate the factory computer with "cheaper" components that often fail prematurely. Because of this the aftermarket computers just can't compare to a GM factory computer.
  • Corvette style accessory drive
    • Complete with alternator, starter, power steering pump, idler pulley, tensioner, ac pump, mass airflow sensor with housing to simplify your installation, all required accessory brackets, hardware, and belts.
Pacific Fabrication is offline
Old 03-24-2014, 05:00 PM   #2
Pacific Fabrication
Re: Lowest Price LS3 Ready To Run Package Available!!!
Old 04-02-2014, 03:52 PM   #3
Pacific Fabrication
Thanks for the orders!
Old 04-22-2014, 01:54 PM   #4
Pacific Fabrication
Have a question? Don't hesitate to ask!
Old 04-29-2014, 07:39 PM   #5
Pacific Fabrication
Old 06-23-2014, 02:57 PM   #6
Pacific Fabrication
The best value LS3 package anywhere!
Old 07-14-2014, 02:48 PM   #7
Pacific Fabrication
Old 07-23-2014, 04:47 PM   #8
Pacific Fabrication
Call Today!
Old 08-14-2014, 07:37 PM   #9
Pacific Fabrication
Old 10-15-2014, 02:47 PM   #10
Pacific Fabrication
Old 11-14-2014, 06:09 PM   #11
Pacific Fabrication
Thanks for the orders and don't forget to check us out on the latest episode of Dirt Every Day!
Dirt Every Day
Old 11-19-2014, 03:45 PM   #12
Pacific Fabrication
Our new Street Performance Ready To Run LS3 is now available! Check it out!
Old 12-04-2014, 04:02 PM   #13
Pacific Fabrication
Old 12-10-2014, 08:07 PM   #14
Pacific Fabrication
Call Today!
Old 12-16-2014, 03:15 PM   #15
Pacific Fabrication
Old 12-18-2014, 04:13 PM   #16
Pacific Fabrication
Call today!
Old 01-14-2015, 05:59 PM   #17
Pacific Fabrication
This is one of our most popular packages!
Old 01-20-2015, 04:23 PM   #18
Pacific Fabrication
Thanks for the order!
Old 01-23-2015, 08:18 PM   #19
Pacific Fabrication
Custom builds are also available!
Old 01-27-2015, 06:32 PM   #20
Pacific Fabrication
Old 02-04-2015, 04:27 PM   #21
Pacific Fabrication
Old 02-10-2015, 07:54 PM   #22
Pacific Fabrication
Call today! We are here to help!
Old 03-12-2015, 04:02 PM   #23
Pacific Fabrication
Old 03-24-2015, 01:40 PM   #24
Pacific Fabrication
Old 04-03-2015, 07:41 PM   #25
Pacific Fabrication
Closed Thread
