Closed Thread
Old 03-19-2014, 08:35 PM   #401
texjake
texjake's Avatar
Re: What did you do to your truck today? Chapter II
I finished painting the steering column (no more orange column, yahoo!) after I repacked the upper bearing. After doing some research on the shift indicator that I have, it looks as if someone changed out the '68 column with a '70-'72, I don't know for sure because the harness coming out of the column is different than what it plugs into under the dash (but it still works) and the fact that it was factory orange and the rest of the trim of the truck is red. And yes, I masked off the shift indicator clear lens for the fiber optic light, it just looks like I painted over it and that's not a botched paint job, its a reflection in the paint.
"Now all I need is a shop to go with my shop vac!"
texjake is offline
Old 03-19-2014, 08:45 PM   #402
colgad
colgad's Avatar
Got bed and bumper on today
1967 Red, C10 Short Bed 6.0L T5 5 speed
1967 Orange and Black C50 6.2 Detroit Diesel NV4500, 2 Ton Pickup
1972 White, Chevy Blazer 2WD 67 Dog house 5.3 4L65 2016 Power Tour LH
1955 Red-Cream, Chevrolet Nomad, restoration on hold
2004 Black, Corvette Z06 LS6 convertible (Rock solid Fun) 2011/2018 Power Tour
colgad is offline
Old 03-19-2014, 09:01 PM   #403
ole dollor
ole dollor's Avatar
looking good William , want be long we can cruise the sonic ....
ole dollor is offline
Old 03-19-2014, 10:47 PM   #404
magwakeenercew2jh
RAT1968 '68 Cab/'71 Parts
magwakeenercew2jh's Avatar
Nice set up all the way. Really like the script on the gate.
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
magwakeenercew2jh is offline
Old 03-20-2014, 12:03 AM   #405
texjake
texjake's Avatar
yep, as long as the dirt will stop blowing....lol
texjake is offline
Old 03-20-2014, 09:35 PM   #406
Mike_The_Grad
Mike_The_Grad's Avatar
Finally the day has arrived! Two separate pieces became one once again. It feels good to see your ideas,time,hard earned money and hard work all come together. At least everything from here on out is just bolt it up the way it used to be!
1972 C/10 LWB - Mine
1964 C/10 LWB - My Dad's
Instagram: Mike_The_Grad
Mike_The_Grad is offline
Old 03-20-2014, 09:59 PM   #407
JG67
Originally Posted by 74baggedbug View Post
My boy hooked me up with this on the roof of the 68.. It's been a very expensive 2 weeks for me ... New rearend with 373's and a new posi, new for bearings, roof painted , new windshield & gasket and now gotta install a new driveshaft on Monday
NICE Paint! Good idea that's usually untouched real estate on these trucks.
JG
JG67 is offline
Old 03-20-2014, 10:07 PM   #408
magwakeenercew2jh
School me on that fuel pump. I don't run a mechanical f.p. I always pull 'em off and pull the push-rod, and then block off the port. But, I'm just curious about that big canister on the bottom.
Thanks.
And, by the way, "congrats".
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
Old 03-20-2014, 11:09 PM   #409
mmiddle
mmiddle's Avatar
Thanks.
That's a big block or "heavy duty" (C/30 and up) pump. I ran one on my 69 back in the day.
Mark
Jesus is the Way!
2003 2500HD CCLB Duramax/Ali (Clifford)
2014 2SS/RS black on black Camaro (Betty)
2006 Pontiac SOLSTICE silver/black (Lula-Bell)
1970 C/10 Short Wide (Peggy)
1964 C/10 Short Step (Hambone)
RIP Jimmy Hamilton Thank you for the trucks
mmiddle is offline
Old 03-21-2014, 02:06 PM   #410
Mike_The_Grad
Magwakeenercew2jh, the fuel pump I have has one inlet and two outlets. One for the carb,which is a threaded flare fitting. And a smaller barb type, which is a vapor return line, that runs back to the fuel tank. My guess is that its part of the emissions control system. Also maybe to help reduce vapor lock?
Old 03-21-2014, 03:55 PM   #411
In The Ten Ring
I was finally after over a month able to get a weather break, borrow a truck, and get help to unloadthe fender I had shipped to a body shop. 148 pounds all told the weight of the crate and fender. I hope to uncrate it in the coming weeks and then store it away for when the hardcore restoration comes.
In The Ten Ring is offline
Old 03-21-2014, 05:29 PM   #412
Econman
Econman's Avatar
Picked up my "new" Vortec heads from the machine shop and dropped off my new crank, rods, pistons, rings, balancer and flywheel to be balanced.
Econman is offline
Old 03-22-2014, 02:09 AM   #413
In The Ten Ring
FINALLY. I am able to pick up my new-to-me fender and store it in my garage. Once I am ready I'll uncrate and store it in the garage attic. Once the "hard" restoration begins, this may be my new spare tire fender.
I love how the seller crated if for me. NO DENTS FROM SHIPPING!
Old 03-22-2014, 05:22 AM   #414
Gokart Mozart
After about 2 years recovering from surgery, the need for the truck to be running is coming soon. I drove it around a few times but the trans was slipping, shifting hard. I found a place that will switch the turbo 350 with a 700r4. I was on my way down, not even out of my work's parking lot, I stopped for a second and blewie, no gears, fluid everywhere. The shop is about 30 miles away and I called my roadside assistance company, they wanted to tow it to a Chevy dealership 5 miles away because that's what's stipulated in the contract. I tried to explain the trans isn't going to be repaired, it's getting replaced and she tried to tell me they could only authorize the closest shop. I said the place I was going to was the closest place that will do the work I needed. After a couple times being put on hold they did come back with a wrecker that would take it there. They're going to do the work after hours and with luck it should be done Monday! They said the only issue will be there isn't 4 indents on the column so first won't have a slot. No biggie for now.
Gokart Mozart is offline
Old 03-22-2014, 04:52 PM   #415
Ridgeclimber
In the last two days I got the roof, back of the cab stripped. Started the filler work. I'm tired of sanding now.
Ridgeclimber is offline
Old 03-22-2014, 09:52 PM   #416
dakattack7
dakattack7's Avatar
I spent the day polishing by hand. Did the whole truck, about 3 rounds of compound and then waxed the whole thing. Used some #7 and ultimate compound. I'm really happy with it! Can't feel either of my arms though.
Here's some before and after
During
dakattack7 is offline
Old 03-22-2014, 10:38 PM   #417
magwakeenercew2jh
Quite a difference.
Good arms. It must have been good General paint, huh?
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
Old 03-22-2014, 11:41 PM   #418
dakattack7
dakattack7's Avatar
Quite a difference.
Original? Yes, except the roof was painted with a brush and house paint
Old 03-23-2014, 01:07 AM   #419
Mike_The_Grad
Looking sweet! Dakattack7, hard work pays off. Inspires me to remove all the oxidation from mine also.
Old 03-23-2014, 09:47 AM   #420
dads longhorn
dads longhorn's Avatar
Dackattack7 good job! The truck looks great! It also looks pretty original, I encourage you to keep it that way. Not many originals left around.
dads longhorn is offline
Old 03-23-2014, 01:08 PM   #421
VWNate1
VWNate1's Avatar
Post Re: What did you do to your truck today? Chapter II
There's a great trick RV'ers use to keep that shined up original paint looking great : commercial floor wax ! you put it on several coats and it makes the trig look amazing , keeps the tin worms at bay too .
Once a year does it .
Your rig looks very nice now .
-Nate
Geezer
'49 3100 235 W/ Muncie SM420 SOLD
'69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH
VWNate1 is offline
Old 03-23-2014, 04:22 PM   #422
dakattack7
dakattack7's Avatar
Sorry, double post
Old 03-23-2014, 04:24 PM   #423
dakattack7
dakattack7's Avatar
Thanks everyone. Yea I'm definitely in to the original look, here's how it looked when I got it. I've been putting it back to original. You can't really see in the pictures, but it has 8 screws in the door where a sign or something was, there's some kind of antitheft system that has an extra door lock on the driver side. I haven't even pulled the doorpanel to see whats up, but a wire goes in to the door panel. The seat has been recovered at some point, the engine isn't original, the paint on the roof is brushed on house paint and the box for the bedside toolbox is replaced by an aux tank. So, it's not as original as I would like, but overall I like it!
Old 03-23-2014, 10:06 PM   #424
zicc1835
zicc1835's Avatar
had some fun this weekend clip off motor/ trans out ........
zicc1835 is online now
Old 03-23-2014, 10:19 PM   #425
Steeveedee
Who Changed This?
Steeveedee's Avatar
I had to work both days; the old boy has been parked around the corner for a couple of weeks without being driven. I have a '68 Skylark California GS. I bought a donor car to bring it back to stock over a month ago, and I haven't had time to work on that either. In the last three months, I've had one weekend "free", most of which time ended up being "honey-dos". Good thing the old boy runs well. I was going to at least drive it today to slosh the fluids around, but didn't get to it.
~Steven
Simi Valley, CA
Steeveedee is offline
Closed Thread
