Old 03-20-2014, 03:27 PM   #1
markiemark
HELP..Easiest way to raise a low truck?
OK.. my truck is currently slammed to the ground. leaf flip kit out back and I would guess lowered with spindles and lower springs up front. I just put my 22" rims on and I'm hitting. Not so much in the back but in the front. I was thinking of the quickest fix to maybe gain an inch all around. I really love the look of the 22" and don't mind sacrificing the height a bit.. Thanks
markiemark is offline   Reply With Quote
Old 03-20-2014, 03:32 PM   #2
BMERDOC
BMERDOC's Avatar
Re: HELP..Easiest way to raise a low truck?
Swap out springs in the front and install a higher flip kit. if memory serves there are several height flip kits out there.
Nick Carter
1967 C10 Short bed Fleetside
Project Cheap Thrills!
2WD C10 Modern/Performance Alignments
Easiest Alignment Ever!
BMERDOC is offline   Reply With Quote
Old 03-20-2014, 03:34 PM   #3
markiemark
how do I measure what I have now? Thanks for the quick response too
Old 03-20-2014, 03:38 PM   #4
markiemark
This is my rear set up now
Old 03-20-2014, 05:37 PM   #5
BMERDOC
BMERDOC's Avatar
Looks like someone used regular spring perches to do the flip. Do you know if it has lowered shackles? The front hanger looks stock. Looks like you'll have to reverse the flip and go for shackles and possibly hangers.
Nick Carter
Old 03-20-2014, 07:26 PM   #6
markiemark
So you are saying it's not a simple job.
Old 03-20-2014, 07:42 PM   #7
markiemark
Here's the front set up
Old 03-20-2014, 07:46 PM   #8
BMERDOC
BMERDOC's Avatar
Easy is a relative term. I will have to admit that I haven't done many Flips so its not what I consider my specialty but by the looks of things it has what equates to a 4" drop. If you put the springs back on top and add a 2" shackle you'll have a two inch drop. I don't know if you have drop shackles so I assume its about a 4" drop. If it have shackles its probably a 6" drop and you won't have to buy new shackles to gain the 2". Lets see a side profile of the truck and a shot of the shackles.
Nick Carter
Old 03-20-2014, 07:54 PM   #9
Fatherof3
Fatherof3's Avatar
Have a spring shop add more arch to your existing rear springs or find a leaf with more arch and add it under your main leaf, but this will be trial and error on getting the right height. You can get spacers for the front springs, check off road sites for those.
65 C20 292 4spd 4:56 Eaton HO52
Fatherof3 is offline   Reply With Quote
Old 03-20-2014, 08:09 PM   #10
Pro Performance
Pro Performance's Avatar
For a temporary fix, a spring spacer will work in front, but would suggest to eventually switch them out to a taller (less of a drop) spring. As for the rear, it ends up being appx. a 5"-6" drop with the flip kit. The only way to raise the back, would be to flip it back as mentioned, and add a spring and hanger kit. The spring and hanger kit would yield about a 4" drop.
Pro Performance is offline   Reply With Quote
Old 03-20-2014, 09:12 PM   #11
BMERDOC
BMERDOC's Avatar
Given the way your truck was flipped it would be dropped between 4"-4.5". Your drop used replacement spring perches instead of a "real" flip kit. I won't take it from the P.O. it's a bonafide flip and so simple it eluded me but it does work. All you have to do is measure from the top of the leaf spring (at the lower spring perch) to the top of the upper spring perch and you'll know exactly how much it was lowered. Figure out how much lift you need and report back. It shouldn't take much in parts and some elbow grease to get you where you need to be.
Nick Carter
Old 03-20-2014, 09:15 PM   #12
BMERDOC
BMERDOC's Avatar
Oh yeah, what kinda truck are we working on?
Nick Carter
Old 03-20-2014, 09:18 PM   #13
markiemark
Thanks guys. I don't know much about it but to me it looks way lower than 4". Here's a picture with the 18" and the new 22"
Rear
Front
Old 03-20-2014, 09:26 PM   #14
BMERDOC
BMERDOC's Avatar
I can work with that!! If any thing I'd say you need to be a smidge lower in the front and panties will fly!! LOL! First off. I took a second look at your pictures and noticed you haven't cut down or completely removed your front bump stops . They have a couple of clean spots on them and a nice wrinkle so I'd assume you may be bottoming out on them. Trim the bump stops in half, drive it and see if that helps.
Nick Carter
Old 03-20-2014, 09:30 PM   #15
markiemark
That's the triangle looking thing next to the spring? I can do the work..just need the direction. lol
Old 03-20-2014, 09:30 PM   #16
markiemark
It does look a tad lower in the back than the front though... or is it me..
Old 03-20-2014, 09:32 PM   #17
BMERDOC
BMERDOC's Avatar
Trim it like this:
Nick Carter
Old 03-20-2014, 09:39 PM   #18
markiemark
Thanks I can do that for sure. That gives the front more travel? But will that also help with my tire rubbing.
Old 03-21-2014, 01:30 AM   #19
andrewmp6
Depends where your tires are rubbing on how to fix it.Do they rub over a bump in the road or is it when your turning?
Old 03-21-2014, 08:02 AM   #20
markiemark
I didn't drive to far but id have to say a little of both.
Old 03-21-2014, 08:47 AM   #21
BMERDOC
BMERDOC's Avatar
You may end up having to lose the inner fenders being that low with such a big wheel. The stock bump stops are the only thing keeping it from rubbing worse than it already is.
Nick Carter
Old 03-21-2014, 12:58 PM   #22
N2TRUX
Happy to be here
N2TRUX's Avatar
If you cut that bump stop its going to rub worse. I agree that it should be cut, but not until you resolve the rubbing issue.
Look inside your inner fender and determine where the front is rubbing. If its to the outside (which I suspect) you have too much backspace. Your going to need to raise it, mod or remove the fenderliner, or change front wheels.
If its on top, your spring is too soft, or your tire is too tall. You can add a spacer as Travis mentioned, or go to a smaller tire. new shocks might help too if your only bottoming on occasion.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 03-21-2014, 01:11 PM   #23
markiemark
I'm running 265/35 on 8.5" up front and 285/35 on 10" out back
The backspace is 4.5 on front i believe and 5 out back
I just mounted the new tires yesterday so changing tire size wouldn't be an option at this point...
Old 03-21-2014, 01:14 PM   #24
markiemark
My other question is how do I know what size coil to get up front if I decide to change them. I think I counted like 6 coils but I would have to re check it after this weekend.
Old 03-21-2014, 04:28 PM   #25
SCOTI
SCOTI's Avatar
The backspace is 4.5 on front i believe and 5 out backI just mounted the new tires yesterday so changing tire size wouldn't be an option at this point...
That's part of your problem.... Front wheels on these trucks that are lowered aggressively should be 5" minimum back-spacing w/any decent tire height (28"avg) to keep the edge of the tire farther away from the inside edge of the inner fender-well. I usually try for 5.50" w/8.5" front wheels.
Your front tires are 29.3" tall & the 2nd issue @ that ride height. I would yank the front springs & replace them vs doing the coil spacer which is a band-aid @ best (they're just not a permanent solution).
Flip kits are easier to do vs shackles & hangers because you don't have to remove any rivets. Get us a pic of the rear shackles so we can determine if they're OE or dropped/aftermarket. If they're dropped shackles, swapping OE shackles back in place raises the rear some (1-2" depending on the shackle). For the front swap in a known spring & trim it down from there.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
