03-21-2014, 12:20 AM | #326 |
Re: What did you do to your truck today part II.
The rear is tubbed. I cut the tub in half and added a 4" wide piece of sheet metal. I plan to redo it with new tubs using 2 sets so there is only one weld seem. The fronts took a little coercing and picking the right wheel adapter thickness.
03-21-2014, 06:17 AM | #327 |
Bought another parts truck yesterday, a 1996 C1500, 5.7 TBI/ 5spd. Time for a total drivetrain swap on the '65. Going back with the manual trans, using the '96 hydraulics. Possibly changing the rear end, also, so to keep a working combination together.
will update the build thread, once we get started. |
03-21-2014, 09:25 PM | #328 |
Finally got all the wood installed in the box.
03-21-2014, 11:48 PM | #329 |
03-22-2014, 03:09 PM | #330 |
Installed the deluxe knobs today and took the truck to town. Had one person stop and ask if I wanted to sell it. Of course I said no, and "its my grandpas truck" usually ends that. But I appreciate them liking it enough to ask. As long as they don't throw a typical flippers price at me lol. And another guy came over while I was putting gas in it. Beautiful day.
Chris
1966 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=615165 1968 GTO http://67-72chevytrucks.com/vboard/s...=1#post7650182 |
03-22-2014, 03:39 PM | #331 |
GOD BLESS AMERICA! |
03-22-2014, 03:40 PM | #332 |
TOTALLY different truck. I'm collecting hub caps if you find any back there
03-22-2014, 09:36 PM | #333 |
I fired up the '66 C30 today and drove it around a bit. Will do some more tomorrow. Then it goes up for sale.
Past Master Triluminar Lodge #117 GL of WVa My 1963 4x4 Suburban build; http://67-72chevytrucks.com/vboard/s...d.php?t=531274 My Gallery, now with pics of my 1966 C30 motorhome. http://67-72chevytrucks.com/gallery/...&ppuser=103447 |
03-22-2014, 09:51 PM | #334 |
GMC hood got stripped. Pretty solid overall. Going on my '65 Chevy C10 1/2 ton step.
Before and after shots.
My 65 C10 build: www.lugnutz65chevystepside.weebly.com Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild. |
03-23-2014, 10:11 AM | #335 |
check this out members
03-23-2014, 10:26 AM | #336 | |
03-23-2014, 03:38 PM | #337 |
Super cool, thanks for finding that
03-23-2014, 08:17 PM | #338 |
I towed my tractor with ol Two Tone today! Piece o cake in compound gear...Tried to start out in second; almost...but wouldn't...load was a tad to heavy..and I didn't wanna burn my clutch. lol. But I did shift from compound to second and the motor pulled...might chance and take her down the road an see if she pulls in 3rd. Tractor weighs around 3500 pounds and trailer around 1200....that's calling everything a tad light. No pictures means it didn't happen...so here are some pics...and check my build thread later tomorrow for a video.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
03-23-2014, 09:06 PM | #339 |
Removed the deteriorated A-pillar drip rails on both sides of the cab to find that the A-pillars, while pitted, were still sound.
I'll weld in new drip rails once the cab is sitting upright again. Looking into using some type of rust converter/encapsulator inside the A-pillars and across the top of the windshield via wand/tube, like the "internal frame coating" that Eastwood sells. Anyone have any recommendations? |
03-23-2014, 09:57 PM | #340 | |
03-23-2014, 10:38 PM | #341 |
Replaced the trailing arms, the old ones were a tad moth bitten. A huge thanks to forum member Wayno for donating his old trailing arms.
My truck ain't dead, it just smells funny. |
03-23-2014, 10:51 PM | #342 |
Painted the valve covers and attached the coil packs. Still need the oil pan to come in, and need to put gaskets under the valve covers. Going to wait to install accessories until after it's in the frame.
03-24-2014, 12:41 AM | #343 |
Won't let me edit my post above . . . so here is the fixed link to the engine pic:
03-24-2014, 01:17 AM | #344 |
Clean Waxed, Covered all 3 Put on jack stands On Way Tomarrow To Work in Canada For 4 Months....Duramax All Filled Too Box And Knaack Box Loaded...
I'll be Buying parts and reading in Enviy All of You
1966 GMC K25 V6 351E Original Utility Truck 2000 C3500 Hot Rod Utility Truck 2003 ROAD KING 100th 124ci 6 Speed 145CI M/P Pro Street FXR 2002 FXDP 2007 2500HD DURAMAX. DD Studio Teamsters / Mechanic Retired GM Master Tech 20 Years Retired Ford Tech 15 Years |
03-24-2014, 09:29 AM | #345 | |
03-24-2014, 09:40 AM | #346 |
My plan is to media blast the A pillar and then seal it with epoxy primer. Or I might use POR-15 and then epoxy primer. I want to keep water out so I plan to use a modern adhesive to attach the drip rails. Before I do, I plan to check with Tony and get his advice.
03-24-2014, 11:54 AM | #347 |
Hat's off to "swamp rat" for helping me move on........ Hope all is well.!
. Washed the truck getting myself prep for top removal to fix the rust. I was thinking of lowering the truck but after i unloaded it I like the stance as is . BEFORE . . . . AFTER . . . . Bed looks ok so i can focus on other things leave it for now . |
03-24-2014, 08:30 PM | #348 |
Well,
I didn't actually do anything to the truck exactly... Started making a home for the old girl so the weather doesn't do too much more damage before I can get funds together to continue restoration progress. My Daughter just HAS to "help" with everything. I love that she is into the things I do. Mom wasn't too happy with me for this one, but I didn't show her the picture until after we were back on the ground! still may put some kickers from the drip edge of the barn roof up to the rafters, it's just about at the limit of what 2x6's can handle. Plus, roof sheeting is 3/4" plywood... Not overdoing, just working with what was free. |
03-24-2014, 08:35 PM | #349 |
didn't have permission to upload more than 5 pics at a time, so here are the rest.
Jooniper helping again. And a break for ice cream. Now the yard is starting to look better, and the wife is starting to act much happier |
03-24-2014, 09:54 PM | #350 |
Painted the master cylinder yesterday and mocked it up with brake lines. Still need to polish the aluminum plug in the firewall, then it will be ready to bleed the system. It's been 5 years since this truck has had working brakes, or has moved under it's own power, soon it will again.
66 c20 with 1/2 ton 73-87 front and rear suspension 2-1/2" drop spindles, air-bags, c-notch rear frame 463 Pontiac, SRP Pistons, Eagle Crank and Rods Mega-Squirt Fuel Injection |
