Old 03-21-2014, 07:20 AM   #1
Bueno 68C-10
Bueno 68C-10's Avatar
Question Park lamp to fog lamp conversion??
Is it possible to make the park lamps on a 68 into fog lamps then put a headlight in like these for park lamps?
Bueno 68C-10 is offline   Reply With Quote
Old 03-21-2014, 11:01 PM   #2
Bueno 68C-10
Re: Park lamp to fog lamp conversion??
Anybody???
Old 03-21-2014, 11:44 PM   #3
BlacklandCamper
I have thought about swapping grills to do this. The main issues that I have seen by examining the parts is fitting the housings into the parking light slots. It is more involved than simply swapping bulbs, the housing, and lens need to change as well. One way to do it would be to fab a mounting bracket that would attach to the core support and provide a strong mount for aftermarket fog lights. The alignment and fitment would be very involved with this method.
To make things easier, I would suggest using a '71-'72 front bumper, and installing your fog lights in place of those parking lights, allowing you to keep the factory parking lights in the grille.
Grunt: 1971 C20 Custom Camper. Runs/Drives/Kinda stops. 350Ci, TH350. 4.10:1 D60. Eight Lug LWB is more better. Hell no its not fast!
Donkey: 93 Nissan D21, the farm truck. My 1/2 ton SWB. The Indomitable Datsun.
1st BN 3rd MAR. '00-'04
BlacklandCamper is offline   Reply With Quote
Old 03-22-2014, 12:17 AM   #4
Bueno 68C-10
The bumper idea is a good idea but will a 71-72 bumper fit on a 68?
Old 03-22-2014, 12:51 AM   #5
BlacklandCamper
Bracket modification to fit a '71 bumper onto a '68 would be more straightforward, and less complex than fabricating and engineering a bracket.
Old 03-22-2014, 01:42 AM   #6
'68OrangeSunshine
'68OrangeSunshine's Avatar
I looked into that years ago and wound up getting a '67-'68 front bumper plasma cut for fog lamps and rechromed. It's on my '67 K/10 Suburban now. It was criminally cheap in 1978, especially with a buddy working in a chrome shop.
Another way would be to get an extra inner grille lower insert with the flat mounting for the parking lights and fit fog lights there. You could then have the turn signal /parking lights on the other one. Fog lights work best as low as possible.
'67-'68 brackets are different from '71-'72 ones.
Old 03-22-2014, 02:06 AM   #7
BlacklandCamper
I had been thinking that using '71 braces and upper brackets would bolt to the frame and allow the use of the bumper.
Old 03-22-2014, 03:05 AM   #8
'68OrangeSunshine
It was a long time ago, but IIRC I was told there were issues. But it would have to be tried to find out conclusively. It may have been more expedient at the time to cut out a '67 bumper for a '68.
Old 03-22-2014, 08:44 AM   #9
Bueno 68C-10
So will the headlamps with the park lamps built in work on my 68??
Old 03-22-2014, 10:51 AM   #10
brawley
Easy Does It
brawley's Avatar
I used the built in turn signal headlights on a 63' truck I did, you will have to take the wires from the turn/parklights to the new headlights there are two connections on the back of headlights. then you could mount and wire in some foglights in where the old parklights were, should work.. find some about the same size
brawley is offline   Reply With Quote
Old 03-22-2014, 11:27 AM   #11
Hawghauler
Hawghauler's Avatar
I was looking at some newer truck and car driving lights. It looks like some of them could be adapted to fit in the same space as the original blinkers. Then you get some h4 housings with the extra blinker light inside. Here's a pic of the headlights.
I haven't done any measuring or anything, I just started looking around. I don't think it has to be exactly the same dimensions, just close enough to maintain the original look we all love. I've seen the '72 bumpers on the '68's, and I think it looks too different.
If I have to be on 4 wheels, It has to be a classic Chevy
1967 c10 Longbed (Hawghauler/Icy weather transport)
2003 BMW K1200GT (Rain bike)
2007 Softail Deuce (Sun bike)
2009 Ultra Classic Electra Glide (Everything else bike)
Hawghauler is offline   Reply With Quote
Old 03-22-2014, 11:34 AM   #12
Steve Hafner
Steve Hafner's Avatar
A couple people on here have done it ( not mine )
Steve Hafner is offline   Reply With Quote
Old 03-22-2014, 11:45 AM   #13
cdowns
cdowns's Avatar
you cant use the park lamp wireing to use on fog lamps as it is not heavy enough to hold up for long
Old 03-22-2014, 12:15 PM   #14
BlacklandCamper
The bumper with the round lights is offered by LMC. The second one looks like a regular bumper from a 71-72.
Old 03-22-2014, 12:51 PM   #15
Hawghauler
Hawghauler's Avatar
They would definitely need their own wiring for the driving/fog lights. You would be using the original parking light wiring for the one inside the h4 housing. I'm not too sure how visible these blinkers inside the h4 would be, but I've seen them being used that way on older hot rods. I've even seen it done on Harleys.
I've also considered doing a light in the same place but above the center bar, matching the blinker below. I think I've pretty much poo pooed that for me though.
Old 03-22-2014, 05:43 PM   #16
Bueno 68C-10
Alright I think I'll try that maybe and if I can't figure out the fog lamps at least I will have some sweet headlights!
