Old 03-21-2014, 02:47 PM   #1
First c10
First c10's Avatar
HVAC Vacuum Reservoir???
I searched and could not find an anwser, so thought I would ask the question.
Do you have to use the stock Vacuum reservoir for the HVAC?
and if so can it be mounted under the dash?
Scott
FYI
1970 C10 CST with factory AC LC9/6L80E
1956 Chevy Bel Air 2 door
1956 Chevy 210 4 Door
1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD
1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E
1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD*
GO GO!!!
First c10 is offline   Reply With Quote
Old 03-21-2014, 03:32 PM   #2
JimKshortstep4x4
Re: HVAC Vacuum Reservoir???
You don't have to use the factory vacuum reservoir and you can mount it under the dash. You will want to use a good canister that is made for vacuum and is at least as large as the truck unit.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 03-21-2014, 06:25 PM   #3
First c10
First c10's Avatar
So you have to use a canister???
GO GO!!!
Old 03-21-2014, 07:31 PM   #4
JimKshortstep4x4
I did not mean to throw you with the terminology! Plastic or metal can be used as long as the part is made for vacuum.
Jim
Old 03-21-2014, 07:55 PM   #5
First c10
First c10's Avatar
Jim so you HAVE to use a canister? As in a canister is needed and will not work and will NOT work without it?
GO GO!!!
Old 03-21-2014, 09:33 PM   #6
68c10airstream
68c10airstream's Avatar
Hi firstc10, I went to auto schooling in the 70's and remember the vac tank well. It's purpose is to check and hold vacuum, because when you step on the gas manifold vacuum drops off, and the vacuum that was in the lines would be bled off into the intake and there would be no vacuum available. 2 lines hook up to the tank, engine supply, and the other line goes to the controls inside the cab. It can be hooked up wrong (backwards), so here is the test. Use 2 vacuum hoses, install them on the tank, put your finger over the open end of one line from the tank, then suck on the other line that is hooked to the tank. When you release the vacuum that you put on the hose, there should still be vacuum present on the hose that your finger is on. Another words you are acting like the engine would with vacuum present, then bled off, but there should still be vacuum remaining on the other line. Good luck, Brian Fuller
68c10airstream is offline   Reply With Quote
Old 03-21-2014, 09:38 PM   #7
68c10airstream
I believe classicparts.com has that tank very reasonably priced. It mounted on the engine side of the evaporator housing in the engine compartment. 2 screws were used to mount the vac tank ball.
Old 03-22-2014, 02:43 AM   #8
First c10
First c10's Avatar
Thank you for the explanation would I still have a vacuum problem with a stock 2011 LC9? I was wondering if I could just eliminate the reservoir all together. If I need to keep it where is the best place to get vacuum from? Maybe I need to ask in the lsx area.
GO GO!!!
Old 03-22-2014, 03:03 AM   #9
piecesparts
Parts and more parts
piecesparts's Avatar
The reservoir is an important piece for your controls in the cab of a vehicle. It holds enough vacuum in reserve, to make up for those moments when your engine does not make good vacuum. This keeps the heating and air conditioning dampers from cycling to a different position, when the vacuum signal drops from the engine while climbing a hill or driving in heavy traffic. The newer vehicles have electronic controls on a lot of their dampers and controls and do not require as much vacuum as the older vehicles used to. If nothing else, put the reservoir under your floorboard to keep the volume of your vacuum available but the reservoir is out of site.
Frank
Old 03-22-2014, 10:14 AM   #10
First c10
First c10's Avatar
Perfect thank you.
GO GO!!!
Old 03-22-2014, 10:46 AM   #11
68c10airstream
Hi firstc10, as far as an available vacuum port on an ls goes, i know my 2001 5.3 has a unused port on the intake. If nothing is available, dodge, plymouth, and chrysler, into almost 2000's had a spare port that was capped off right at the vacuum line at the brake booster. The thick vacuum line went from the engine to this round check valve assy, and that pushed into the booster. The capped off line was used for cruise control, hence this is your vacuum supply and check valve all in one. You could install this check valve in place of the gm check valve (if it fits) you would not need to get a vacuum tank and add it to the vehicle. I hope i'm not confusing you in the process, but if the check valve fits it would be a clean install with minimal sized parts only needing the vacuum line from inside the cab to plug into the check valve at the booster. If you care to venture into this, take your old check valve out and go to a junk yard with this post printed in hand and i think they would help you. Good luck, Brian Fuller
Old 03-24-2014, 12:43 AM   #12
First c10
First c10's Avatar
I used the 1/2" port on the back of the intake that was for the brake booster. I put a tee to the vacuum reservoir and to the brake booster. So far so good.
Thanks for all the input guys.
GO GO!!!
