Old 03-21-2014, 08:49 PM   #1
BCOWANWHEELS
Hei where to hook up 10 gauge wire ????
WELL, i,am installing a coil in cap hei dist. I was told I need to not use the factory hot wire going to coil as its a resistor (9 volt) and go to a 10 gauge wire. my question is where are you fellas hooking up the 10 gauge wire to in order to get 12 volts ? i know where it hooks on distributor but where does other end hook to ? all help is appreciated. I searched hi and low on this site for info and couldnt find it.
regards
bob
I BELIEVE IN JOHN 3:16
BCOWANWHEELS is offline   Reply With Quote
Old 03-21-2014, 09:02 PM   #2
uncle
Re: Hei where to hook up 10 gauge wire ????
Ign unfused on fuse block is where I put em. Other words switched 12 volt source not constant.
uncle is offline   Reply With Quote
Old 03-21-2014, 09:04 PM   #3
NC67Chev
NC67Chev's Avatar
I plugged mine into an unused spade connector on the fuse box labelled "IGN Unfused".
1967 Chevy C-10, 250 L6, Powerglide, 3.73, SWB, Fleetside
Upgrades: Power steering, Offset air cleaner, Rear Sport bumper, 3 point safety belts, HEI, -1/-2 springs, 16x5 wheels, McGaughy's disc brake conversion, Sway bar
NC67Chev is offline   Reply With Quote
Old 03-21-2014, 10:30 PM   #4
FirstOwner69
FirstOwner69's Avatar
Here are a couple good threads on this subject. I did mine as VetteVet suggests in post 20 of the first link. That way it appears more like the original, and I didn't have to run another wire inside the cab and use a terminal on the fuse block.
Edit: I used a wire and connector from a mid-70s to 80s Chevy truck and maintained the resistor wire, disconnected at both ends, in case someone wants to use it in the future.
http://67-72chevytrucks.com/vboard/s...d.php?t=431086
http://67-72chevytrucks.com/vboard/s...d.php?t=457489
FirstOwner69 is offline   Reply With Quote
Old 03-21-2014, 10:55 PM   #5
cdowns
cdowns's Avatar
i prefer to take the original harness apart and eliminate the original resistor wire and put the new wire in that place and wrap the harness up to look stock as it came from the factory// i've always just used 12ga wire with good results
Old 03-22-2014, 01:50 AM   #6
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Yup, 12 ga. works just fine. IMO, 10 ga. is overkill, looks too fat, and being somewhat stiffer makes it a bit harder to handle.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Old 03-22-2014, 03:45 AM   #7
BCOWANWHEELS
SEEINGS I,AM crippled getting to the factory harness would make life difficult for me so today I bought 6 ft of #10 wire so I,am gonna find the ign. unfused in the fuse block and try to go that route. then just tape up real good the stock wire so it wont ground out. this will keep my truck as close to stock as possible. thanks fellas you fellas really come thru when t counts.
regards
bob
Old 03-22-2014, 04:43 AM   #8
BCOWANWHEELS
ok i see there is a correct wire connector available for the tach and batt connection on the dist. cap. do you fellas know if NAPA or the like has these as replacement parts, i like to do things as right as possible. I know a spade wire connector will work but the correct connector would be nice.
Old 03-22-2014, 06:35 AM   #9
19673ontree
CAN'T FIX NOTHIN
19673ontree's Avatar
I just bought a new accel high power hei and accel wires for my boys 68 at advance $275 for all of it , he got online they make a set of weights to put in the distributor to change the advance curve we got those and put in it , also the accel vacum advance is adjustable we monkyed with that and BAM! Woke his 350 up !
We put a new 12 gauge wire from the ignition unfused on fuse box , the distributor had a spot for his tach also , easy install ,,
1967 C10 Shortbed Fleetside Small back glass
6 cyl 3spd on the tree 3.08 gears
underdash AC
19673ontree is offline   Reply With Quote
