resident oilfield trash
Want to add keyless entry. Currently have manual locks
I want to add keyless entry and remote start to my 91k5. I currently have manual locks. I don't want to add unlock buttons to the door panels but I do want to be about to unlock with a remote. I really don't care about it having an alarm. What do I need to do?
1967 SWB C10 396/400 factory air factory tach (sadly had to send to a new home) 1986 Honda 70 Fourtrax 1991 Chevrolet K5 blazer 2wd 1982 Mastercraft Pro Star 190 Stars and Stripes 2002 Chevrolet Tahoe 2011 Nissan Armada
It followed me home?
Re: Want to add keyless entry. Currently have manual locks
just add a solenoid in the door(s) and use it to move the lock/unlock rod. Control it with a keyless entry system, easy enough
Adam That's why they call it a shortcut Kyle, if it was easy it would just be the way. 86 c-10 SWB 85 CCSB 90 GMC K30 Crew SRW 1985 C30 Dually |
78K & 79C Jimmys
I installed the lock popper from another car door,ran wires into dash area,local autostart company wired it to the remote when the Viper alarm was installed.
Even stock it all hides under the panel.....cept the switch I'd go out pop the lock,pump the gas and start with key, once running, hit the start button, remove key,go back in and wait till warm, pop lock to get back in,or car turned off using built in timer. but 91 shouldn't be a carb.......so much easier! I think here we (still do) need to be liceneced to install an auto start here
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
I'm more of a kit kind of guy lol.
![]() Any kit will work, id recommend something by DEI. See the little square metal piece in this kit, it mounts to the rod in the truck and the new actuator rod, mount actuator to metal strap on door, run wires to relays, wire brain of keyless and done. You'll be done in 2 hrs
Adam That's why they call it a shortcut Kyle, if it was easy it would just be the way. 86 c-10 SWB 85 CCSB 90 GMC K30 Crew SRW 1985 C30 Dually Last edited by cochino12; 03-20-2014 at 07:23 PM. |
Home Built '87
x2 above...
LMC has a universal kit you can buy too.
Gordon 1998 White Chev ext cab 2WD (Summer Project) http://67-72chevytrucks.com/vboard/s...d.php?t=408424 1987 Chev Silverado SWB (Winter Project Rebuild) http://67-72chevytrucks.com/vboard/s...d.php?t=424833 Truck Club http://67-72chevytrucks.com/vboard/s...d.php?t=466969 |
just get the factory(esq) door lock solinoids from a truck/burb/blazer with electric doors, the hardware for mounting is all straight forward, use the factory door lock wire clips and connectors and run it thru the door jam at the factory location using factory door boots to keep it clean and hook it to an el-cheapo wireless alarm or wireless starter brain box. cheap, easy, uses factory hardware, from pick and pull and local radio install shop or big box shop like best buy you would be in it less than 250 clams and the loss of an afternoon during march madness.
dont read too deep into what is 'available' just look at what gm already did and add the wireless brain box in the mix. my truck is an 86, but it already had all the factory electric parts in the dash and fuse panel for electric doors, just need to add the hardware and wires to the doors themselves. CAKE.
WHO_DCTC - Wifes 05 Z-71 Build - Now defunct as she decided she wants an Escalade too Cream Puff - LS'd Square - Slow going on the back burner Tripple Threat - 3 Wrecks for the price of one build thread Project Delongdium - Step-Sons Plastic Clad 2003 Avalanche - DONE and Delivered. |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
