03-23-2014, 02:50 PM | #1 |
3 on the tree help
i googled and didnt come up with much i need pictures of what brackets mount to what shift linkage and what pin on the transmission and from that i should be able to figure out what goes into the colum at the top...my truck got stuck in first i yanked the linkages free but it just kept screwing up over and over again so i took everything abart and can get it to shift into reverse i used a pin on the colum to line up neutral and everything...the links on the trans look like the were welded and re angled so i think it might be that or a bent arm its just being a pain thanks
03-23-2014, 05:41 PM | #2 |
Re: 3 on the tree help
More info?
What year truck? Which tranny? And most important question for me is where on THe Island do you live? |
03-23-2014, 05:45 PM | #3 |
68 c10 3 speed pretty sure saginaw and im down in vic
03-23-2014, 06:01 PM | #4 |
Could be a muncie like in this link. IF it has 4 bolts on the side cover and shift arms like the link pic.
If it's 7 bolt cover it's a saginaw. You might need to take us some pics of your linkage on the column and on the tranny, then we can see what you're talking about. http://67-72chevytrucks.com/vboard/s...d.php?t=621891 |
03-24-2014, 12:44 AM | #5 |
03-24-2014, 01:56 AM | #6 |
Whoa, those linkages look dodgy as.
Here's a post with some images of how they should look: http://67-72chevytrucks.com/vboard/s....php?p=6257877 |
03-24-2014, 09:43 PM | #7 |
ok so i need new linkages then...hope i can find a pair..and hopfully my shift bars are tweeked either thanks for your help and i think im also going to get a machinist to spin me some bushings.
03-26-2014, 09:04 PM | #8 |
Hey Nodd, If you want to have a look at my set up I'm down in Vic pretty regular. I run the 3ott, I-6 250, saginaw tranny. I had to source the column linkage from a farmers field, it works but it's sloppy. If you decide to have some bushings spun I'd like to go in on that with ya maybe we can split the set up costs?
Cheers, Rob. |
03-27-2014, 01:04 AM | #9 |
That would be awesome if u came down with the truck text my phone when ur down next 250-507-7744 and ya I can get the guy to make 2 sets shouldn't cost much he said he's got some spare once inch brass stock kicking around shouldn't be 2 much
03-27-2014, 01:05 AM | #10 |
I noticed ur in Brentwood I'm just down from uptown not to far away
