Old 03-24-2014, 12:35 PM   #1
1moretime
Porterbuilt Front Stage 1 Install.
Seems alot of people ask about installing a Porterbuilt Stage 1 front bag kit so I thought I'd post pictures of my install. I took lots and lots of pictures so it will be more than one post. I'm not an expert photographer or installer but it will give you a general ideal. I'm starting out with the springs and spindles removed. I had replaced my ball joints earlier and also redid my control arm shafts, so I'm starting with a clean slate . This was installed on a 68 c10 so if you have a different year it may vary a little. Here goes....... Hope you don't mind Nate
68 Chevy Short Stepside 250, 3 on tree
1moretime is offline   Reply With Quote
Old 03-24-2014, 12:42 PM   #2
1moretime
Re: Porterbuilt Front Stage 1 Install.
Now that the bumpstop is gone , time to remove the upper shock mount.
Old 03-24-2014, 12:46 PM   #3
1moretime
Now I'm going to drill my crossmember for the upper bag plate.
Old 03-24-2014, 12:49 PM   #4
1moretime
I drilled a hole in the crossmember to run my air line.
Old 03-24-2014, 12:53 PM   #5
1moretime
I mounted the air bags to the upper plate and lower cup
Old 03-24-2014, 12:56 PM   #6
catch2otwo
Looking forward to more.
catch2otwo is offline   Reply With Quote
Old 03-24-2014, 12:58 PM   #7
1moretime
Mounting the bags
Old 03-24-2014, 01:01 PM   #8
1moretime
When you go to mount the drivers side upper shock mount you may run into this
Old 03-24-2014, 01:05 PM   #9
1moretime
I'm waiting on my spindles before I install the shocks but I'll post pictures when I install them. There are several threads you can search and reference before you install your front air bags. Here's a nice chart that shows the different hieghts with the different components. http://67-72chevytrucks.com/vboard/s...d.php?t=609897 The Porterbuilt kit is very nice and everything is labeled nicely, another big plus is Porterbuilt will answer any question you have.
Old 03-24-2014, 01:22 PM   #10
1moretime
No I don't work for PorterBuilt but I'd sure like to. Think they could pay me in crossmembers.
Old 03-24-2014, 02:08 PM   #11
slowcpe
slowcpe's Avatar
Great info. Thank you. I'm hoping to be tackling mine when I take a vacation in 2 weeks.
Ryan
1967 Red Stepside..."Laymond" http://67-72chevytrucks.com/vboard/s...40#post6441840
1972 Medium Olive SWB-Chester http://67-72chevytrucks.com/vboard/s...d.php?t=759628
1967/71 Blue SWB C10..SOLD
1977 SWB K10..my grandpa's.....never should have sold
slowcpe is offline   Reply With Quote
Old 03-24-2014, 02:42 PM   #12
oldman3
oldman3's Avatar
Very nice on the detail of the install, looking forward to the rest...Jim
oldman3 is offline   Reply With Quote
Old 03-24-2014, 09:07 PM   #13
dec010974
dec010974's Avatar
where was this thread about two mounts ago? it sure does bring back memories. I want to add two notes things, test your bags, lines & fittings, to make sure they hold air pressure. my front bags wouldn't hold air for more than a few hours. I had to redo everything. also if you are running stock rally wheels, grinding of the lower control arm, around the ball joint area, may be necessary. larger diameter wheels makes this concern, grinding of the control arm, disappear. I am waiting until I can afford a nice pair of wheels b4 I run the streets of Miami. good luck to all. 1moretime, I'm gonna watch this thread. I wanna see your finished product.
dec010974 is offline   Reply With Quote
Old 03-24-2014, 10:05 PM   #14
Pro Performance
Pro Performance's Avatar
Great write up, and thanks for sharing!
Pro Performance is offline   Reply With Quote
Old 03-25-2014, 12:47 PM   #15
Gus350
68 C 10
Gus350's Avatar
Great info in here thank for taking the time to write it up
Kevin
"Life is Hard But its Harder when your Stupid"
John Wayne
68 C10
70 C20
http://67-72chevytrucks.com/vboard/s....php?t=602326#
Gus350 is offline   Reply With Quote
Old 03-25-2014, 11:48 PM   #16
kamikazekyle05
kamikazekyle05's Avatar
Man i wish i had this when i installed mine, great job!
kamikazekyle05 is offline   Reply With Quote
Old 03-28-2014, 07:43 PM   #17
1moretime
Got my drop spindles on and installed the shocks. Here's the shock mounting sequence.
Old 03-28-2014, 07:46 PM   #18
1moretime
More pictures of the bottom shock mount.
Old 03-28-2014, 07:49 PM   #19
1moretime
TIme for the top shock mount.
Old 08-17-2014, 12:24 AM   #20
swanga c10
So does the bottom cup just sit in the recess of the lower control arm?
swanga c10 is offline   Reply With Quote
Old 08-17-2014, 06:58 AM   #21
1moretime
Yes
Old 09-16-2014, 12:04 AM   #22
Carbajal
Carbajal's Avatar
Great job!! Going to make my install alot easier.
Carbajal is offline   Reply With Quote
Old 09-18-2014, 06:24 PM   #23
Tree-50
Dumb question, never bagged one of these trucks but are shorter shocks/relocated a must or will stock?
Will the stock hold you up?
Tree-50 is offline   Reply With Quote
Old 04-03-2016, 05:45 AM   #24
crazycrew
WOW, very informative write up. What drop kit/spindles are you actually using??
crazycrew is offline   Reply With Quote
Old 04-03-2016, 08:29 AM   #25
crazycrew
Edit::: I read thru the actual build thread also and see that you have McG spindles.
Brooks -- South Louisiana
2004 Tahoe, DD
Currently on the prowl for that right C10 project
https://www.facebook.com/brooks.landry.1
IG : brolandry
