Old 03-24-2014, 03:19 PM   #1
terrylgreenjr
BOSS 338 Questions
I'm looking to put the 338 wheels on my 91 Suburban. Id like to put the 8.5 inch in the front and 10 inch in the rear. Im unsure of which backspacing to get and I'm pretty sure I'll need a spacer to ofset the rear out some. Any info ou have would be great. I'll probably end up with a flip kit and drop spindles and springs in the front. Im not going so low to cut the back floor or remove the wheel tubs in the front
thanks in advance
terrylgreenjr is offline   Reply With Quote
Old 03-25-2014, 08:06 PM   #2
gclark1
gclark1's Avatar
Re: BOSS 338 Questions
Have a 77 2wd Blazer and just ordered 10" wide with 5.25" backspace on the rear. Factory rally wheels that are on it were 8" wide with 4" back. I measured against what was on there and took my best guestimate as to how they would work. I am going to use a 295 wide tire.
I am not to the front yet as I have no engine in it and want it sitting pretty close to ride height before I measure for fronts. Hope that helps.
Since the picture, I have adjusted the rear up about 3" to where it will sit. Static drop.
gclark1 is offline   Reply With Quote
Old 03-25-2014, 08:09 PM   #3
lolife99
67-72 parts collector,…
lolife99's Avatar
20x8.5 (5.25" bs)
20x10 (5.5" bs)
These are the available sizes that work best.
Keith
Convert to disc brakes.
Old 03-26-2014, 01:44 PM   #4
terrylgreenjr
gclark1 how did you lower the rear? I'm going to to 3inch spindles in the front and want the rear to match on my 91 Suburban
Old 03-26-2014, 02:56 PM   #5
Cherub
Cherub's Avatar
20x8.5 (5.25" bs)
20x10 (5.5" bs)
what he said
Cherub is offline   Reply With Quote
Old 03-26-2014, 04:25 PM   #6
gclark1
gclark1's Avatar
Just removed the overload and had the leafs de-arched.
Old 04-01-2014, 04:04 PM   #7
terrylgreenjr
Is there any other way besides d arching the springs to get another 1-2in of height back after doing the axle flip?
Old 04-01-2014, 04:41 PM   #8
68Timber
I know the pieces fit
68Timber's Avatar
I'm trying to remember who it was, but someone used a 4x4 hanger to raise their Blazer back up a little after a flip. I'll have to search on that.
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 04-01-2014, 10:35 PM   #9
terrylgreenjr
What about 2.5 inch lift spring with the flip kit?
Old 04-02-2014, 08:32 AM   #10
68Timber
68Timber's Avatar
I haven't had a chance to do a search yet, but it was something tvblazer78 did that was a pretty slick solution to the flip. I think he used next gen 4x4 hangers to raise it back up 1.5" or so. I know he was running a static lift and had it dialed in just right, I just can't remember at the moment exactly what hangers he used that were the solution. I'll look for it later today.
John
74 Honda Z50 build
Old 04-02-2014, 10:52 AM   #11
68Timber
68Timber's Avatar
I had the wrong member in mind, it was something lowlife mentioned doing in nlped's build thread on page 1 here: thread.
John
74 Honda Z50 build
Old 04-02-2014, 02:09 PM   #12
terrylgreenjr
Does this look like it will work? Its listed for a 1996 K1500. To me it looks longer then the factory 2wd ones but Ihaven't put my hands on one yet
http://www.oreillyauto.com/site/c/de...eyword=722-008
Old 04-02-2014, 02:24 PM   #13
68Timber
68Timber's Avatar
After looking again I'm pretty sure he's talking about 73-87(91) 4x4 hangers. I'm not sure why I'm remembering next gen.
John
74 Honda Z50 build
Old 04-02-2014, 03:18 PM   #14
lolife99
lolife99's Avatar
73-87 4x4 rear hangers are taller.
This will raise the truck after a flip kit is installed.
Before you buy "lift leaf springs",... I would reverse the flip kit and buy drop leaf springs.
www.performanceonline.com sells them.
Keith
Old 04-02-2014, 05:01 PM   #15
terrylgreenjr
The Drop leafs are only listed for trucks Do you think the weight Suburban is going to cause an issue? Will They be too soft?
Old 04-08-2014, 05:41 PM   #16
terrylgreenjr
I got the wheels installed fronts 8.5in w/5.25 bs and rear 10 w/5.5bs. I did have to clearance the front rotor hub a little but other then that they look great. I'm doing the flip kit and installing the 96 model 4x4 rear hanger this weekend. If my math is right they will raise it about 2inches up after the flip. I'm also pulling the LS motor out of my K5 and its going in the suburban too Its going to be a crazy weeked without sleep
Old 04-08-2014, 05:57 PM   #17
lolife99
lolife99's Avatar
They worked great on my 'old '91 'burb,...
Keith
Old 04-16-2014, 08:43 PM   #18
Ice&burban
Hey lolife, I really like the stance of your burb. What did you use front and rear? Sorry, mean to hijack.
Ice&burban is offline   Reply With Quote
Old 04-16-2014, 09:32 PM   #19
lolife99
lolife99's Avatar
Just found your question.
Drop leaf springs in the rear.
3" drop spindles and 1" drop springs up front.
Keith
Old 04-16-2014, 09:42 PM   #20
Ice&burban
Ok, I wasn't going crazy. Was that a 4 or 5 drop leaf? I'm guessing you still needed to notch the frame.
Old 04-16-2014, 11:09 PM   #21
lolife99
lolife99's Avatar
4" drop leaf springs.
Www.performanceonline.com sells them now.
Keith
Old 04-16-2014, 11:10 PM   #22
lolife99
lolife99's Avatar
No frame notch.
Keith
Old 05-14-2014, 09:10 AM   #23
wpotter
wpotter's Avatar
I did a flip on a 90 Suburban and then added a 1.5" add a leaf. Worked out great, no notch needed and probably helped out the old sagging springs. Front was a spindle and 2" spring. 20X8 front with a 255/35r20, 20X10 rear with a 275/35r20. Sorry no pics, one I did and never took pictures.
Never a failure, Always a lesson!
1968 Chevy SWB Fleetside ECE 4/6 327/350
1987 Chevy V20 Scottsdale 4X4 350/400 4.10
1987 Chevy Custom Deluxe SWB 305/7004R4
1991 Suburban Silverado V1500 4X4 350/700R4
2015 Chevy Crew Cab SWB (Daily Driver) 5.3
wpotter is offline   Reply With Quote
