Old 03-24-2014, 04:05 PM   #1
monte0185
monte0185's Avatar
Doing something small
It all started with.... LOL I think most of our truck endeavors start this way. I started with just a simple thing and it escalated from there. When i got my truck I knew the grill was in upside down. Not a huge ordeal to fix so after working on the engine and getting most of it squared away I started on the Grill. Pulled it out. 1 screw and some silicone on the screw holding it in place is what was holding the entire grill in. So got the grill out and noticed all my headlight adjusters were bolts and nuts. Well onto rockauto we go. Order a t-stat cause mines to low if it actually has one. 4 sets of headlight adjusters and an oil pressure switch since mine reads too high to be true. So after sitting for a couple days the parts come in and i start to remove the headlight bolts and think to myself these headlight buckets are aweful rusty and would probably adjust better with a bit of new grease on the back of the buckets. well that escalates into pulling all of them out and cleaning with a wire brush then i think to myself well if i have went this far might as well start painting too. LOL So I painted the headlight buckets and started in on the rust on the radiator support and its up for paint next. LOL Sometimes I think i think a bit too much for something that was never meant to be a show truck. Im just glad i dont have access to some powder coating. LOL
A computer once beat me at chess, but it was no match for me at kick boxing.
Duct tape is like the force. It has a light side, a dark side, and it holds the world together.
monte0185 is offline   Reply With Quote
Old 03-24-2014, 04:11 PM   #2
OldCreek
OldCreek's Avatar
Re: Doing something small
Don't you think you should paint the rad support now that its freed up? And the horn. And the fan. and the....
1972 K20 Suburban 5.7/700r4/NP205 Dana 44/H052 Sold
1972 C10 5.3L/4L60E 12bolt 5Lug - Sold
1971 K5 Blazer 6.0L LQ9 4L60E NP205 Dana 44/H052!!!
1970 K3500 1ton CrewCab 8.1L/Allison1000/NP205 Dana 60/14B!!!! - Sold
1984 K10 SWB 7.4L/4L80e/NP208 Corp 10/12 bolt Sold
1988 V30 CCLB 7.4L/TH400/NP205/Dana 60/Dana 70/3.73!!! (Sold)
2003 K2500HD 8.1/Allison1000/NP263
OldCreek is offline   Reply With Quote
Old 03-24-2014, 04:12 PM   #3
monte0185
monte0185's Avatar
Grill pic before. If you look at the corners you can see the PO put it in upside down. LOL
Old 03-24-2014, 04:13 PM   #4
monte0185
monte0185's Avatar
Yeah thats next. Pulled the fan off after that pic and started cleaning up the surface rust on the RS so I can paint it too. LOL Think im gonna take the plastic breather thing off on the pass side and take the knock out of the drivers side off as well to give the engine compartment a bit more air.
Old 04-07-2014, 10:51 PM   #5
monte0185
monte0185's Avatar
Guess I should show my after pics as well since i started with the crappy before ones. LOL. I really do not like the grill. it has a horrible fit. I think its an older model of the phantom grill cause they were prone to bad fits if memory serves. Going to either buy a new one or just get the center section and buy the light covers. havent made up my mind.
Old 04-07-2014, 11:02 PM   #6
05duramaxhd
Lookin good
05duramaxhd is offline   Reply With Quote
Old 04-07-2014, 11:19 PM   #7
Slammed84
Slammed84's Avatar
Looks nice monte. It always a snowball effect with guys like us. I have the same grill but mine is not the phantom. It shows the headlights.
84' C-10 Custom Deluxe
97' & 98' C-1500 Silverados
Slammed84 is offline   Reply With Quote
Old 04-08-2014, 07:33 AM   #8
monte0185
monte0185's Avatar
Thats what i had on my last square. Thinking about doing it again on this one but havent made up my mind yet.
Old 04-08-2014, 08:34 AM   #9
Slammed84
Slammed84's Avatar
yeah i like the phantom but then again i like just the plain billet better. The phantom grilles look good on show trucks that are going for that completely smooth look. But i think the billet looks better on daily drivers that still want to be custom in parts.
Now i'm gonna have to clean up my headlight buckets! they look good. I'm in a good position to do it right now too as you can see
Old 04-08-2014, 08:50 AM   #10
monte0185
monte0185's Avatar
Yep you are. LOL.. I started out just going to change the headlight adjusters since they were rigged up with bolts and nuts. Once i seen the grease between the radiator support and buckets was all dried and crusty it went down hill from there. lol
Old 04-08-2014, 05:29 PM   #11
79Betty
79Betty's Avatar
What started with a 4 speed 205 swap turned into a cab swap, newer 454 and 8" lift... Go big or go home!
When in doubt, throttle it out!
1974 Chevrolet Custom K20
2005 Ford Ranger Edge
1985 Chevrolet Custom Deluxe C10
79Betty is offline   Reply With Quote
Old 04-08-2014, 08:31 PM   #12
monte0185
monte0185's Avatar
Thats how mine usually turns out. Lol trying to keep this one on the smaller scale.
Old 04-08-2014, 09:47 PM   #13
silverbear
silverbear's Avatar
I know this effect way to well. My small repair started as a busted brake line and now a year later, I stripped it down to the frame. Replaced the cab and bed and exhaust and wiring and fenders and doors and..... Still haven't put any miles on .
86 Chevrolet K10 350/SM465 Frankie SOLD
1995 GMC Yukon GT SOLD
1996 GMC Yukon GT
2010 Suburban 1500 4x4 5.3l/6L80e. Sold
2016 Silverado 2500HD Crew Cab 4x4 6.0l/6L80e
silverbear is offline   Reply With Quote
