#76 |
Re: 64 C10 Stepside "Jaybird"
Thanks Rian.
I got the driver floor pan tacked in this morning. Working on getting the kick panel to fit properly at the top. ![]() ![]() ![]() Bret
64' Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=586955 |
#77 |
I'll be doing the same thing in a few weeks. Nice job.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
#78 |
Well I started out sandblasting the front of the frame yesterday but the North winds quickly put a stop to that. Blowing in at 27mph. So I switched gears and almost finished welding up the floor pan. I still have a few holes to weld up. Taking the time to let it cool was killing my patience just wanted to keep going and finish.
Metal to metal bondo is going to be my friend on this job. Although no one will ever see any of this once it is done. ![]() ![]() ![]() ![]() Can't wait to get the cab finished so I can pull it and start serious on the frame and suspension. ![]() ![]() ![]() I start vacation in 11 days. I will be off for 12 days and hope to get all of the cab welded up so I can pull it and start on the bottom of the cab and the frame rebuild. Ordering all of the suspension parts and frontend rebuild on Thursday. Bret
#79 |
Nice job repairing the floor in your truck, I looked back at post 17 to get a before and after view,
1963 Fleet Side cab, Converted Fleet Side Barden bumper, Step Side in the middle. |
#80 | |
I spent 2 hours after work yesterday and got the passenger floor cutout. Should be able to weld the patch in tonight. I found a huge wasp nest in the front cab support! Bret
#81 |
![]() Join Date: Mar 2013
Looks good!
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
#82 |
Nice job on the cab repair. Everything looks like it lined up nicely for you.
#83 |
Thanks guys. It came out alright. I got the passenger side welded in last night. It lined up much better. My first cut was damn near perfect. Instead of using the sheet metal clamps I used the big triangle welding magnets and the made it much easier to lineup up the panel.
Just ordered all my parts for the frontend rebuild and the rest of the cab patch panels I needed. I saved a ton of money buying all my fontend parts from Amazon. All Moog too. The difference between O'riellys and Amazon for all my parts was like $350 difference! Here is what I bought upper and lower ball joints upper and lower control arm shaft assemblies Inner and outer tie rod ends rear control arm bushings (polyurethane) track arm bushings (polyurethane) Idler arm Pitman arm I also bought a new ram jack for my engine hoist since it already failed after only 2 uses and some metal to metal bondo from Evercoat And a 9/16" drill bit for the lower control arm u bolt upgrade. Bret
#84 |
Good progress
Amazing how much money you can save shopping around. Will call you again sometime when I am awake late so it takes up the time difference.
MY BUILD LINK: http://67-72chevytrucks.com/vboard/s...585901]Redneck Express - 1966 C10 Short Fleetside MY USA ROADTRIPS http://forum.retro-rides.org/thread/...2018-humdinger IF YOU CAN'T FIX IT WITH A HAMMER, YOU'VE GOT AN ELECTRICAL PROBLEM MATE. |
#85 |
![]() Join Date: Feb 2014
Great job repairing your cab. Looks like you didn't have to replace your cab supports? Also like the sand blasting booth you made up! Think I will do the same!!
#86 | |
Bret
#87 |
Sure don't know how I missed your build, but I am caught up now….
![]() I would be seriously concerned about your boy that's in a pic on page 1… He looks deep in thought, mmmm what can I do to get this away from dad??? ![]() Sandblast booth... ![]() ![]() Very Nice on the cab repair... ![]()
DON Proverbs 27:17 ![]() US Air Force Retarded errr Retired My '65 Stepper Build:http://67-72chevytrucks.com/vboard/s...d.php?t=533920 My '60 Rusty Patina Build:http://67-72chevytrucks.com/vboard/s...66#post7402266 My '72 http://67-72chevytrucks.com/vboard/s...59#post7204359 SOLD Last edited by Ta2Don; 03-20-2014 at 10:35 AM. Reason: Add-on |
#88 |
Thanks Don. Its funny you should notice that as my ultimate goal is to build this truck for my boys to enjoy when they get older. They are 5 and 7 so I have some time. The one in the picture is the 5 year old and he loves being in the garage and helping with everything. He is going to be a maker for sure.
Of course I am going to enjoy it as well until they are old enough too. Bret
#89 |
I spent some time this morning working on the passenger fender. I guessed it was hiding some damage as the core support on that side was damaged a little. From then inside there were several holes with bondo coming out of them and about a 3/4" deep dent. OUCH.
I cleaned off all the bondo ![]() ![]() I had to remove this brace to have access for the hammer on the inside ![]() This is what I ended up with after some hammering. Not to bad will still require some bondo but not 1/2" thick at least ![]() I switched gears after that and starting stripping all the front suspension. Here is where I ended for the day. ![]() ![]() Bret
#90 |
nice...I'll be there in the next week or two myself.
#91 |
I have got all my goodies for the front end except the idler arm. Should be here in the next couple of days. Also still waiting on my patch panels from Top Banana
Here is all the stuff I bought on Amazon. ![]() ![]() One more 10 hour shift and then I'm on vacation for 12 days! Bret
#92 |
This is a quick video I made last year before the tear down. I don't think I ever posted it
https://www.youtube.com/watch?v=P8rx...6b8e0CcGKJNG_Q Bret
#93 |
![]() Join Date: Mar 2011
That's a great stack of parts you got there! I'll bet you can't wait to get started. I just finished vacation and didn't do a thing to the truck. Just played.
Sanity'66 http://67-72chevytrucks.com/vboard/s...d.php?t=515110 Long bed, Fleetside, Small back window I've Done So Much, With So Little, For So Long, That Now I Can Do Anything With Nothing. ![]() |
#94 |
Nice stock of parts there! And good work!
#95 |
Parts, Parts, and more Parts...
DON Proverbs 27:17 ![]() US Air Force Retarded errr Retired My '65 Stepper Build:http://67-72chevytrucks.com/vboard/s...d.php?t=533920 My '60 Rusty Patina Build:http://67-72chevytrucks.com/vboard/s...66#post7402266 My '72 http://67-72chevytrucks.com/vboard/s...59#post7204359 SOLD |
#96 |
I'm just glad to be here!
Looks like you are going to be able to get some stuff done vacation!
BTW those are some cool wood projects on you bench. Did you make them?
Karl ![]() 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
#97 | |
![]() ![]() And last summer I had a little time frame with rockets. They are pretty simple to make on the lathe and a lot of fun. Mark I ![]() Mark II ![]() Mark III ![]() Mark IV This was my favorite one. ![]() I also spent a year making this 1/10 scale Scania Truck ![]() and my 1/10 scale small block Chevy for the 32' Ford I'm building. ![]() Bret
#98 |
Awesome Woodworking!!!
![]() GRIZZ Needs to see this... ![]()
#99 |
WOWZA! That's some sweet work you are doing! I wanna buy the steam train!!!!!!! LOL! Nice job!
#100 |
Your woodworking skills are top notch. My grandfather built custom cabinets after he retired from the fire department. I wish I could have learned more from him before he passed away. Your attention to detail on those projects is awsome!
