Old 03-27-2014, 06:40 PM   #1676
gdavis
gdavis's Avatar
Re: 1968
Today, I had to install some tile in a bathroom. But I still painted the front of the truck. To cover up the over spray. This last week we had a thunder storm with 45 mile winds and it made my canopy useless. I will have to go and buy another canopy. I thing I will try a better one this time a 7 mil instead of the 5 mil it came with.
Check out Patches
Cars I owned in the past.
1962 chev II Nova - 1965 Chevelle SS - (2)1966 Chevelle SS 1965 chev C10 57 belair chev
1967 Chevelle SS - 1969 Chevelle SS - 1972 Chevelle SS
1967 Buick electra 225 1995 Harley Davidson bager
What does not kill you will make you stronger
1968 c10 short wheel base stepper
gdavis is offline   Reply With Quote
Old 03-28-2014, 05:03 PM   #1677
gdavis
gdavis's Avatar
Re: 1968
Today I got another canopy cover and now I have a shade and the rain can't get to the truck.
then I mounted both fenders
then I mounted the grill
Check out Patches
Old 03-29-2014, 10:54 AM   #1678
Xeen
Xeen's Avatar
Re: 1968
The truck looks great George!
Please call me Brian.
Check out My 1972 SWB Fleetside 5.3L Vortec Restomod Build
Xeen is offline   Reply With Quote
Old 03-29-2014, 03:19 PM   #1679
tlyday
Re: 1968
Wow, your truck is looking great. I am a high school teacher and am finishing up my spring break here in indiana. Not much of a spring if you ask me. I too am stuck outside with my build and the march snow is putting a damper on my plans!!!
Quick question. My next task is changing out my rusty old trailing arms. The only parts I'm missing are the u-bolts as I had to cut them off due to rust. Any IDEa where I can get the right set of ubolts?? Thanks and good luck finishing her up. I'll be watching
tlyday is offline   Reply With Quote
Old 03-29-2014, 08:09 PM   #1680
gdavis
gdavis's Avatar
Re: 1968
Today I mounted the cowl and adjusted the body lines on the two fender with the cowl
As you can see I bumped the paint off on the door edge. I will have to repaint the door again. no big thing though. I hope to mount the hood back on the truck. Then all my parts to the body will be back on the truck. What is the easiest way to adjust the hood.
I will start the bed supports next. I will have to spot weld the bed supports and then remove the frame and weld them together solid. I am planing on raising my bed 5 inches.
Check out Patches
Old 03-29-2014, 08:24 PM   #1681
gdavis
gdavis's Avatar
Re: 1968
thanks Brian. I installed the cowl today and adjusted the body line on the fenders go and ck them out.
Check out Patches
Old 03-29-2014, 08:24 PM   #1682
gdavis
gdavis's Avatar
Re: 1968
thanks guy I sent you a PM
Check out Patches
Old 03-30-2014, 05:00 AM   #1683
Xeen
Xeen's Avatar
Re: 1968
George buy some green paint tape and line all the edges, it will help keep the paint chips from happening.
Old 03-30-2014, 04:37 PM   #1684
cubber
Re: 1968
Looks great George! My work has kept me real busy lately, and moving to the new house. I'm glad to see you're still at it! Turn a bolt or two for me. I love the orange, too!
=MATTHEW
69 Stepper...Stroked & Bagged GONE BUT NOT FORGOTTEN
2003 Chevrolet Z71 Ext. Cab
1995 Cavalier gas saver!
cubber is offline   Reply With Quote
Old 03-30-2014, 06:58 PM   #1685
gdavis
gdavis's Avatar
Re: 1968
I seen that done. But I did not do it so now I have to repaint the one door edge.
Check out Patches
Old 03-30-2014, 07:00 PM   #1686
gdavis
gdavis's Avatar
Re: 1968
Thanks guy and I hope you all the luck in the world on your new home. And when you drive down to pinelas park stop by. glad to hear from you.
Check out Patches
Old 03-30-2014, 07:01 PM   #1687
gdavis
gdavis's Avatar
Re: 1968
Tomorrow I hope to mount the hood. I need to get my friend over and help me.
Check out Patches
Old 03-31-2014, 08:05 PM   #1688
gdavis
gdavis's Avatar
Re: 1968
Today I mounted the hood and somewhat adjusted the hood. I installed the hood stops also. Ran into some difficulty adjusting it so I stopped. It was starting to get me upset so I thought I better walk away before I made a mess of it. It closes real nice but the drivers side is a litter high on the front and back. I think the front can be adjusted with the hood stop. but don't know about the back of the hood.
Then I installed both turn signal housing on the front of the truck. That was the easiest thing I did today.
Then I mounted the 15'' chrome over flow tank. I wished I bought the 13'' instead of the 15'' it would have gave me a litter more room on the bottom of the tank to attach the lines. Take note guys sometimes bigger is not better.
Then I mounted the 105 amp chrome alt. But my big red wire is not long enough to reach the battery. So I will have to make me a jumper lead from a terminal block to the battery. If I had my alt on the pass side it would have been long enough.
looks like things are coming together now. I had to remove the e brake cable and run it underneath the steering shaft and clamp it to the inter fender. now it don't move around. It don't rub on the shaft like anymore. It looked clean until I took the picture it shows all the dust in the engine compartment.
Check out Patches
Old 03-31-2014, 08:28 PM   #1689
Dean'smeanmachine
Dean'smeanmachine's Avatar
Re: 1968
i bet you are getting exited to fire that thing up soon!
Dean
1972 Custom Camper c/20 5.3 LS swap in progress. http://67-72chevytrucks.com/vboard/s...d.php?t=610187
in God we Trust
Dean'smeanmachine is offline   Reply With Quote
Old 03-31-2014, 09:17 PM   #1690
Mustard72
Mustard72's Avatar
Re: 1968
Why green paint tape?
Looking really good, George!
Nick
Old Mustard, 1972 Chevy C20, 350, TH350, 4.10 Dana 60 rear, owned since I was 16 in 1986
http://67-72chevytrucks.com/vboard/s...d.php?t=545356
Blue Bell, 1987 K20, 6.2L Diesel, TH400/NP208, 4.10 gears
Ustahav 1976 K10, 350/350/203, Gov Loc, Yooper beater trail truck.
Mustard72 is offline   Reply With Quote
Old 03-31-2014, 09:24 PM   #1691
SeTx67
SeTx67's Avatar
Re: 1968
Can you loosen the hood hinges and rotate the back of the hood down to help bring the hood down a tad? I had to do this on my truck and it helped but I'm still learning and may have done it wrong . You're moving right along as usual George and your truck looks great.
67 SWB LS2/4l70e... http://67-72chevytrucks.com/vboard/s...d.php?t=587435
SeTx67 is offline   Reply With Quote
Old 04-01-2014, 07:50 PM   #1692
gdavis
gdavis's Avatar
Re: 1968
It acts as a cushion. This way if you do bump the tape, the tape takes the blunt of the action.
the reason you should use frog tape it does not lift the paint so much. blue or green will work.
Check out Patches
Old 04-01-2014, 07:51 PM   #1693
gdavis
gdavis's Avatar
Re: 1968
I see what you are saying I will try that tomorrow. I will let you know if it works.
Check out Patches
Old 04-01-2014, 07:55 PM   #1694
gdavis
gdavis's Avatar
Re: 1968
Today was the third time I tried to get the right belt for the alt. One time to long and the next to short. Advance Auto.
I didn't do much on the old girl. We had friends down from Boston, Ma. and we spent the time with them. But tomorrow I will get back at it again.
Check out Patches
Old 04-01-2014, 10:37 PM   #1695
Mustard72
Mustard72's Avatar
Re: 1968
I understood that part. Just wondering why green? Is a certain tape better than others?
Nick
Old 04-02-2014, 06:56 AM   #1696
SuperC10Tex
SuperC10Tex's Avatar
Re: 1968
"The green tape adheres to automotive surfaces and removes cleanly after you've completed the job." I guess 3M is saying it sticks, but it will not lift paint.
1970 GMC Sierra Grande CST SWB Fleetside "Texas Touch"
"An intellectual is a man who takes more words than necessary to tell more than he knows"
SuperC10Tex is offline   Reply With Quote
Old 04-02-2014, 08:15 AM   #1697
Low Elco
Re: 1968
At the car paint store, they sell a 3M tape that's 3x thick and not as sticky especially for assembly. Not cheap, but it works good!
Low Elco is offline   Reply With Quote
Old 04-02-2014, 07:27 PM   #1698
gdavis
gdavis's Avatar
Re: 1968
The green tape I find is better and it is more expensive also. But what price can you put on a lifted paint.
Check out Patches
Old 04-02-2014, 07:30 PM   #1699
gdavis
gdavis's Avatar
Re: 1968
Mustard, low elco, super C10 tex
I never tried 3M tape guys so I can't knock the product. I have used blue or green painters tape and it work. I have to double it up though. twice the tape is still cheaper. I did not get to work on the old girl today. I had to do some electrical wiring for my daughter.
Got to do a little honey to do list for her. Isn't kids wonderful?
Check out Patches
Old 04-02-2014, 08:41 PM   #1700
kowboy63
Re: 1968
Man, you have this project moving. looking good
kowboy63 is offline   Reply With Quote
