Old 03-28-2014, 02:56 PM   #1
jmader
jmader's Avatar
1967 327 Engine Question
Ok I'm looking for the "correct" intake manifold for my 67 GMC K15 327 engine. My part # books for both Chevy and GMC list the part # as 3888885 but that's not the casting number. The research I've done online tells me that the casting number would be 3882858 but when I look up that number it only lists it for a 283 engine. Can someone with a parts interchange manual tell me if these are the right numbers I'm working with? Thanks in advance.
1949 Chevy 3100 Five Window
1964 Chevy C10 Lambrecht Auction project
1967 Chevy SWB K10
1967 GMC K15 Project
Build thread-
http://67-72chevytrucks.com/vboard/s...72#post6502772
1968 Chevy Anniversary K10
1991 K5 4" Lift 35's (the wife's toy)
jmader is offline   Reply With Quote
Old 03-28-2014, 10:17 PM   #2
airdale94
airdale94's Avatar
Re: 1967 327 Engine Question
I don't have a book but it could be due to the fact that the 327 was only produced a few years. The 283 ended in 1967, after 10 or more years, and the 327 came out in 1968. Basically they were the same block. In 71 or 72 the 350 and 307 replaced it with a new block design. They may have just used the the 283's manifold on the 327.
68' C20. 283CI w/55CC 305HO heads, NP435 Close Ratio, Corp. 14 bolt FF 3.21, 75' front end swap (everything but the X-member).
airdale94 is offline   Reply With Quote
Old 03-28-2014, 11:09 PM   #3
too much stuff
Roadtrip!
too much stuff's Avatar
One number i come up with if it would be a 4bbl holley would be 3872783. (from a chevy book, not sure if GMC would be the same)
The 327 was out in 62
67 gmc custom lwb dakota truck. Sold...And bought back
69 swb 4x4 project (in progress)
70 c-10 lwb texas truck
70 4x4/BB/bkts/posi/tach(retired)
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
71 cheyenne 4x4/tach/posi/ plow rig
71 Cheyenne20 BB, buckets, tach, tilt, 4 speed
72 jimmy CST wyoming rig
72 jimmy Colorado rig
72 lifted texas 4x4 3/4 ton burb
65 fury conv. 383/auto
65 chrysler 300 "L" 413 auto
too much stuff is offline   Reply With Quote
Old 03-28-2014, 11:47 PM   #4
SS Tim
SS Tim's Avatar
Remember a factory parts manual is a service replacement part and will often be different from a production part. If you can find access to a 67 GMC parts manual (printed in late 66 or early 67) that may be close. Anything later is going to be an expanded coverage universal part number.
There is a big difference between "parts interchange" and "as built".
SS Tim is offline   Reply With Quote
Old 03-29-2014, 12:22 AM   #5
michael bustamante
michael bustamante's Avatar
I thought 67 small block v8 truck only came with a 283 and 327 came out in 68. I could be wrong
1967custom
michael bustamante is offline   Reply With Quote
Old 03-29-2014, 12:39 AM   #6
SS Tim
SS Tim's Avatar
66-68 on the 327 light truck engines not sure if ran a little into 69 like Camaros or not though. Never researched it.
Old 03-29-2014, 12:40 AM   #7
Hutch
Hutch's Avatar
I do not have the answer to your question.
Not to hijack this thread
Did you happen to see this article on one of the lambrect cars?
http://autos.yahoo.com/blogs/motoram...lkA1ZJUDM4NF8x
John Hutchison
Grapevine,Texas
68 1/2 t swb
68 Mustang
69 Jaguar
71 1/2 t swb
88 Supra CompTs6m
93 Escort GT
2005 Corolla XRS
Hutch is offline   Reply With Quote
Old 03-29-2014, 10:33 AM   #8
jmader
jmader's Avatar
Good point. My GMC master parts book was printed November 1969 so there's a good chance the numbers in it aren't exact. Some websites I read the 3882858 was used extensively as a service replacement so they might not have ever been on the vehicles originally.
Any other ideas out there? This one has really got me stumped.
1967 Chevy SWB K10
Build thread-
Old 03-29-2014, 10:33 AM   #9
airdale94
airdale94's Avatar
Wikipedia
327
The 327 cu in (5,354 cc) V8, introduced in 1962, had a bore of 4 in (101.6 mm) and a stroke of 3.25 in (82.55 mm). Power ranged from 210 hp (157 kW) L30 to 375 hp (280 kW) depending on the choice of carburetor or fuel injection, camshaft, cylinder heads, pistons and intake manifold. In 1962, the Duntov solid lifter cam versions produced 340 hp (254 kW), 344 lb·ft (466 N·m) with single Carter 4-barrel, and 360 hp (268 kW), 352 lb·ft (477 N·m) with Rochester mechanical fuel injection. In 1964, horsepower increased to 365 hp (272 kW) for the now dubbed L-76 version, and 375 hp (280 kW) for the fuel injected L-84 respectively, making the L-84 the most powerful naturally aspirated, single-cam, production small block V8 until the appearance of the 385 hp (287 kW), 385 lb·ft (522 N·m) Generation III LS6 in 2001. This block is one of three displacements that underwent a major change in 1968/1969 when the main journal size was increased from 2.30 inches (58.4 mm) to 2.45 inches (62.2 mm). It's also interesting to note that in 1965 Chevrolet released the now legendary L-79, which was nothing more than an L-76 (11.0:1 forged pop-up pistons, forged steel rods and crank, 2.02 Corvette heads), but with the 30-30 Duntov cam replaced by the #151 hydraulic cam. The 327-350 hp engine could give many big blocks a run for their money.
In 1966, Checker began offering the 327 as an option.[5] The Avanti II and its successors were powered by the 327 and later versions of the small-block V8.
In 1968, the 327 was exported to Australia for use in the Holden HK Monaro GTS327. The engine was used in the Monaro after development of the locally made Holden V8 engine fell behind schedule. The 327 was replaced in the 1969 Monaro by the 350.
Old 03-29-2014, 11:25 AM   #10
67swb72klb
67swb72klb's Avatar
my 67 came with a 327 4bbl it had a carter carb and of coarse had the oil fill in front on the intake I have no pics or part #
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project
67swb72klb is offline   Reply With Quote
Old 03-29-2014, 11:29 AM   #11
too much stuff
Roadtrip!
I have a complete 327 4 bbl from a 68 3/4 ton. I will see how buried it is. If i can pull some casting numbers, i will try.
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
Old 03-30-2014, 09:45 AM   #12
jmader
jmader's Avatar
Ok thank you. Does anyone have an original 67 with the 327 they could look at their casting numbers?
1967 Chevy SWB K10
Build thread-
Old 03-30-2014, 12:59 PM   #13
jmader
jmader's Avatar
We're the Holley carbs used very much on these trucks? I don't know anything about them.
1967 Chevy SWB K10
Build thread-
Old 03-31-2014, 06:57 PM   #14
jmader
jmader's Avatar
Ttt
1967 Chevy SWB K10
Build thread-
Old 04-10-2014, 03:10 PM   #15
SS Tim
SS Tim's Avatar
Ttt
Old 04-10-2014, 03:36 PM   #16
dmartin1
dmartin1's Avatar
my 67 327 has " 3882858" on it. though it is not a 283.
it is the small square bore rochester carb, i believe called the "4gc"
i actually removed the intake because the carb was gone and couldnt find an adapter ANYWHERE
way different then a spread bore quadrajet or the carters fronm what i found.
it has the oil fill in the front and the bolt for the banana bracket for the alternator.was original to the truck, 1 owner
1969 Shortbed in progress
1982 short step, few suspension and motor upgrades.getting a 468
1978 Shortbed fleet side bonanza fully loaded
1978 k20 Silverado loaded.currently engine-less
1989 k10 suburban 9" lift
65 nova
And more
dmartin1 is offline   Reply With Quote
Old 04-10-2014, 08:46 PM   #17
jmader
jmader's Avatar
Thanks for the input. I was thinking that intake was right but I was also under the impression that all 67's with a 327 came with a Quadrajet. I guess I didn't notice the 3882858 had the smaller bore.
Does anyone know if the 4gc's did in fact come with these trucks? I was thinking they were used in the early 60's.
1967 Chevy SWB K10
Build thread-
Old 04-10-2014, 09:58 PM   #18
ray_mcavoy
Yes they did ... At least the 4G manual choke version anyway. The 4GC is the automatic choke version that was used in late 50's and early 60's cars. Although the car 4bbls had changed over to Quadrajets by 67, trucks were still using the 4G.
Years ago I parted out a rusty 67 C10 with a 327 that appeared to be relatively untouched. The engine went into another project (since sold) but I had done some checking and found that the intake & 4G carb were the same as 66 pickup truck 327's. So I saved those for Dad's 66 C10.
If I get a chance tomorrow, I'll check the intake casting number and see if it's a 3882858 or not.
ray_mcavoy is offline   Reply With Quote
Old 04-11-2014, 08:39 AM   #19
jmader
jmader's Avatar
Yeah that would be very helpful. My parts book calls for carburetor part number 7027125 which would be a 4 jet 4G so I'm almost convinced that the intake 3882858 is what I need.
1967 Chevy SWB K10
Build thread-
Old 04-11-2014, 06:38 PM   #20
ray_mcavoy
I took a look at the intake earlier today and it is indeed a #3882858. This particular one has a date code of "B 13 7" ... I believe that'd be February 13th of 67 so that seems to fit with it being original to that 67 truck.
I also looked at the carb and it is a Rochester "4 Jet" 4G. The little metal tag with the number is missing though.
Old 04-11-2014, 11:59 PM   #21
cdngearhead
Put a 67 L79 Intake on!
cdngearhead is offline   Reply With Quote
Old 04-17-2014, 02:10 PM   #22
jmader
jmader's Avatar
Thanks everyone for your input. I'm going to go with the 3882858 right or wrong. I'm pretty confident in it though. Makes it all the easier since I already have the right 4g carb.
1967 Chevy SWB K10
Build thread-
