Old 12-31-2003, 03:39 PM   #1
bucket
bucket's Avatar
pinion nut size
what size socket do i need to remove the pinion nut on a 3/4 ton rear end? my 1 1/2" socket dosen't fit. looks to be a weird size.
bucket is offline   Reply With Quote
Old 12-31-2003, 06:20 PM   #2
smokekiki
Mike
smokekiki's Avatar
Mine took a 1- 5/16th.
70'c/10, 71 suburban4x4 402bb, 72suburban 4/6 drop, 72k/5 4x4 blazer 4" lift 35 tires
smokekiki is offline   Reply With Quote
Old 12-31-2003, 06:20 PM   #3
Rod
1 3/8 for the dana. Had to buy one of those myself in 3/4 inch drive. There tight... I was after the power lok and gears and the yard guys turned the truck over for me as I couldn't get the leverage needed under the truck to break the pinion nut loose. Dont worry the truck was worked over before they flipped it.
Senior active founding member.
70 3/4 ton GMC Suburban 4x4 250/4 spd.
71 1/2 ton Suburban Chevy 4x4, 350/350
72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane
2005 FLSTSCI Harley Springer
85 FXSB Harley Lowrider
72 Triumph 650 Bonneville 5spd
"Poor people don't have hobbies" Quote from wife.
Rod is offline   Reply With Quote
Old 12-31-2003, 06:41 PM   #4
jack'd up
What about a 12 bolt. I have every socket execpt that one. A 30mm will all most work.
jack'd up is offline   Reply With Quote
