Old 03-29-2014, 08:54 AM   #1
Wildman65
??? for you guys sitting low.
Hi! I'm new here. Picked up a 1965 Shorted fleet side back in December and have been working on it off and on since. I've converted it to 5-lug, disc brakes up front, all new ball joints, tierods, Idler arm, pitman arm, lowering springs & shocks, drop spindles, etc. Put some 18" Ridler wheels on it. Has a 454/TH400 combo & 3.73 posi rearend. Going to be a fun truck!
To my question. I lowered the front with 3" drop springs and 2.5" drop spindles. So 5.5" up front and I went 4" in rear. I really like the stance but I'm a bit concerned about the ground clearence of the lower a-arms and center cross member. Just wandering if anyone else is like this and if they have any troubles with anything. Thought about going a little taller on the front tires and maybe going to a 2" drop spring to gain a little more. Any thoughts.
Wildman65 is offline   Reply With Quote
Old 03-29-2014, 09:25 AM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: ??? for you guys sitting low.
The stance is perfect up front.
I would actually lower the rear a little more.
The a-arm issue is the main problem with these trucks.
No way around it if you like it this low,... unless you add air bags up front.
But then you will be driving at a taller ride height.
This is where the Porterbuilt Dropmembers fix this problem.
They raise the a-arms up in the frame for more ground clearance.
Short of a sectioned crossmember or a "Z'd" frame,... you are stuck raising it back up with taller tires or taller front springs.
Keith
Convert to disc brakes.
Old 03-29-2014, 09:42 AM   #3
Narxoleptic Customs
My truck lower arms are 4" from the ground. I've put over 1500 miles with no issues. I do not recommend any lower that that for sanity sake...
18" rims w 245/55 tires
Narxoleptic Customs is offline   Reply With Quote
Old 04-03-2014, 06:15 PM   #4
Wildman65
Yeah, that's what I'm worried about. I may have 3". I'm putting power steering on it now and was thinking of going ahead and pulling the 3" drop springs and put the 2" drop ones in and go to a bigger tire dia.. I know the springs won't really change the outer portion of the a-arms but will pull the center up an inch.
Old 04-04-2014, 02:32 PM   #5
timmytimm3
You could always section the crossmember to bring everything up but that takes a lot of work.
A sectioned crossmember with Porterbuilt forward arms is a nice setup.
Nice truck!
http://67-72chevytrucks.com/vboard/s...d.php?t=742865
66 SWB, C4 Dropmember
timmytimm3 on IG
"If you don't have time to do it right the first time, when will you?" -Dad
timmytimm3 is offline   Reply With Quote
Old 04-04-2014, 04:38 PM   #6
forestb
forestb's Avatar
I have a 4.5-5 inch drop in front and my lower control arms scrape of I go to fast over speed bumps. I think you will scrape with a 5.5 drop. You must have one heck of a rake with that set up.
forestb is offline   Reply With Quote
Old 04-04-2014, 07:20 PM   #7
Wildman65
probably my best bet would to just put non-drop spindles back on it.
Old 04-04-2014, 07:35 PM   #8
shortbed70
shortbed70's Avatar
What are the specs on the wheels? Backspacing and width... Love the look
PM me easier cause I don't check in here often..
Troy
1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb
my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884
Big Red Dog build
http://67-72chevytrucks.com/vboard/s...d.php?t=572274
shortbed70 is offline   Reply With Quote
Old 04-04-2014, 09:44 PM   #9
grs
How close to the ground are the lower control arms? Let the air out of the front tires and see if any thing touches the ground. And if you hit a 4 inch pot hole in the street what will happen? Low looks good, but I like safety first.
grs is offline   Reply With Quote
Old 04-04-2014, 10:49 PM   #10
Wildman65
Technically, to low! I'm not sacraficing safety and I'm sure not going to tolerate scraping and worrying about everywhere I go. So I think I'm just going to look into stock height spindles.
Old 04-05-2014, 05:53 PM   #11
grs
How about stock springs? Then the front would not be so low.
Old 04-05-2014, 08:33 PM   #12
donthekawguy
donthekawguy's Avatar
Keep the spindles and if you have to get shorter springs. 1 the spindles cost more 2 its better to have it lowered with spindles. Try driving it around like it is and see if you scrape on anything. Go into some steep parking lot entries and go over some speedbumps. You might be suprised at what it takes to scrape on anything. Back in the mini truck days we got pretty good at pulling in and out of parking lots without scraping anything.
66 shorty
donthekawguy is offline   Reply With Quote
Old 04-06-2014, 02:39 PM   #13
Wildman65
I think I've made my decision. I found some 1.5" drop springs from Western Chassis. I'm going to order them and hopefully get them by next weekend. I just put power steering on it yesterday and need to fab up some lines and switch springs and it's ready to take in for an alignment and drive it!
Old 04-06-2014, 03:46 PM   #14
familyfast64
familyfast64's Avatar
Just drive it and see. I have 2.5 " spindles and either 2 or 3 in drop springs. My lower arms are about 4 inches from the ground and I've put over 7xxx miles on her without any issues other than the occasional rear end bang against the frame. I have 3 inches of clearance between the rear end housing and both the bed and frame rails. It only hits on a large bump but I definitely need a c notch. Other than that I believe I need to remove some of the metal area of the front bump stop as well. Even tho it has hardly ever touched, it would if I was going crazy. Other than that, if you had the money I suppose porterbuilt would be the best bet but Damn! All that money cannot be justified to me at least unless of course you were to bag it. I just bought some stiffer lowered front shocks and that made a big difference surprisingly. My old shocks were junk. I also have air shocks in back and without them I'd be in trouble. .. what really surprised me is the lack of body roll. I have no anti sway bars and hardly any roll in corner. Altho I plan on purchasing them, just lowering the center of gravity helps so much. These trucks are nice and wide too which I'm sure helps. I'm falling more and more in love.
Live and let live
familyfast64 is offline   Reply With Quote
Old 04-06-2014, 04:25 PM   #15
theastronaut
theastronaut's Avatar
My daily driver ('64 VW Bug) is 2.75" off the ground and it hardly ever scrapes. Try it before you pull it apart.
theastronaut is offline   Reply With Quote
Old 04-06-2014, 05:00 PM   #16
Slow Build
Slow Build's Avatar
What size tires are you running? You might need to get taller tires. I like a tire around 28" tall.
Current Ride: 1964 C-10 Short Fleetside
Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe
Past GM Trucks:
1959 GMC short stepside
1968 GMC short stepside-4x4
1973 Chevy short stepside
1989 Chevy short fleetside-reg cab
1993 Chevy short fleetside-Xcab
2002 Chevy short fleetside-Xcab
Save the dinosaurs, use synthetic oil.
Slow Build is offline   Reply With Quote
Old 04-06-2014, 06:07 PM   #17
Wildman65
I think I forgot to mention that I'm running a 454 big block. That might a bit to do with it. I figure if I put 1.5" drop springs on, it will be realistically more. Might even go with a 1" drop spring. right now the lower control arm towards the middle cross member and including the cross member is roughly 2" maybe a little more. It won't be a problem putting the new springs in because everything is new and should come right back apart.
Old 04-06-2014, 08:54 PM   #18
gimmy 64
I agree with everyone else drive it! I have 21/2 dropped spindles and 2 in. lower springs. it does look pretty scary with the control arms ,but you need to look at the scrub line that is where the problems can come. mine is above the scrub line and I have no problem going over speed bumps in parking lots or anything. I am running 235-60-15 tires and I was running 245's with no problem
gimmy 64 is offline   Reply With Quote
Old 04-06-2014, 09:27 PM   #19
ChrisDollins
ChrisDollins's Avatar
Another here for just drive it. Bring the back down a little and cruise it. Good looking truck!
Chris
ChrisDollins is offline   Reply With Quote
Old 04-20-2014, 10:27 AM   #20
Wildman65
Well, when I first lowered and dropped it down on the tires for the first time, I couldn't get my floor jack out! So I took care of the problem. I pulled out my 3" drop springs and swapped them out for some 1.5" drop springs. Now I feel satisfied and I can get my jack out. Of coarse I was so focused on the springs that I totally forgot about the drop shocks! LOL! New shocks on the way! And I might swap the tires out for a little taller ones. The fronts are just too low profile for the little more gap I have in the fender wells. Can't wait to get this thing on the road! I added power steering last weekend. Just need to swap the shocks, get the tires, then it's ready for alignment so I can drive it to a friends shop to put a nice exhaust setup on it.
Old 04-20-2014, 02:49 PM   #21
Slow Build
Slow Build's Avatar
What size tire are you running now and what tires are you thinking about mounting?
Past GM Trucks:
Old 04-20-2014, 05:17 PM   #22
familyfast64
Sweet bro, it's coming.
Live and let live
Old 04-20-2014, 09:25 PM   #23
Wildman65
235/40-18 up front and I may go with 235/50-18 along with going 285/40-18 in the rear in place of the 285/35-18. If it won't cost me to much more. If it's more than I want to spend right now, I'll just go with 245/45-18 up front. Hope that all made sense.
Old 04-20-2014, 10:21 PM   #24
64chevmn
I'm in the same position; 2.5 drop spindles and 3-inch drop springs. I'll get the cab back on the frame along with everything else and see where it sits after all the weight is back on the suspension. I may be doing the same thing you are if it bottoms out driving out of my garage! Post a few more pictures with the new drop springs in place.
64chevmn is offline   Reply With Quote
