03-29-2014, 06:47 PM | #1 |
Draining Air Compressor ?
Just curious as to how often everyone drains the moisture/water build-up on their shop air compressor ? Just drained mine this afternoon, single stage 60gal. vertical tank. Drained a full two quarts from it. Seems like a lot, was sure I drained it at the end of summer last year. Maybe not? Usually try to drain at the end of summer and again in the start of spring even tho don't use it a lot during winter. Anyone have a schedule or particular time they do it? General shop usage, air tools, air nozzle, air impact on occasion, bead blast cabinet, airing tires and such.
1971 Chevy 1/2T 4x4 LWB 350 V-8 Was sm465-now 350TH/np205 Tilt, Tach, Towhooks Original Truck AM/FM Wellington, Ks |
03-29-2014, 07:50 PM | #2 |
Re: Draining Air Compressor ?
Basically everything is a factor on how often it needs to be drained. How much it runs,how old it is, temperature, etc etc etc all affect how much moisture the compressor builds. If this is a home compressor twice a year is plenty. 2 quarts of water isn't a whole lot.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member. |
03-29-2014, 08:31 PM | #3 |
We drian ours at work everyday but they get alot of use our 60 gallon we bought used after install it woukd run 3 mins and be at max pressure. Bearly use it it run ann the time found the drain plug broke totaly removed the drain plug and it drained water for an hour and half been fine since just a mTter how howmuch it is used and the temps used in
03-29-2014, 10:30 PM | #4 |
i drain mine when i remeber it. theres a big yellow magnet on it that says drain every 2 weeks. I drained it the other day and didnt tighten the drain back up very well so now it leaks. But I was thinking since I dont use it alot and turn off the breaker after im done I may just leave it. the leak still takes 2 days to leak out from 150psi. its like draing for lazy people.
03-30-2014, 09:50 AM | #5 |
Dang, truckdude, that was a lot of water!
03-31-2014, 07:11 AM | #6 |
Watch out for your cornhole !
For me, it's somewhere between daily and weekly. I had to save hard to buy my big compressor so I try to take measures to treat it well.
03-31-2014, 02:04 PM | #7 |
harbor fright has an auto drain kit you can get for $10, it burps the tank every time it runs
my home shop i try to drain it weekly and have a line run outside for this, right now the drain valve is frozen and hasn't been drained all winter the real shop gets drained every day when we shut down for the night
cool, an ogre smiley Ogre's 58 Truk build how to put your truck year and build thread into your signature shop air compressor timer |
03-31-2014, 11:45 PM | #8 |
Thanks for the replys. May need to look into that auto drain setup. Sounds like would be a good deal. Used the compressor today for about two hours of bead blasting. Compressor keeps up pretty well, usually run it for 30/45 minutes and then shut it down to cool somewhat.
04-01-2014, 07:22 AM | #9 |
I replace the wied drain cock with pipe and a ball valve that sticks out for easy access. Make the job easy and you will do it more often. I can throw the valve with toe of my boot. Not squatting required.
'70 GMC C1500 LWB Power disc brakes. WooHoo! Posi 6 Lug Dana 60 |
04-01-2014, 07:23 AM | #10 |
i live two blocks from the ocean so i do it daily
04-03-2014, 11:32 AM | #11 |
thats excatyl how ours are them cheap valves aren't worth anything
