03-31-2014, 02:57 PM | #1 |
Electric fan?
I had a quick question,its about to get hot here in Dallas and my 67 is my daily driver and it has the original fan with no fan shroud.will adding a single or double electric fan cool it down enough? Just don't want to have to fork out 4 to 500 for a aluminum radiator that comes with the fans..thanks
03-31-2014, 04:00 PM | #2 |
CAN'T FIX NOTHIN
Re: Electric fan?
I have not looked in the last little while but I got an aluminum radiator for less than $200 for my 67 I think the fan will help ? But not sure on the hottest of days if it will be enough ,,,,
1967 C10 Shortbed Fleetside Small back glass 6 cyl 3spd on the tree 3.08 gears underdash AC |
03-31-2014, 04:03 PM | #3 |
Re: Electric fan?
Just get a shroud. That will make the biggest difference.
I know a guy who's addicted to brake fluid. He says he can stop any time. 72 K10 396 75 Cj5 MPI 350 Chev 67 Chevelle 396, 4 speed 74 FXE 08 Tahoe |
03-31-2014, 04:13 PM | #4 |
Parts and more parts
Re: Electric fan?
Everyone wants good things for a little price. The radiator and fan are the major supporters of that pricey thing under your hood (The engine). I would spend the most money on protecting that engine and less on other goodies, if it is in my house. Nothing more pitiful, than a good looking hot rod or truck sitting on the side of the road belching out water. I run electric fans on my trucks and with the dual fans and the electronic fan controllers, I have a better cooling setup and it warms up better in the colder months. I also save some fuel by taking that load off of the engine, which ultimately gives a little amount of torque increase.
Frank |
03-31-2014, 04:29 PM | #5 |
Re: Electric fan?
I got a thick two core rad from summit racing 160 bucks and a junkyard 16 inch fan. My sbc has no cooling issues.
03-31-2014, 04:32 PM | #6 |
Re: Electric fan?
Just to clarify...a fan without a shroud is similar to an impeller without a pump housing. Taking off the shroud is a sure way to get overheating issues. These trucks ran in hot weather as built, so the system design is good. Not saying there isn't better, but a good fitting shroud should keep you moving.
03-31-2014, 04:33 PM | #7 |
Re: Electric fan?
Thanks for the comments guys i guess ill get me a new radiator with the electric fans i sure ass hell dint need to be stuck on the side if the road lol.i heard that becool brand is the best but damn ones with the fans are mucho$$$....or maybe ill just see a a shroud will help first
03-31-2014, 07:06 PM | #8 |
20' Daredevil (Ret)
Re: Electric fan?
It's your money, but if your radiator is good, why replace it and why buy electric fans? Your truck won't overheat with a shroud and a clutch fan unless there's something else wrong anyway.
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
03-31-2014, 08:03 PM | #9 |
Old member
Re: Electric fan?
I ran the truck fan and shroud for over 20 years with no problems with AC. Buy a correct shourd for the truck. Then take foam and place it around the openings on the outter edges of it and the radiator support. This forces the air through the radiator and it will cool better if the air is directed through it than around it.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
03-31-2014, 08:38 PM | #10 |
Cruzin
Re: Electric fan?
Just buy a shroud is my op. the can be had new so i think it would still be cheaper than new rad, fans, etc. I like the mechanical side of the original clutch fan much more reliable than an anything electric to me.
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8 Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U Proverbs 3:5,6 "Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt In memory of our first baby daughter, daddy and mommy love you. Danica Grace 6/26/14
04-01-2014, 12:41 AM | #11 |
Re: Electric fan?
Im looking for a fan shroud ..thanks for all the good info
04-01-2014, 08:40 AM | #12 |
Re: Electric fan?
I've got a flex a lite electronic controller with two black magic puller fans and I love it. You couldn't give me one of those crappy belt fans with shrouds. That controller is progressive and only turns on one fan at a time and starts it off at 50% power on one fan at whatever temp you set it at then goes to 100% on one fan then progressively turns the other fan on as you get hotter so you draw as few amps as possible. Fan Controller is a Flex A Lite 31174 or 31173. one has a screw in temp sensor. Once you get rid of that big junky shroud and fan you will never go back.
http://www.flex-a-lite.com/media/cat.../1/31165_1.jpg |
04-01-2014, 09:52 AM | #13 |
Re: Electric fan?
The main thing when going electric is to get good electric fans. You have to be careful buying generic auto parts store fans, sometimes they just don't draw enough air. I ran into that problem before.
I'm on the fence on one or two electric fans. I think that one BIG fan cools better, when you have two smaller ones, I think you get some air turbulence in some situations and it doesn't cool as good. The advantage to two however is if one goes out, you still have one. You can also control the amount of air flow if you wire them to separate.
1972 C10 "Project Ole' Blue" CLICK HERE for the build thread 1969 C10 Late model bed, smoothed engine bay, digital dash, custom interior CLICK HERE for pictures |
04-01-2014, 09:53 AM | #14 | |
Re: Electric fan?
04-01-2014, 10:09 AM | #15 |
Re: Electric fan?
I bought a set of electric fans from Jegs. I think they are Derale brand. I have them set up so one comes at 190, second one at 205, with 2 separate adjustable thermostats. High 90's, sitting in traffic with the AC on, it will seldom get to the 205 setting. I have a factory style 4-core radiator. The fans needed a tiny bit of the plastic shroud trimmed to fit the radiator. Otherwise it was a very easy install.
NJ is NOT the same as Texas weather, but I have no issues at all with this setup. Aluminum radiator is not required.
Shawn 1970 Chevy C-10 SWB, 350, TKO 600 5 speed My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881 |
04-01-2014, 10:47 AM | #16 |
Re: Electric fan?
This is a good write-up of an electric fan using the factory shroud. I am going to try doing this on the weekend if weather cooperates.
http://67-72chevytrucks.com/vboard/s...d.php?t=254617 |
04-01-2014, 02:01 PM | #17 | |
Re: Electric fan?
04-01-2014, 02:04 PM | #18 |
Re: Electric fan?
Mechanical fans NEVER blow a fuze and leave you stranded
1946 car hauler 1948 surburban 1937 chevy sedan 1940 olds sedan (project) 1967 ss396 chevelle 1999 dually crewcab(24000 miles) |
04-01-2014, 02:32 PM | #19 |
Re: Electric fan?
Yes, you are correct that they never blow a fuse, but the clutch can give out and even grenade on mechanical...been there.
Whatever your preference, the shroud is the key to making it work efficiently. |
04-02-2014, 12:18 AM | #20 | |
Re: Electric fan?
04-02-2014, 01:28 AM | #21 |
Re: Electric fan?
I did the jeep fan in my shroud with a thermostatic switch. Works great.
04-02-2014, 02:10 PM | #22 |
Project Junkie! Fishing Poor!!
Re: Electric fan?
I run these. I have them on 3 trucks hear. 2 big block trucks and 1 small block. I haven't ever had any overheating problems with this systom. They are my own design. http://www.classicheartbeat.com/radi...&__related.htm WES
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys |
04-02-2014, 02:22 PM | #23 |
Re: Electric fan?
I did the Cherokee fan mod too. Mines a mod of the mod though :
project: "my happy mess" |
04-02-2014, 02:34 PM | #24 | |
Registered Cruiser
Re: Electric fan?
I intend to live forever. So far, so good. |
04-03-2014, 12:06 AM | #25 | |
Re: Electric fan?
