Old 04-01-2014, 10:53 PM   #1
keh27
keh27's Avatar
looking to by a front sway bar
I want a new factory style front sway bar which is the best one that fits in factory location. thanks all ps. Buy lol
keh27 is offline   Reply With Quote
Old 04-01-2014, 11:38 PM   #2
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
Re: looking to by a front sway bar
The least expensive way to get a front sway bar for your truck is to go to a wrecking yard and find any 73-87 Chevy or GMC truck with a front sway bar and take it for your truck and you should be able to get one for 25/40.00 with the brackets and new brackets are available as well. The biggest you will find is an
1 1/4 inch bar and they are found on C20's and C30's. This is one of the best bang for the buck you can do to your truck.
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 04-01-2014, 11:40 PM   #3
19GM71
19GM71's Avatar
I can't speak for new ones but I thought I would share what I did. I found one at a salvage from an 81-87 1/2 ton. Cleaned it up, painted it and bought some new bushings from the parts store and bolted it up. I did not remove the drop brackets from the donor due to the rivets holding them on, so I just bolted it straight to the frame. This worked out very well due to the 3" drop springs, the sway bar is setting a good angle, not hanging to low below the frame and Wow! did it make a difference in the handling! Maybe just another option for you.
19GM71 is offline   Reply With Quote
Old 04-01-2014, 11:43 PM   #4
keh27
keh27's Avatar
thanks guys
Old 04-01-2014, 11:46 PM   #5
Already Gone
I know Early Classic Enterprises and other vendors sell front sway bar brackets for lowered trucks. I have them on my stock height truck and like them because you can't see the sway bar.
Old 04-02-2014, 07:45 AM   #6
csfields
csfields's Avatar
I did what already gone did. Purchased new bushings and everything fit real nice. Less than 50 bucks invested. got mine at a local pull a part.
Thanks,
Casey
71 Chevy C-10 SWB 350/400 PS, PB
The Build http://67-72chevytrucks.com/vboard/s...d.php?t=584045
The Brake Upgrade http://67-72chevytrucks.com/vboard/s...d.php?t=695699
csfields is offline   Reply With Quote
Old 04-02-2014, 09:03 AM   #7
Tom Vogel
2WD Jimmy
Tom Vogel's Avatar
The sway bar from Early Classi Enterprises is a better unit than factory.
Tom Vogel is offline   Reply With Quote
Old 04-02-2014, 09:08 AM   #8
chopnchaneled
chopnchaneled's Avatar
How come ??????
I don't think we get smarter as we get older. We just run out of Stupid things to do.
chopnchaneled is offline   Reply With Quote
