Old 04-03-2014, 07:41 PM   #1
siggyfreud
siggyfreud's Avatar
Header and CPP mount issue
Well I just got my old headers back from the coating company. In the month they had them I received and mounted the motor with new CPP mounts. Went to put the headers in today, and passenger side is pretty far off on fitment, running into the mounts.
Driver side fits okay, but close:
Anyone have any ideas, or at least know of headers that DO fit well?
siggyfreud is offline   Reply With Quote
Old 04-03-2014, 08:39 PM   #2
siggyfreud
siggyfreud's Avatar
Re: Header and CPP mount issue
Hehe mounts are brand new! Doh! Would hate to try new aftermarket mounts and figure out they still don't clear, versus shelling out a bit more for headers that someone already knows WILL clear. Problem is I don't remember what headers I do have . . as I bought them 10 years ago or so.
I know stock mounts work, but really don't like the single bolt through the center of the mount. It always seems to separate.
Old 04-03-2014, 08:58 PM   #3
bj383ss
bj383ss's Avatar
Man that sucks. I like those CPP mounts but I'm afraid my headers won't fit around them. I'm just going to use the originals. They worked for 50 years I guess they'll work another 50.
Bret
64' Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=586955
bj383ss is offline   Reply With Quote
Old 04-03-2014, 09:04 PM   #4
siggyfreud
siggyfreud's Avatar
Yeah I guess I'll reuse the original mount and see if I can find a better quality rubber mount than before.
Old 04-04-2014, 12:22 AM   #5
Captainfab
60-66 Nut
Those headers look like car headers to me. If you had headers made for a truck, they would likely clear those engine mounts.
Old 04-04-2014, 01:48 AM   #6
siggyfreud
siggyfreud's Avatar
You're likely right. Now I just have to decide if I'd rather have these freshly coated headers or new engine mounts, with the former costing about 3x more to replace.
Old 04-04-2014, 06:51 AM   #7
PGSigns
PGSigns's Avatar
Check with the vendors here for the Prothane 7-509BL mounts. Put the stock stands back in. Or you could trim the CPP mounts, my first choice.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 04-04-2014, 09:13 AM   #8
63burban
Chevy addict
Trim the mounts
63burban is offline   Reply With Quote
Old 04-04-2014, 10:49 AM   #9
siggyfreud
siggyfreud's Avatar
I'd have to trim a lot on the CPP mount to make the passenger side fit. It's over an inch off at the back. I'll double check but I'm afraid I'd compromise the mount doing so. The support shafts stem directly from the top, so I'd be cutting into the tubular shafts to grind the mount down. Perhaps I can grind it down flat and then weld it back together, but not sure how much changing the shape affects the integrity.
Old 04-04-2014, 10:55 AM   #10
Chevy Fleetside
Chevy Fleetside's Avatar
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 04-04-2014, 01:27 PM   #11
RockTonka
RockTonka's Avatar
I'd sell the headers and get some that fit...if you bought them 10 yrs ago you might make money on the deal! Those mounts are too nice to cut up...
1958 Chevy 1 ton dually 4X4 dump/flat bed
My build thread
1966 "Not-So-Original" Chevy Custom Trim Suburban
My Time-Killing Project Truck
1966 GMC Extended cab 1 1/4 ton 4X4
My Son's build thread
RockTonka is offline   Reply With Quote
Old 04-04-2014, 03:46 PM   #12
1963c-10
1963c-10's Avatar
I agree....I'd keep the mounts and find the proper headers for the truck.
1964 Short bed trailer
Old 04-05-2014, 06:48 PM   #13
bama63
bama63's Avatar
these clear anything http://www.jegs.com/i/Hedman/500/696...FWxp7AodQVYA3Q
also available in a coated version.
Due to financial constraints, the light at the end of the tunnel will be shut off until further notice
bama63 is offline   Reply With Quote
Old 04-06-2014, 05:05 AM   #14
siggyfreud
siggyfreud's Avatar
I ended up ordering these: http://www.summitracing.com/parts/HED-69890
They should clear the mount and work with my angle plug heads. Just have to find a new hike for my old headers. Inc Craigslist!
Old 04-06-2014, 10:13 AM   #15
1963c-10
1963c-10's Avatar
can always save the headers for the next build
