04-06-2014, 12:25 AM | #1 |
1968 chevy to 1989 gmc suburban conversion
Hey guys so here's the deal; I picked up a 1968 Chev C10 LWB pickup last summer and have decided to do a conversion to a 1989 GMC suburban front clip and drivetrain (with the exception of rear axle) and was wondering what you guys think? And what problems I will encounter! I have already figured out the suburban has a mechanical speedo and I need electronic for the gauges to work. Any help on this project will be much appreciated. I can post updates as well if wanted. Thanks!
-1968 C10 Longbed-Work in progress |
04-06-2014, 12:50 AM | #2 | |
I have a radical idea!
Re: 1968 chevy to 1989 gmc suburban conversion
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! |
04-06-2014, 01:07 AM | #3 |
See for yourself
04-06-2014, 02:17 AM | #4 |
Yep, that's a squarebody. The front crossmember is an easy swap. IIRC, you have to drill 1 or 2 holes, but once you get them both off, you'll see what you need to do by comparing both frames.
If the Suburban has a mechanical speedo, it should just be plug and play to make the speedo work. If your '68 has factory gauges, the oil pressure gauge is mechanical so it will work anyway. All you'll need is the '68 sending unit in the newer for temp gauge to work. You will need a kit to make the lockup converter work in the Suburban's transmission, if it is a 700R-4, unless you are putting the computer and wiring out of the Suburban in the '68. If the engine in Suburban is EFI, and you want you run that, somebody else will have to help you on that, because I don't do fuel injection. Unless it's a diesel!
04-06-2014, 02:23 AM | #5 |
Ok well I'm planning on using whole wiring harness and computer out of the suburban and I am not using stock 68 gauges. I'm getting aftermarket ones. The problem is finding 5" ones that are also metric. Thinking about going digital but lmc' new cluster is only imperial and intellitronix create a kit doesn't have an indicator gauge! I don't know what to get
04-06-2014, 07:16 AM | #6 |
I didn't understand at first,but by "front clip" you meant front suspension and not the sheet metal (which is what the "clip" is). Alrighty then,getting easier now. As Jamie said,you can do all you planned and fairly easily. The speedometer is cable drive,so no issue there,except the one you invite by not wanting to stick with the original KPH unit. Good luck with that. You're on you own there.
04-06-2014, 11:01 AM | #7 | |
04-06-2014, 10:59 PM | #8 |
I've heard clip to refer to the front suspension,too,but I think the title started my confusion. I was wondering how someone could convert a 68 Chevy into an '89 GMC Suburban
04-08-2014, 12:06 AM | #9 |
Man why would anyone want to do that lol?
04-08-2014, 12:12 AM | #10 |
Would've saved me some horrific thoughts!
I know a guy who's addicted to brake fluid. He says he can stop any time. 72 K10 396 75 Cj5 MPI 350 Chev 67 Chevelle 396, 4 speed 74 FXE 08 Tahoe |
04-08-2014, 07:48 AM | #11 |
There is no explaining the thoughts and ideas of some minds out there. I've seen some trucks where my only thought was "WHYYYYYYYYEEEEE??????????
04-08-2014, 08:49 AM | #12 |
I was a little worried there myself. Whew! Putting the vodoo doll away now...
'70 GMC C1500 LWB Power disc brakes. WooHoo! Posi 6 Lug Dana 60 |
04-08-2014, 09:04 AM | #13 | |
Whew! K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
04-13-2014, 12:00 AM | #14 |
Just got motor in today and boy she is a tight squeeze
Tags |
chevrolet, gmc, lwb, pickup, suburban |
