Old 04-06-2014, 01:56 PM   #1
Sven
Sven's Avatar
1969 4x4 front axle
I have a 1969 4x4 with drums and leaf springs all around. I'm done with the drums and want to get disk brakes on it. The problem is, as far as I know, it's impossible to retrofit disks to the front of a 67-71 due to the closed knuckle.
Anyway, I'm looking at replacing the front axle (and the complete braking system) from a 72-87 (the later the better), which, I understand, is a direct bolt in.
Anyone know if the direct bolt in for this is actually true? I'm a bit of a neophyte, so any help from the gurus before I start spending money would be great.
Thanks,
-Steve
1969 Chevrolet 4x4 C10 Pickup
Sven is offline   Reply With Quote
Old 04-06-2014, 02:11 PM   #2
too much stuff
Roadtrip!
too much stuff's Avatar
Re: 1969 4x4 front axle
Basically a bolt in and go from 71 and newer. I think there was some little change in the late 70s, but it was minor. Make sure the gears match the rear, and i wouldn't spend much on one. There are alot of them out there.
67 gmc custom lwb dakota truck. Sold...And bought back
69 swb 4x4 project (in progress)
70 c-10 lwb texas truck
70 4x4/BB/bkts/posi/tach(retired)
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
71 cheyenne 4x4/tach/posi/ plow rig
71 Cheyenne20 BB, buckets, tach, tilt, 4 speed
72 jimmy CST wyoming rig
72 jimmy Colorado rig
72 lifted texas 4x4 3/4 ton burb
65 fury conv. 383/auto
65 chrysler 300 "L" 413 auto
too much stuff is offline   Reply With Quote
Old 04-06-2014, 02:16 PM   #3
Sven
Sven's Avatar
Thanks mate!
Old 04-06-2014, 06:38 PM   #4
1972RedNeck
1972RedNeck's Avatar
Lucky for you, it is very possible and quite simple.
http://www.blackbirdscustomtrucks.com/index25.html
1966 F250 4X4 416
1972 K20 350 4 OTF
Originally Posted by GASoline71 View Post
I once pulled an intake manifold for a cam swap... ended up with a full on drag car that ran in the 11's.
1972RedNeck is offline   Reply With Quote
Old 04-06-2014, 07:10 PM   #5
BLT gmc
Search the threads there are quite a few addressing this issue. The one I found most helpful is titled "Dana 44 closed knuckle disc brakes" by danw210
If your are committed to keeping the original axle it can be done. With that said the quickest least expensive way is to do the post 71 open knuckle swap. Travel well, Bruce
BLT gmc is offline   Reply With Quote
