Closed Thread
Old 04-06-2014, 07:13 PM   #426
iceship
Re: What did you do to your truck today part II.
URL=http://s1100.photobucket.com/user/iceship/media/Cars/trucks/20140406_162216.jpg.html][/URL]
jeep shaft in, fix gear box leak while shaft was out. .
pics of rear glass from the other day
iceship is offline
Old 04-06-2014, 07:18 PM   #427
TJ's Chevy
TJ's Chevy's Avatar
Originally Posted by Grizz1963 View Post
Popped over to mate Martin early morning to help him swop over his "new" patina, rustfree hood, then a haircut at 11.00 and home by 11.30 at which time I brought the truck out of the garage up to the house for a wash and prep for Easter weekend, which will see much truck time including two days on display with the Teardrop trailer.
When Nicola came home from seeing her dad, I washed and cleaned her Mazda MX5 Miata.
Then we took the truck out for a ride into the local farmers fields and also down to the Isle of Grain where she took some pics.
Thought I would post up a bunch of photo's Nicola took today.
I washed the truck and got it ready for Wheels day, and the Chatham Steam and Traction Festival over Easter weekend.
One of my favourites.
The sky was really good as well.
Clever camera.
Out on the Isle of Grain.
After Easter the teardown will start.
Ohhhh, and I recorded the sound of the truck, Nicola operating the camera.
https://www.youtube.com/watch?v=RXAI...lt8TvG8KEwT5Kg
And another
https://www.youtube.com/watch?v=y7Sq...lt8TvG8KEwT5Kg
Free entry tickets in the post today as well..... that is good
Subscribing to you on youtube! If you wanna see my channel its "Chevyman" Nice pictures to!
TJ's Chevy is offline
Old 04-08-2014, 12:06 AM   #428
pimpston65
pimpston65's Avatar
got my new trim tag today, now my glovebox stuff and other bits are complete. never thought id say a job on thos truck was complete but i hope its the first of many completes soon to come!!!
pimpston65 is offline
Old 04-08-2014, 01:05 AM   #429
markeb01
Senior Enthusiast
markeb01's Avatar
Finished installing the new chrome Ididit steering column today. The new Mooneyes steering wheel is due to arrive tomorrow. Here’s a before and after shot of the column:
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
markeb01 is offline
Old 04-08-2014, 01:09 AM   #430
pimpston65
pimpston65's Avatar
markb01 the dash and column looks awesome, at first i thought it was the space shuttle with all those knobs and switches no vital fluids will get passed you!!!
Old 04-08-2014, 11:16 AM   #431
aclay17
aclay17's Avatar
Thumbs up Re: What did you do to your truck today part II.
Brought "Mean Green" out East with me to GA.
'91 Chevy 350 2/4 Drop.
'67 Chevy LWB 250 Inline 6 w/4 speed.
Southern Classic C-10 Club
2013 Hot Rod Pour Tour
aclay17 is offline
Old 04-08-2014, 08:06 PM   #432
pimpston65
pimpston65's Avatar
painted my bench seat frame, gettin ready for my self made upholstery
Old 04-08-2014, 08:07 PM   #433
pimpston65
pimpston65's Avatar
shiny black glad it was a nice day for painting
Old 04-08-2014, 08:09 PM   #434
pimpston65
pimpston65's Avatar
painted my wheel parts they were powder coated many yrs ago never installed so i cleaned and used high temp paint to freshin them up
Old 04-08-2014, 08:22 PM   #435
Lugnutz65
Lugnutz65's Avatar
Nice job on the Ididit! If I don't like my restored factory column I think I'll do the Ididit or a Flaming River - but they ain't cheap!
IIRC you have a floor shift and that means a floor shift column with only turn signals and an emergency flasher switch. Key stays on the dash, right?
How difficult was it to install and what size did you choose, (what length)?
Thanks.
My 65 C10 build: www.lugnutz65chevystepside.weebly.com
Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild.
Lugnutz65 is offline
Old 04-08-2014, 09:58 PM   #436
TJ's Chevy
TJ's Chevy's Avatar
Did some repairing on the stakes for my truck today.
Old 04-09-2014, 07:25 AM   #437
markeb01
Senior Enthusiast
markeb01's Avatar
Thanks.
Yes I have a floor shifted 4 speed manual transmission, and the ignition switch remains in the factory location. I picked the 32” chrome steel version, part number 101320020. It was very easy to install. I used the factory floor clamp, and years ago I added a muffler clamp at the dash to secure the column to the lower pedal support housing. I’ll add a photo of this later today in my build thread.
In the engine compartment I retained my 2nd generation Monte Carlo intermediate shaft. I simply knocked the cross pin out, ground the round portion into the DD shape, trimmed 7/16” off the end and joined the column to the intermediate shaft by using a polished SS Borgeson joint. The lower shaft is ¾” DD and the bottom of the column is 1” DD. I haven’t taken any pictures of this yet, so I’ll also add them in my build thread later today.
The most difficult issue was sorting out which wire would work on the Ididit adapter for the horn. I ended up using the straight wire that came with the column, and spliced on my old connector to the horn plate. The one that comes with the adapter was soldered to the horn plate, making it nearly impossible to connect after the wheel is installed.
One interesting note – every Covico, Grant, and Superior wheel of this type I’ve seen has the top two mounting holes level across the top like these:
The Mooneyes wheel apparently was designed with the Ididit column in mind, as they rotated the mounting holes clockwise:
This was to accommodate the nylon tower on the horn plate being set at 10:30 on the top of the column. This allows identical travel left-right on the cancelling cam.
With the Covico wheel, I had to position the horn plate at 9:00 as the upper left mounting hole is located at 10:30.
With new Mooneyes wheel, I simply pulled the adapter back off and rotated it to match the wheel position. I did have to drill a new hole at the location shown in the blue circle so I had room for the horn wire to make the turn into the cavity under the steering wheel. It sounds more complicated that it was. The entire modification/adjustment took about 10 minutes.
Here are a couple of shots with the Mooneyes wheel installed:
It is exquisitely finished and is truly beautiful compared to my classic Covico version.
markeb01 is offline
Old 04-09-2014, 06:18 PM   #438
pimpston65
pimpston65's Avatar
got some more parts today and polished my brake and fuel lines poor mans chrome just buff to high shine and clearcoat
Old 04-09-2014, 06:20 PM   #439
pimpston65
pimpston65's Avatar
took only 5hrs but labor was free and i had the equipment
Old 04-09-2014, 06:22 PM   #440
pimpston65
pimpston65's Avatar
good thing i scored bent lines off a 65C10 so no bending on my part
Old 04-09-2014, 06:23 PM   #441
pimpston65
pimpston65's Avatar
gifts from usps
Old 04-09-2014, 06:52 PM   #442
grs
I drove the truck for the first time in 4 months. And I found out that I can start it with the house key.
grs is offline
Old 04-11-2014, 01:55 PM   #443
TJ's Chevy
TJ's Chevy's Avatar
What I did yesterday with my truck and currently doing.
Old 04-11-2014, 02:08 PM   #444
tonythezeek
tonythezeek's Avatar
just got back from the DMV. My truck is now legal to drive in the Sunshine State.
tonythezeek is offline
Old 04-11-2014, 04:48 PM   #445
65Gregg
65Gregg's Avatar
Changed my OEM 30 ohm fuel sending unit for a converted 90 ohm sender, I think I'll have to do some fine tuning though, it doesn't go all the way to full on the gauge when full. Now it's time to run a tank through it an see how it registers when low. Thanks Chevyrestoguy for the sender to modify.
65Gregg
Blue long bed
White TBSS
61 Impala
“The two most important days in your life are the day you are born and the day you find out why.” Mark Twain
65Gregg is offline
Old 04-11-2014, 04:59 PM   #446
Casaba
Replaced the backup light switch on the column of my 66 today
Casaba is offline
Old 04-11-2014, 06:58 PM   #447
LVPhotos
LVPhotos's Avatar
Cleaned garage and loaded up the truck for Mutt and Jeff's swapmeet tomorrow.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline
Old 04-11-2014, 10:13 PM   #448
grs
What is the difference in a 30 ohm, and a 90 ohm? Would the gauge have to be changed too?
grs is offline
Old 04-11-2014, 11:39 PM   #449
65Gregg
65Gregg's Avatar
Arrow Re: What did you do to your truck today part II.
I had to change because aftermarket gauges need a different Ohm value in order to read correctly.
65Gregg
Blue long bed
White TBSS
61 Impala
65Gregg is offline
Old 04-12-2014, 12:12 AM   #450
Softpatch
Softpatch's Avatar
Wait you do work with your truck.?
Wow I'm having trouble rap'n my mind around that
Work truck = truck work.....
.nope must be Photochopped
Missing my backhoe
Softpatch is offline
Closed Thread
