04-07-2014, 01:50 PM | #1 |
engine oil priming... dont do this!
just a short story id like to share about this saturday. well anyway i was priming my fresh 350 with a drill driven tool i bought from lmc. I spun the tool over by hand just until i felt resistance from the oil, so then i took the drill and spun it slowly. well, didn't seem like much priming was being done, so i went balls to the wall with the drill, and about a half second later, about 60 psi of oil shot out of the port for the oil pressure gauge two- three foot high and all over my arm that was running the drill, all over my transmission, frame rails, everything, made a mess! well after taking off my oil soaked sleeve of my sweatshirt, i installed a guage and got a healthy max of 65 psi of oil pressure. well.. lesson learned here is that you should always put a oil pressure gauge or even a plug in your engine while you are priming it so you dont get a 2 foot oil geyser that makes a mess of your work like i did! well now that everything is cleaned up and pretty looking my motor is almost ready to fire off!!! well i guess this is part of the learning experience, wont make that mistake again, all in fun! like my dad always says, you can live and learn, but you still die dumb!
04-07-2014, 01:55 PM | #2 |
Active Member
Re: engine oil priming... dont do this!
Holy smackerel!
So no "balls to the wall with the drill." Good info to be aware of since I am in the process of redbuilding an engine and was going to do the same on it once I put it together. btw: Hope that wasn't inside your garage.
68 GMC 250/3 speed Saginaw p/b p/s 69 Chevy 350/350 currently in pieces still lookin for a cab 06 Trailblazer I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive... |
04-07-2014, 03:18 PM | #3 |
Hahahhahahah
Been there, done that
04-07-2014, 03:32 PM | #4 |
2WD Jimmy
Could have been worse. You could have actually started it before hooking up the oil pressure gauge. Now THAT will empty out your oil in great quantity and quick. Ask me how I know. lol
04-07-2014, 04:48 PM | #5 |
I did something similar once, I had stripped everything off my 69, inside and out in prep for a paint job. I left only what was needed to drive it to the shop, I even removed the gauge cluster. Got in and headed down the road when I felt my crotch getting warm, looked down to see oil shooting out of the dash, I forgot to plug the line for my oil pressure gauge. Had to drive three miles to a parts store on the way so I could buy a plug then another 15 to get to the paint shop. Walking around with an oil soaked crotch on a hot day really sucks!
http://smg.photobucket.com/albums/v655/aaronhero/ |
04-07-2014, 05:06 PM | #6 |
KEEP ON TRUCKIN'
Did that about a month ago. Shot oil all over my garage wall. Your not alone my friend.
JIM '97 GMC Sierra K1500 '95 Chevy Silverado C1500 '71 Cheyenne Z71 / LT1 & 4-Speed SWB K/10 Father/Son Project http://www.youtube.com/watch?v=4l689JKXPnA http://67-72chevytrucks.com/vboard/payments.php "LIVIN' FREE FOREVER" |
04-07-2014, 05:10 PM | #7 |
Now you have a well oiled elbow.
My Trucks: 1967 Chevrolet Short Wide Box 327 TH350 9" w/3.90 gears paint will be White - Current Project 1967 Chevrolet Custom LWB 283 TH400 3.73 Posi, no-AC, no-PS, no-PB, bench-seat, small-window - mostly orig driver 1967 Chevrolet CST LWB originally a 327 TH400 3.73 Posi AC PS PB, had Buddy Buckets, Small Window - parts truck 1967 Chevrolet CST LWB, 283 MT 3.73 had Buddy Buckets, Panoramic Window - parts truck 2001 Chevrolet 3500 2WD Crew Cab Dually 8.1L Allison White |
04-07-2014, 08:46 PM | #8 |
04-07-2014, 09:50 PM | #9 | |
Parts and more parts
Frank |
04-07-2014, 09:52 PM | #10 |
You got lucky, I had my son's engine on the stand, forgot to plug the opening and when the oil hit the open hole, I painted the ceiling on my shop with oil. That ceiling is 12 feet high and the engine was sitting about 4 feet high at the top of the engine. Luckily the ceiling is metal and all I had to do was wipe it off, but at least I know the oil pump is good.
Frank |
04-08-2014, 09:49 AM | #11 | |
04-08-2014, 09:52 AM | #12 | |
04-08-2014, 09:53 AM | #13 |
04-08-2014, 10:51 AM | #14 |
...just another truck junkie..
We've all had some sort of adventure like this. Anyone that says they haven't has not been wrenching regularly! I took the instrument panel out of my '71 to replace the main wiring harness and forgot to hook up the line for the oil pressure gauge. I drove a ways before I realized it was oil peeing onto my boot
Mike "Bear" Shea Last edited by Bears63; 04-08-2014 at 10:52 AM. Reason: grammar, spelling, the usual.... |
04-08-2014, 10:57 AM | #15 |
After installing a new dash bezel I forgot to hook up the oil pressure gauge and "Painted" the underside of my dash with a fresh coat of oil. Not fun cleaning while standing on your head!
04-08-2014, 11:02 AM | #16 |
I built it
try priming oil on a big block and itll have a sideways stream of oil. ask me how i forgot it... hahaha
'72 k10 lwb 454, th400, 205, d44ft, 12b rear, 4in skyjacker, 35x12.5-15 superswampers, 4.56, blazer tank. painless wiring harness '98 dodge 3500 12v 5sp 4x4. the truck that actually runs |
04-08-2014, 11:41 AM | #17 |
Location: Formerly MD and San Diego, now loving life in Arizona
Thanks for posting this reminder. I just installed my 396BB in my truck and was going to get ready to fire it up this weekend. I totally forgot about that orifice that needs to be capped...
Alan 2012 Ram 3500 Dually Crew Cab 6.7 Cummins 2014 Palomino Columbus 340RK 5th wheel '69 Chevy C10 396BB |
04-08-2014, 09:58 PM | #18 |
You really brought out the elbow grease didn't cha?
04-09-2014, 09:39 AM | #19 |
04-09-2014, 09:40 AM | #20 |
glad to know im not the only one who forgot to put the line on and blew oil everywhere, thats some relief! also good to know i helped people remember to put the line on before firing their new engine!
04-09-2014, 01:40 PM | #21 |
I built it
well i was in a bad mood after i noticed i forgot to put the timing tab on before the balancer and had to rent the puller/installer again. and decided id just get the priming done for now. shot oil half way across the garage.. i was basically foaming at the mouth at that point
04-09-2014, 01:50 PM | #22 |
I have a mechanical oil pressure gauge I added to the dash... I removed everything to repaint my dash after I cut it up for the A/C install... just wanted to move the truck out of the way for the night... Oil ALL OVER the floor... Luckily I had one of those thick rubber mats that caught most of it.
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
04-09-2014, 02:14 PM | #23 |
Okay, I gotta throw this one in here. I was watching a friend working his new engine one time. When he got ready to prime the oil pump he also used a drill and a priming shaft. He must have spun it for a good 10 minutes and was getting more frustrated by the minute. When he went in the house to call the auto parts store to complain, I went over and pulled the dip stick..... YA!
My build thread. 1977 C10 short box. >>>> http://67-72chevytrucks.com/vboard/s...d.php?t=624182 700R4 build thread. >>> http://67-72chevytrucks.com/vboard/s...36#post6740236 |
04-09-2014, 02:33 PM | #24 |
Junior Member
Reminds me of when I 'tried' to check the PSI in the nitrogen shocks of my newly purchased sand rail project. The tire pressure gauge went Ka-BLAM!! I found out later it's about 400 psi.....
"I was patina when patina wasn't cool." 1973 Cheyenne SWB Sunset Gold / Frost White / Saddle |
04-09-2014, 03:21 PM | #25 |
I started a 283 I just took back out of my truck and didn't notice the front oil pressure hook up was un plugged.. Shot 8 feet out and hit an innocent bistander walking through the auto shop at school. We all laughed and he wasn't mad
