Old 04-10-2014, 08:55 PM   #26
brad_man_72
the boat guy
brad_man_72's Avatar
Re: Questions for fellas with ls swaps
Originally Posted by Chevyllac View Post
correct me if I'm wrong but I was reading something along the lines of needing the gas pedal accelerator and the tac module??? so I would have to replace the accelerator pedal aswell??
If you want the drive by wire you will need an eletronic gas pedal. You can change to a mechanical throttle body and use your stock pedal.
My factory tach hooked right up to my pcm after it was reprogrammed to send 8cyl signal instead of a 4 cyl signal. I don't know anything about a tach module.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck
66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate.
28, model a rpu project,
brad_man_72 is offline   Reply With Quote
Old 04-10-2014, 09:58 PM   #27
chipflyer
chipflyer's Avatar
All the info you need can be found to do the harness yourself can be found here
http://lt1swap.com/
I did the harness myself and have little in it but my time, its a very fun sub project that anyone can do if they can follow directions. Brendan will also reprogram your PCM (remove VATS) for $75 on Gen III engines and $150 on Gen IV.
Look that site over good, all you need to know is there.
Jeff
I'm not a pessimist, I'm just optimistic that bad things are going to happen.
1971 Cheyenne Super K10 - tilt, cruise, air, am/fm, tow hooks, factory buckets!
1986 Jeep J10 pickup, - 5.3L Vortec with 4L60e and NP241.
chipflyer is offline   Reply With Quote
Old 04-10-2014, 10:01 PM   #28
Daaaanz67
Tac is throttle actuation module the brain between pedal and throttle body.
Daaaanz67 is offline   Reply With Quote
Old 04-11-2014, 09:31 AM   #29
rkn463
rkn463's Avatar
Yes, the 04 donor will be drive by wire meaning you have to replace the pedal assembly.
-Richard
I may have too many Chevys... Is that possible?
68 c50 pickup build: http://67-72chevytrucks.com/vboard/s...d.php?t=704713
rkn463 is offline   Reply With Quote
