Old 01-02-2004, 11:22 AM   #1
Charlie Coleman
Charlie Coleman's Avatar
What does screw do on this carb?
I'm not a carb man......
What does this screw do?
Thanks for any help!
Charlie Coleman is offline   Reply With Quote
Old 01-02-2004, 11:26 AM   #2
PR454SS
PR454SS's Avatar
I would have to say it's the float adjustment
PR Too many projects, not enough time!
72SWB 350/350TH, 3500stall,525 lift cam 3:73 posi. Sold!
69LWB Flatbed 350/Super T-10, ported/polished 481 heads, 480 lift cam.
78SWB 468/400TH, ported/polished Alum. heads, 3:42 posi, 3000 stall on 17x8 and 18x9.5's
77 Jeep CJ-5 304V8 fiberglass body on 36" Ground Hawgs
PR454SS is offline   Reply With Quote
Old 01-02-2004, 12:50 PM   #3
71GMC_3/4T
Weapons Of Construction
71GMC_3/4T's Avatar
Fast Idle adjust?
It's a long way from the fuel inlet to be the float level adj.
1971 GMC 2500, 402/TH400 4.10 Daily Driver
Lafayette, CO
71GMC_3/4T is offline   Reply With Quote
Old 01-02-2004, 04:59 PM   #4
Charlie Coleman
Thanks for the responses...
Old 01-02-2004, 07:41 PM   #5
Don Smith
That is the idle vent valve. At idle or when the engine is shut off the vent releases fuel vapors. The vent maintains atmospheric pressure in the fuel bowl.
68 Short Stepside, 350, quadrajet, 700r4, 3:73 posi, power front discs, HEI, Factory Air, Tilt, Tach, accelerator cable instead of rod, sway bar.
96 Impala SS
97 Monte Carlo
Don Smith is offline   Reply With Quote
